Conqueror Comfort - Questions
Results 1 to 10 of 10
    Oct 2017
    Rustenburg
    Thanked: 4403
    Default Conqueror Comfort - Questions
    I traded my Commander for a Comfort and I need a bit of advice from long time owners:
    1. What do you do with the tent cover bag, after opening the tent so that it does not interfere with the awning or blow around and girts girts on the tent?
    2. What do you do with the loose cover straps so that they are not in your way while you camp?
    3. What do you do to make the fold away process of the tent into the tent cover a bit easier?
    The trailer and tent set up easy, and even the the fold up is not that bad, but, I set up and break camp on my own, and would appreciate some help to make things a little easier.
    Andrew van Staden
    Oct 2017
    Rustenburg
    Thanked: 4403
    Default Re: Conqueror Comfort - Questions
    Probably should have included a Trumpism in the heading..
    Andrew van Staden
    Thanked: 315
    Nobody can believe that you traded your Commander for a comfort?!?
    Francois
    Oct 2017
    Rustenburg
    Thanked: 4403
    Quote Originally Posted by Francois111 View Post
    My Comfort, sets up faster has a bar, and has more usable space , it also has a bigger kitchen, more packing space, a bar, tows better, and has a bar.. Oh and it tows better. It can also take a bigger fridge..
    Wait, did I mention the bar?
    But most importantly it is water tight.
    My Commander was old, did lots of dirt and off - road work and was a bit leaky.
    Ok, not a bit...
    Andrew van Staden
    Thanked: 315
    Did you mention the bar in the comfort?
    Wish you many happy camping trips in your new comfort.
    Francois
  6. The Following User Says Thank You to Francois111 For This Useful Post:
    Ruimsig
    Thanked: 15168
    was a bit leaky.
    Ok, not a bit...
    Come on, it wasnt that bad
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Plett/Paulshof
    Thanked: 1218
    So he traded a jacuzzi for a bar?
    Congrats Andrew
    Bruce Hunter. 2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  9. The Following 2 Users Say Thank You to BruceHun For This Useful Post:
    Thanked: 340
    1. Fold it in a V, roll it up and place it in the space provided above the bar... length of the trailer. Except if you have a comfort with the awning that lifts out from that space...
    2. I place the straps in that same area as the tent cover. Straps from front I place underneath the tent, where the table goes.
    3. The tent alone does fold away easily. I also fold my L-shape awning with it (keep attached), then pack 3 groundsheets, the add-a-room, a small table and a mattress for one stretcher under the cover also. Made the cover 70mm taller to fit it all though. Before I made the cover bigger, the groundsheets and the awning also fitted below.
    Enjoy the trailer. We enjoy ours.
  11. The Following User Says Thank You to Bassfisher For This Useful Post:
  12. #9
    Oct 2017
    Rustenburg
    Thanked: 4403
    Thanks Bassfisher. Some good advice about the v-shape rolling up of the cover. I will try it, I do have the quick awning that folds out and lifts up though.
    I think my bag (tent cover bag) might be the problem. I think it is too small. It is a mission to get closed, even just with the tent.
    Andrew van Staden
  13. #10
    Nov 2019
    Thanked: 20
    Yes, I use the same approach as Bassfisher on the cover and straps. Also had my cover extended with 50/70mm to allow more packing space.
    Another tip:
    When we are staying longer than 3 nights we like to use the 7x7 sheet. To speed up the setup we've halved the number of poles required by installing an extendable pole in the middle section. Therefor only 8 poles required VS 16. It work perfect and there is more space. See pictures. Click image for larger version.
ID:	593697Click image for larger version.
