Hilux 2,8GD-6: Paint Chipping
Results 1 to 6 of 6
    Feb 2012
    Sandton
    Thanked: 29
    Default Hilux 2,8GD-6: Paint Chipping
    Good morning,
    As the title suggests, I have a 2018 2,8GD-6 Hilux which I use to overland in. Last December I went to the Kaokoveld and in September I went to the Richtersveld in it. Both required travel on gravel roads. The paintwork on the mudguard/bodywork directly in front of both rear tires, now show quite a bit of stone chipping. In other words the bodywork between the rear tire and the rear door.
    Are there other members of the Forum who experience this part of the Hilux's paintwork getting damaged?
    And secondly, are there aftermarket mudflaps one can attach in order to protect the paintwork from further damage when travelling on gravel roads?
    Thank you, I would be grateful for any advice.
    2011 Toyota Land Cruiser 76 S/W
    Dec 2012
    PMB
    Thanked: 269
    Default Re: Hilux 2,8GD-6: Paint Chipping
    I have VPS on the lower part of the rear fender flare in the area you mention, it helps alot. But, the factory running boards, like them or loathe them, stop most of the stone chipping in the area you mention and on the lower part of the doors and the sills.
  3. The Following User Says Thank You to TOY4X4 For This Useful Post:
    Feb 2012
    Sandton
    Thanked: 29
    Thanks Toy, I have unfortunately taken off the standard running boards in order to put on rocksliders. Do you know of any effective aftermarket mudflaps that would prevent the spraying up of stones onto the paint?
    What is VPS?
    Feb 2012
    Sandton
    Thanked: 29
    Quote Originally Posted by Ernesto View Post
    What is VPS?
    It's a paint protection film layered over the paintwork of a vehicle.
    Mar 2016
    Thanked: 90
    Hi.
    Sorry for hi jacking the thread. Where in Centurion area can you buy/fit VPS?
    Thanks Johan
