Bluenova two or one
Results 1 to 20 of 20
    Thanked: 393
    Default Bluenova two or one
    Want to replace the 2 deep cycles in my Cheetah with either 1 x 218ah or 2 x 108ah. Any thing I should keep in mind?
    www.lani4travel.com
    Louis Le Grange
    Plett/Paulshof
    Thanked: 1217
    Default Re: Bluenova two or one
    I have one 200ah Sunsol battery. You will be happy and much cheaper than Blue Nova. Contact Byron at Sunsol solar.
    Bruce Hunter. 2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  3. The Following User Says Thank You to BruceHun For This Useful Post:
    Thanked: 112
    Perhaps just the length of the 218ah battery, it is listed @ 552mm.
    - Leonardo Da Vinci
    Also on
  5. The Following User Says Thank You to Rooikop For This Useful Post:
    Plett/Paulshof
    Thanked: 1217
    Pm me your number and I will send you the spec sheet
    Lonehill (JHB)
    Thanked: 29
    Is your battery charger lithium ready?
    2014 Ford Ranger 3.2 XLT 4x4 D/C Auto
    2018 Ford Everest 2.2 XLS 2x4 auto (SWAMBO)
    Echo 4 trailer
    Thanked: 393
    Quote Originally Posted by ChrisH View Post
    Jip it is.
    www.lani4travel.com
    Louis Le Grange
    Polokwane
    Thanked: 588
    With two batteries you can,
    1. Leave one at home, to save weight, if two are not needed for a short trip.
    2. Have a backup if one fails on a trip.
    3. Do bush welding by connecting them in series (24v).
    4. Place them at different spots in the vehicle for better weight distribution.
    Conqueror Courage 2016
  10. The Following User Says Thank You to DC Polokwane For This Useful Post:
  11. #8
    Feb 2013
    Thanked: 640
    Don't know what you pack under the bed in your Cheetah, but in general 2x 100 Ah sized batteries fit that space much better, since you can put them side by side, then it's much like the footprint of a case of beer.
    A single bigger battery like a 200 Ah actually wastes a lot of space since it's like 2x 100 Ah batteries next to each other in their length, so it basically takes up half of that compartment if you have it positioned front to rear of the van. If you can find a bigger battery which can fit in side to side of the van it can work, but I doubt it since the wheel arch is in the way.
    With the 108 Ah Blue Nova's you can't interface the BMS's of the batteries together, so the 2 going out of balance might be a problem, however I have no experience here, so in terms of this a single bigger battery might be better again, then you don't have to worry about balance, you don't have to worry about parallel cabling or fuses etc.
    Maybe also look at the Blue Nova 13V 2K mini HP, it's only 154 Ah though.
  12. #9
    Jan 2015
    Thanked: 207
    Also have 2 104's in the cruiser. Replaced them with this little beauty.
    120A/H @15kg vs 108A/H @50kg. Keeps 2 fridges running happily. Fits behind the backseat.Click image for larger version.
    2002 Discovery td5
  13. #10
    Oct 2014
    Thanked: 19
  14. #11
    Oct 2014
    Thanked: 19
    What make of battery in your picture
  15. #12
    Jan 2015
    Thanked: 207
    Lifepo4 cells with box home made to fit behind the Cruisers backseat. This is only a testpack/prototype I slapped together. Once the rattletest is done and passed, the first production set will be built, but without battery poles but rather with Anderson plugs as well as a digital battery monitor.
    Quote Originally Posted by nevillet View Post
    2002 Discovery td5
  16. #13
    Thanked: 12
    Hi BruceHun,
    Do you perhaps have images of the SunSol-E battery installed and feedback?
  17. #14
    Plett/Paulshof
    Thanked: 1217
    I will take pics and post.BL installed it for me. All i can say so far is that it is a brilliant battery. Check under BL mods.
  18. #15
    Feb 2018
    Thanked: 1431
    I can't help but go back to this little saying from my days in the army "two is one and one is none" quite often having a redundancy plan is of more value than efficiency.
  19. The Following User Says Thank You to River Rat For This Useful Post:
  20. #16
    Plett/Paulshof
    Thanked: 1217
    I do travel with a blue nova 82ah in my battery box as well as my car has a second battery.
    same can go for battery charger, water pump, mppt etc. do you carry those as spare as they are also only one?
  21. #17
    Feb 2018
    Thanked: 1431
    I have a Flexopower 444 as my back up which has battery charger and MPPT built in, I am thinking about a water pump but the Fortuner only has 70k on the clock.
  22. #18
    Plett/Paulshof
    Thanked: 1217
    Similar to me. I meant water pump for camping trailer though.
  23. #19
    Feb 2018
    Thanked: 1431
    Sorry I made the assumption on the water pump but it seems that we agree on the principle. If there's a potential fatal flaw in your set up think of a back up plan.
  24. The Following User Says Thank You to River Rat For This Useful Post:
  25. #20
    Plett/Paulshof
    Thanked: 1217
    Quote Originally Posted by Byroness View Post
    Hi BruceHun,
    See below;
  26. The Following User Says Thank You to BruceHun For This Useful Post:
