Defender Td5 Defender R380 Gearbox? Issue
Results 1 to 8 of 8
    Jan 2007
    Elardus Park
    Default Td5 Defender R380 Gearbox? Issue
    Evening all,
    Hopefully someone could provide some guidance as to their own experience when relating to my situation?
    Just left the office this evening, pulled away at a traffic light and once in 2nd gear a loud bang sound emitted from the transmission.
    No gears and a gears gnashing sound.
    Pressing and releasing the clutch you hear gears scratching, can select some gears but when you release the clutch gears start scratching as if not selected properly.
    Switch engine off, selected first, clutch in (gear noise), releasing clutch (scratches heavily).
    Prior to this, I realized when pushing the clutch in after driving at speed and in a gear, like slowing down towards a traffic light, the engine revs did not drop immediately or on some cases never, until I took it out of gear.
    Could this be a thrust bearing that failed?
    Clutch?
    Gearbox?
    Transfer case?
    Any advice would be much appreciated.
    Thanks in advance,
    Marius.
    _____________________________________________
    2013 Nissan Pathfinder 2.5 dCi SE 4X4
    Ex- 2000 Defender 110 Td5 - MUGWUMP.
    Ex- 1998 Range Rover P38 4.6 V8 HSE - Shrek
    Ex- 1997 Jeep Cherokee 4.0 - Thriller
    Ex- 1998 Toyota Hilux 2.4 D/C 4x4 Ltd - Rooiwyn
    Ex- 1998 Jeep Wrangler 4.0 (Manual) - Sputnik
    Ex- 1997 Jeep Grand Cherokee ZJ 4.0 A/T
    Ex- 1995 Suzuki Vitara 1.6 JLX
    Thanked: 2425
    Default Re: Td5 Defender R380 Gearbox? Issue
    Quote Originally Posted by MariusBez View Post
    Evening all,
    Clutch?
    Gearbox?
    Transfer case?
    Thanks in advance,
    Marius.
    If its NO DRIVE at all in ALL gears, then probably clutch.
    If its NO 1st, 2nd, 3rd, 5th and reverse, but you DO HAVE 4th, then the box has eaten the input pinion and layshaft gears.
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  3. The Following User Says Thank You to JohnnoK For This Useful Post:
    New Germany
    Thanked: 679
    Could be the small tapered bearing on main shaft that has let go,also resulting in 3rd and 4th syncros braking and the hub happened on a box that I used as spare to rebuild my box
    2005 Defender TD5
  5. The Following User Says Thank You to clivemd For This Useful Post:
  6. #4
    Jan 2007
    Elardus Park
    Thank you JohnnoK and clivemd,
    This already gives me something to work from.
    I will test the 4th gear when I get home.
    Then on to someone that would provide honest repairs and cost on it?
    Any suggestions?
    Pretoria area.
    Thanked: 27
    Take it to Walter or Org at LRXtreme. Their workshop is on the British 4x4 premises.
    www.lrxtreme.co.za
    2010 Defender Puma 110
    Bushlapa Boskriek B472
    New Germany
    Thanked: 679
    Get some one who knows the R380 and who can shim the main and lay shaft bearings properly I imported the Ashcroft rebuild kit and shim kit also new oil pump and oil ring when did mine, just crap when don’t have the proper tool to pull the rear seal collar off
    2005 Defender TD5
    Nov 2006
    Edenglen
    Thanked: 194
    Sounds like what my Defender did when it ate its clutch. Luckily only a couple of blocks from home, but still no way it was getting there under its own steam. Had to tow it back.
    Evening all,
    Clutch?
    Gearbox?
    Transfer case?
    Thanks in advance,
    Marius.
    Erin Bosch (082 342 1909)
    4xfagger no. GP0048
    2007 Volkswagen T5 4Motion
    New Germany
    Thanked: 679
    Drain the gearbox oil and transfer box oil and see if any bits of mettle come out and what oil looks like you might get a idea if it R380 or LT230 if all looks great could be clutch, letting go, end of day prob have to remove transfer box and R380 and then only see what problem is
    2005 Defender TD5
