High lift jacking points on a L/C 76 Series?
Results 1 to 11 of 11
    Mar 2014
    Harare
    Default High lift jacking points on a L/C 76 Series?
    Hi,
    Any suggestions how to create high lift jacking points on a Landcruiser 76 Series, without fitting a bull bar and rear bumper replacement?
    Thanks in advance.
Name:	76 SERIES.jpg
    Thanked: 4348
    Default Re: High lift jacking points on a L/C 76 Series?
    Have a look at the two websites below. I think a Hi-lift Jack Wheel Buddy might be the solution you are seeking. For changing tyres you might need to carry a stand to place under the chassis once jacked up. I have modified bumpers and the buddy as well. Most 4x4 outlets in SA have in stock or can get.
    https://www.outdoorwarehouse.co.za/p...lift-lift-mate
    https://www.4x4community.co.za/forum...strap-good-bad
    Stanley Weakley.
    Toyota Landcruiser 76SW 4,2L diesel.
    “Great journeys are memorable not so much for what you saw, but for where you camped”.
    Trans East Africa 2015/2016 Trip report https://www.4x4community.co.za/forum...-6-SLOW-DONKEY
    OR
    http://www.4x4community.co.za/forum/...e16?highlight= from post 315.
    Thanked: 3213
    Stofpad rock sliders.
    Little Falls, Roodepoort
    Thanked: 38
    + 1. What GRIPS said.
    Jannie Botha
    2008 Fortuner D4D 4x4
    Mar 2014
    Harare
    Thumbs up Re: High lift jacking points on a L/C 76 Series?
    Quote Originally Posted by Stan Weakley View Post
    Stan, thanks for the useful advice and links. I agree a Wheel Buddy is a solution for most recovery situations. The exception is when the tyre must be changed in challenging terrain, where a stand makes sense.
    Appreciated.
  6. The Following User Says Thank You to Mr Big Sky For This Useful Post:
    Mar 2014
    Harare
    Rock sliders with jacking points also make sense. Thanks for this.
    Apr 2017
    PUMULA
    Thanked: 329
    While you are checking, double check those bolts on the towbar and bullbar.
    Please check your tow-bars.
    My high-lift points are fitted on the bullbar and towbar. 90% of the time, you only need it on the front or back.
    You do get a strap for the wheels, I did not bother.
    Current off-road vehicles: *** Great family accommodation. See Facebook, Google maps and airbnb. Wild Wind Ranch/Mkulu Kei
    * 1975/8 SHREK Land-Cruiser FJ40 DIESEL P/U, BFG 31x10.5 muds. 2 x 1.6 ton tirfor winchs
    * 1994 Land-Cruiser J70 DIESEL P/U, my truck recovery vehicle. 15000 warn winch. And 3.5ton tirfor winch. Back full of appropriate sized recovery gear. BFG31x10.5 muds
    * 2014 Land-Cruiser LX V8 76 DIESEL STATION WAGON, BFG's 285 all terrain.
    * 2011 Isuzu bakkie 4x4
    * 4x4 trailer, 1987, BFG all terrain and a GSA 1200 BMW ADVENTURE LC 2018, the closest motorbike to a land cruiser
    * A Massey Fergusson 375 tractor. Not BFG's and not a 4x4
    * John Deere E140 2020 tractor (mower).
    * Mercedes Unimog U416
    Thanked: 1241
    Quote Originally Posted by Mr Big Sky View Post
    Before you trust these socket-type jacking points, I humbly ask that you test them first.
    I did once, and it didn't work for me, and in hindsight, it is quite clear to me that it pretty much can't work. Hear me out:
    When you jack a car up on the side, it will roll away from the jack. Since the pin is rigidly bolted to the jack, the foot-plate of the jack must slip on the ground, away from the car, which it may or may not be able to do, depending on the condition of the ground. I almost want to say that you are in a better situation than if it does slip, because what will happen is that the jack will bind up.
    If on the other hand the jack does slip on the ground, you can keep jacking up. However, when you want to lower the car, the jack's foot plate must now slip back toward the car, and since it is at an angle, the foot plate WILL dig in and cannot slip back. You are now stuck more effectively than you were before.
    Having said that, it will be less of a problem on a car with limited articulation. So maybe it can work better on a 79 with it's relatively hard suspension than was the case for me.
    Now having said all this, I firmly believe the safest place to use a hi-lift jack on a heavy vehicle is to jack it under the rock-slider, but get one that doesn't require the pin adapter.
    Thanked: 3213
    Peter I do share your sentiment around socket and pin recovery points.
    You do however get pins that can swivel that sort your concerns
  11. The Following User Says Thank You to grips For This Useful Post:
    Thanked: 1241
    Jip.
    I had one of those slip out on me once... I guess one can fix that problem with a hole and an R-clip, but to my mind it's just easier to make the rock slider such that one can just jack directly under it.
  13. #11
    Thanked: 3213
    Peter with the Stofpad sliders you are safe to jack under them. Uys did quite a sturdy design. When I installed mine I tested them lifting the Cruisers with a trolley jack.
  14. The Following User Says Thank You to grips For This Useful Post:
