Mattress for caravan
Results 1 to 18 of 18
    Jhb
    Thanked: 44
    Default Mattress for caravan
    Morning all
    I'm looking for a company where I can ge a custom mattress made up for my BushLapa
    Any recommendations in the Gauteng area?
    Bruce
    2010 Toyota Hilux 4x4 3.0D4D
    Bushlapa Miskruier BL15
    Jan 2010
    Thanked: 5003
    Default Re: Mattress for caravan
    I had the mattrass for the side bed re-made by the Foam Factory in Centurion.
    https://www.foamfactory.co.za/
    The foam is good quality and I am very happy with that. You have to supply your own fabric for the cover and they make the cover. The sewing workmanship was not too great.
    If I had to do it again, I will rather ask BL to custom make me one.
    Christa
    Jhb
    Thanked: 44
    thanks
    Bruce
    Jun 2018
    Thanked: 13
    MyFo Edenvale do really good work.
    I have used them for a new TTT mattress and a couple other items.
    Good advice and reasonable as well.
    Hilux 2.8 D/C 4X4 AT
    Jun 2008
    Terenure, Kemptonpark
    Thanked: 148
    Or phone Byrone, he manufactures matrasses. His shop is in Alberton
  6. The Following User Says Thank You to LouisXander For This Useful Post:
    Thanked: 1831
    We had one made by Comet Caravans in Boksburg (not sure who they outsourced it to). Mattress was made to our specific size requirements (tapered not a square mattress)
    Anton Muller
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Jhb
    Thanked: 44
    thanks for all the advice
    I'm also looking for some suggestions on the mattress makeup. Most people seem to make up a multi-layer mattress with foam of various densities / hardness.
    Any recommendations on "recipes" that work?
    Bruce
    Wartburg
    Thanked: 1930
    We had one made up locally in Pmb - 150mm high density foam with a 50mm layer of memory foam on top. It is extremely comfortable.
    Mike Lauterbach
    Jan 2010
    Thanked: 5003
    [QUOTE=out of africa;4504304...I'm also looking for some suggestions on the mattress makeup. Most people seem to make up a multi-layer mattress with foam of various densities / hardness.
    [/QUOTE]
    Well that is really personal preference. The new one I had made is thicker than the standard BL mattrass and it has a thick layer of very high density foam at the bottom and a thinner layer of less dense foam on top, IIRC about 6 cm.
    At the foam factory they have samples of all the densities and you can touch and compress them. The quality of their foam is excellent. They did however advise me not to put a layer of memory foam on top. I am not a fan of memory foam at the best of times though.
    Sorry not sure what went wrong with the quoting.
    Christa
    Jun 2018
    Thanked: 13
    We had once made up locally in Pmb - 150mm high density foam with a 50mm layer of memory foam on top. It is extremely comfortable.
    Definitely!
    Used the same combo and can attest to the great comfort level.
  12. #11
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 1382
    Hi Tech Foam have made all shapes and sizes for me over 30 years.
    All top notch, covers of your choice.
    Chamdor.
    Ford Figo 2016
  13. #12
    Howick
    Thanked: 64
    Hi Mike, who did you use in Pmb? I need to get a new mattress made up for the second bed in the Cougar as it is quite a bit thinner than the big bed.
    Thanks in advance, Jason
    2018 Ford Everest 3.2 Limited
  14. #13
    Nov 2008
    Thanked: 117
    I have just ordered a no-turn pocket spring bamboo with the memory foam overlay, but they have many types that will suite just about everyone and made to size - DM Supplies in Primrose.
    Simplicity is the ultimate sophistication.
    - Leonardo Da Vinci
    Also on
  15. #14
    Jhb
    Thanked: 44
    thanks everyone
    Bruce
  16. #15
    Helderkruin
    Thanked: 479
    Strantfoam is in Chamdor enige tipe spons en sny wat jy soek.
    Ek al my kamp beddens se matrasse daar laat op maak en is baie goeie kwaliteit.
    En dan laat ek dit oor trek by Amir hy maak weer tent seile en enige iets vir kamp hys daar op Ontdekkers in Krugersdorp.
    Quote Originally Posted by out of africa View Post
  17. #16
    May 2007
    Welgelegen, Cape Town
    Thanked: 191
    We just put a eggshell matress ontop of our Bushlapa mattress, like sleaping on a new Seally!
    Toyota D4D Legend 45
    Triton Clubcab 2x4 2.5 DID
    Bushlapa Vlooi 652
  18. #17
    Okahandja, Windhoek
    Thanked: 949
    Multi layer foam is usually more comfortable. At the bottom a high density with a low density, memory-foam or eggshell on top. Ideally ask them to make samples of each combination and thicknesses, and feel it. And a 150mm mattress will be more comfortable then a 100mm or 75mm .
    Johan Kriel
  19. The Following User Says Thank You to JLK For This Useful Post:
  20. #18
    Jhb
    Thanked: 44
    thanks everyone
    Got a quote from Bushlapa and a few prices from the suppliers mentioned in the post. Surprisingly Bushlapa is 30% cheaper than the next cheapest price.
    Bruce
  21. The Following User Says Thank You to out of africa For This Useful Post:
