Page 3 of 3 FirstFirst 1 2 3
Results 41 to 46 of 46
    Garsfontein
    Thanked: 6540
    Default Re: M-73 Compass
    I just collected my Mk III donor compass from PostNet. So perhaps I'll get the restoration of the Mk 3A finished over the weekend.
    As I said in an earlier post - it's in rather shoddy shape. But that is fine - I am only after the compass card and grub screw - and they both look good. Those are the only parts I need from this one.
    I will however, keep the leftovers in case I run into another Mk III again. I'd actually rather like to have a Mk III in my collection.
    Peter - as you can see, the cover for the prism assembly is there as well as the screws. I'll see whether it fits on the M-73 when I strip it down this evening. I've got no idea how interchangeable parts are. Although they look very similar in terms of style and size etc, they are completely different models with about 40 years in between their "development". I say "development" because although the M-73 was introduced in 1973, they still manufacture them today. The Mk III was introduced in 1932 and production stopped sometime during, or just after the war years.
    Strangely enough though, and this is what makes these compasses so confusing, is that the Mk 1 compass was introduced in 1966. This was a Mk III compass but converted to Mils. The differences in the Mk numbers and dates depend on whether they're roman or normal numbers. The Mk 3A is a bit of outlier in this regard - originally designated the Mk IIIAUST, it was shortened to Mk 3A.
    Anyways, all these compasses were then superseded the M-71, M-72, M-73 and later the M-88, the last two being the only models still in production.
    If the prism cover / screws do not fit, I believe I will be able to find spares for you. Spares are quite readily available for them.
    Ian de Villiers
    Patrol 4.5 GRX
    Jurgens XT65 2x0 with Super Select Zero
    ORRA: H80
  2. The Following 3 Users Say Thank You to iandvl For This Useful Post:
  3. #42
    Thanked: 4886
    Thanks Ian
  4. #43
    Garsfontein
    Thanked: 6540
    Right, so more worky worky this weekend, but I am almost done now. After disassembling the donor compass, I decided to bastardise my restoration and use the Mk III compass card holder / oil well in the Mk 3A. Yes - this means it is no longer a Mk3A, but I was just impressed with the quality and condition of the oil well internals as opposed to the Mk 3A one. So I cleaned it up, did my doctoring with glow in the dark stuff and sealant and started filling it.
    There is still a bubble in the oil. I'll remove it when I have time. I did not want to fill the oil well too much as I was not sure in what condition the gaskets were in. So I first wanted to check whether they gaskets help up.
    Two things left to do.
    1: I've got to tap a thread where I had to drill out one of the prism cover screws when I disassembled the thing a few weeks ago.
    2: There is a design difference between the Mk III and Mk 3A in terms of the bezel grub screw. On the Mk3 A, the screw is internal to the compass and sticks out the side. The grub screw screws onto this. On the Mk III, the grub screw is machined with a thread which screws into the compass. In short, the grub screw will not work as it. I have ground away the grub screw thread, and will drill a suitable hole for it when I can. No idea where I am going to find a suitable tap for that, but I'll worry about that when I get there.
    Some photos. Note that I had not refitted the prism cover or the crystal guard in the photo where it is open.
    Edit: Oh - I forgot. There is a third thing I need to do. Francis Barker compasses have a rubber ring on the base. The restored one is missing this. I will need to source some suitable rubber, cut this to size and stick it on.
    Ian de Villiers
    Patrol 4.5 GRX
    ORRA: H80
  5. The Following 2 Users Say Thank You to iandvl For This Useful Post:
  6. #44
    Garsfontein
    Thanked: 6540
    A serious gem on the way... Hopefully...
    Also, mods: please change the title to: my compass thread
    Ian de Villiers
    Patrol 4.5 GRX
    ORRA: H80
  7. #45
    Garsfontein
    Thanked: 6540
    Default Re: My Compass Thread
    Right... So a new item is currently finding its way to me via courier.
    This is quite a gem, as I said earlier.
    It's an Aston & Mander compass. Aston & Mander generally manufactured draughting-related equipment, slide rules, navigation-related stuff, although they also manufactured some precision equipment - such as the compass I've just ordered.
    It's a 1908 pocket / hunter compass. Case is nickel-plated brass. And something very interesting is that it has a Singer compass card. It is called a Singer compass card as it was designed by a Master Mariner - Samuel Singer. What made it unique was that he patented the design in 1861. It was valid for seven years and expired in 1868. Older variations of the Singer card will include the term "Singer Patented" on the actual card. The reason for the design of the card was because, being before the dates of "glow in the dark" type technology, he designed it with the purpose of being easier to see in the dark - with the Northern section of the card being in black and the Southern side white.
    The lyre at due North on the compass card is a reference to the star, "Vega" - also known as "Lyra" and "the harp star". During the 1800's there were seven primary stars used for navigation, and Vega was one of those. Mariners apparently referred to it as the "Lucky Star".
    In the photos, you will also clearly see the gem / crystal used for the pivot of the compass card. Whilst the F Barker compasses also use a crystal for this purpose, one cannot really see it without removing the compass card from the compass.
    The condition appears to be pretty good and it even has its original bag / cover. It is missing the loop which is supposed to be on the knob at the top and there appears to be a bit of water damage to the compass card - which is not surprising considering its age. These compass cards were hand-painted, so I'm not going to do any restoration of this item when I receive it. It is just for the collection.
    Pretty excited about this one. Some photos of the item. I'll post more when I receive it.
    Ian de Villiers
    Patrol 4.5 GRX
    ORRA: H80
  8. The Following 3 Users Say Thank You to iandvl For This Useful Post:
  9. #46
    Garsfontein
    Thanked: 6540
    So the item has arrived. Since I am more used to the bulkier military-spec compasses, I find it surprisingly small. It's super pretty though.
    Apart from the stained compass card on the Southern side, it is in absolutely mint condition. I presume some of this is because it is still in it's original chamois baggie thing.
    Despite not being dampened (ie: it is a "dry" compass) the mechanism is smooth and there are no "clunks" if you shake it slightly. If you try shaking a cheap "dry" compass you will know what I mean when I mention this.
    The compass card will roll true at even strange angles - albeit not as impressive as a mil-spec one in terms of this. It is surprisingly forgiving in terms of the angle it is being held at.
    Pity about the stain on the compass card, but I am not going to attempt any restoration on this piece. As I mentioned, it has a hand-painted compass card. Any attempt at restoring it will be an injustice and, considering its age (116 years old), some "damage" is to be expected. it is a nice complement to my collection and I am happy.
    Ian de Villiers
    Patrol 4.5 GRX
    ORRA: H80
  10. The Following 3 Users Say Thank You to iandvl For This Useful Post:
