Defender Clutch issue
Results 1 to 8 of 8
Thread: Clutch issue
    Default Clutch issue
    Hi guys. I have a 1996 300Tdi with 340 000km. About two months ago the clutch failed, so I replaced clutch master and slave, bled the system and all was good again.
    Now something has gone wrong. Again I canít engage any gears with the engine running, but if I engage first with the engine off, then start it, the clutch works like normal.
    Iíve changed the master cylinder again but still the same problem. Any ideas? Could it be the slave? Surely not the clutch or pressure plate??
    Neville du Plessis
    Defender 110 Tdi
    Nov 2011
    Langebaanweg
    Thanked: 1357
    Default Re: Clutch issue
    There's only 2 things left, I would take the easiest one first: change the slave.
    Opinion 2 is a well known issue, the fork tend to fail where the fork hinges. A common fix is to weld a piece of flat bar on the engine side of the fork.
    Thanked: 16371
    4 things to check
    1) clutch engagement adjustment rod on brake master cylinder
    2) slave has failed again (Britpart?)
    3) as mentioned, the fooking fork
    4) yes, the pressure plate has died
    Jakes Louw
  4. The Following User Says Thank You to jelo For This Useful Post:
    Thanked: 582
    Like this
    Defender Kalahari
    Series 3 SWB
    Series 1 De Luxe Cab Pickup
    Series 1 Station Wagon 88''
    Thanked: 32
    Quote Originally Posted by imgreg View Post
    Like this
    Yipe, had these wear right through
    30 years experience and knowledge certainly out weighs a 5min keyboard bashing on google
    Love's electrickery stuff and problems related to it as long as it dont go bang cos then its f......
    NO REPLACEMENT FOR DISPLACEMENT
    A V8 is where thunder is made
    100%WEE
    Nov 2011
    Langebaanweg
    Thanked: 1357
    Mmmm....
    Saw a wet spot under the Kalahari. This is something I'm not used to.
    On the V8 it was ops normal.
    So I go looking.
    Found a crystal clear drop hanging on the "brace" connecting engine and bell housing, just under the slave cylinder.
    Smells like brake fluid.
    With a trip around December, I think I'll have to replace it before something spoils my trip.
    Thanked: 582
    Reminds me of a trip a few years back.
    We left P.E. at 4am heading north. I get to about 50km from Cradock.
    "SOMETHING" tells me to start shuffling my feet towards the clutch pedal
    Mmm cant find the pedal, its missing and on the floor, so without the wife smelling a rat, i fiddle with the radio to tune a better station.
    Then we start climbing to Cradock on the passes. I need to change to 4th, decide to do a rev clutch change, all goes well.
    But when i need to change again wife asks Mmmm something wrong
    Yes, i have had no clutch for 30km
    Pulled into Cradock at first light.
    Fiddled and found master cylinder reservoir EMPTY.
    Topped it up and pumped a few times and got clutch again.
    Carried on to Upington. Got a refurb kit, LUCKILY at a small workshop, reworked and all good for that trip.
    Replaced when we got home with a new one.
    Defender Kalahari
    Series 3 SWB
  9. The Following User Says Thank You to imgreg For This Useful Post:
    jfh
    Nov 2011
    Langebaanweg
    Thanked: 1357
    Nope.
    Pulled the slave and it was dry.
    Checked the breather and it was open. Just a pain to get the brass washers back on when fitting.
    Checked gearbox oil level and it came dripping out, so oil level is okay.
    After I tested the winch I noticed a spot.
    So the clutch wasn't used and it's dry.
    The gearbox was in neutral.
    So my conclusion is that it's engine oil.
    As I never had a great sense of smell, I had a volunteer to help.
    Between the suspect oil, hydraulic oil, engine oil and gearbox oil we couldn't pinpoint it. In fact he got all wine connoisseur on me explaining the smells in detail.
    But I'm fairly certain that it's enige oil. It'll have to wait until I open that part one day, most probably to replace the clutch.
