Results 1 to 3 of 3
    Oct 2020
    Hanoi
    Question Hilux's Audio System
    So i want to play music on USB flash drive (and Micro SD card via USD adaptor) on my Hilux. I'm driving a Hilux 3.0 D4D SR, i believe the model was 2011. So my questions are: What are the limitations? Number of songs? Flash drive data capacity? Type of flash drive?
    Hope you guys can solve my curiosity on Hilux's audio system. Thank you in advance
    Nov 2006
    Thanked: 23
    Default Re: Hilux's Audio System
    Not sure what the specs are but in my Fortuners (2008 and 2014) I used a 16GB flash drive filled with music without problems.
    On very large folders (lots of songs) the mix/random function was not as successful as on the smaller ones.
    Hope this helps
    Thanked: 475
    Quote Originally Posted by itsanhthuw View Post
    I found with factory radio's, they like the SD card, USB stick or whatever to be formatted with FAT32, and not NTFS or something else.
    Some radio's have a capacity limit. I would guess 64GB. I could be wrong. But I have not had the need for bigger than 8GB. 8GB will give you around 1600 odd songs (5mb per song). And at avg 3 minute per song, that is a whopping 80 hours of music.
    2007 Nissan Pathfinder LE 2.5dCI 4x4
    2013 Nissan Xtrail 2.0dCi XE 2x4
