Patrol 3.0Tdi
Results 1 to 7 of 7
Thread: Patrol 3.0Tdi
    Jan 2009
    JHB
    Default Patrol 3.0Tdi
    What are your views on the above vehicle?? Is the 3.0 strong enough for that size vehicle?!
    Jun 2008
    Bethal
    Have a look at the following sites:
    http://www.patrol4x4.com/forum/
    http://www.outerlimits4x4.com/forum5.php
    The sites are not SA, but will give you an indication. The earlier models of the 3.0Tdi was nicknamed "handgrenade" because they used to "blow up".
    Their output (kW and Nm) is higher than the 4.2d, but there are reliability issues.
    2007 Nissan Patrol 4.8 GRX
    Jurgens Exclusive
    MTUNZINI
    Thanked: 464
    Hi , i have owned a 4.2D and now currently a 3.0 d.
    The pre 2003 models had an issue regarding overfueling and burning the pistons with extreme cost to repair, BUT the 3.0d vs the 4.2 d
    • A much better overall vehicle, cruisers well on open road.More powerfull and no problem with the big body
    • Tows much much better than 4.2 D , much more torque. If you tow a trailer or caravan only one choice 3.0 D
    • Keeps it speed uphill and on highveld, 4.2 gutless, gets no where fast.
    • No turbo lag to complain about
    • 4.2D have a temp. issue on a hot day , runs too hot, all of them but it seems not to worry the bullet proof engine
    • 4.2D is actually just a motor for real off road work , 3.0d for general purpose and open road
    • Compsumption , 3.0 D a little better , both are diesel guzzlers. Between 6 to 9.0 km/l
    I personally prefer the my 3.0d above the 4.2 d as stipulated, the only reason the 4.2 d frustates anybody , including the cruiser 4.2d if you travel long distances .Both dont tow well.
    Very important fit an EGT gauge , and the 3.0d will last for ever , have done 175000km . My 4.2 D 286000km .
    My 2c worth, yes its got more than enough grunt!!!!
    Bothasig
    Thanked: 14
    The 3.0l is more than strong enough to cruise comfortably on the open road with enough torque when you need it.
    It is a TD so the appropriate care needs to be taken. (EGT & overfueling as stated above)
    Excellent vehicle overall!
    '02 Patrol 3.0Di GL
    Jan 2009
    Thanked: 47
    I test drove one a while ago. I have a 3.0 td hardbody, and couldnt believe its the same engine. The patrol pulled away nicely, sat on the road well, both tar and dirt, and feels like its got plenty of power for anything. I didnt tow but think it would be up to the extra drag.
    MTUNZINI
    Thanked: 464
    I dont know if its the same motor shared by hardbody and Patrol. I have heard its different, the Patrol zd 30 is a French designed engine , and have a longer stroke ect and more power .
    i'm not 100% sure , maybe somebody out there knows.
    Rocky Guest
    Fugi Welcome here
    Are you done with MX bikes now ?
    The patrols are great
  1. Which one will you buy Patrol or Land cruiser???
    By A.J. in forum Vehicle & Technical Chat - General
    Last Post: 2015/11/30, 04:29 AM
  2. Nissan Patrol 60th Birthday Celebration
    By Herrie in forum Nissan
    Last Post: 2011/09/14, 02:38 PM
  3. Pathfinder or Patrol??
    By TheNatureBum in forum Nissan
    Last Post: 2011/04/05, 03:32 PM
  4. SFA LDV comparison: Cruiser vs patrol vs Defender
    By Engel in forum Vehicle & Technical Chat - General
    Last Post: 2010/05/25, 01:05 AM
  5. Patrol VS LC GX
    By Henris in forum Vehicle & Technical Chat - General
    Last Post: 2009/10/25, 12:53 PM
