Results 1 to 20 of 28
    Default Moisture resistant MDF (MR MDF) board suppliers?
    Hi all,
    Anyone know of anyone that supplies moisture resistant MDF boards (MR MDF) (Supawood) in the Gauteng area?
    I have tried a number of board suppliers, but none of them have the MR type (which is slightly green in colour). All of them only supply standard MDF.
    Looking for 12mm thickness.
    Thanks! Morne
  2. The Following User Says Thank You to mornesm For This Useful Post:
    Thanked: 20097
    Default Re: Moisture resistant MDF (MR MDF) board suppliers?
    Not really going to help but I'd rather consider marine ply.
    Jakes Louw
    Mar 2012
    Ballito
    Thanked: 724
    What about that synthetic plywood stuff? Can't remember what it's called? The stuff VW use for the flooring of their panel vans.
    Apparently more waterproof than mild steel?
    Actually, now that I think of it, I'd like a sheet of that myself, if I can find a supplier (and if I can afford it )
    ZS5CMA
    His: '17 Hilux GD-6 4x4 A/T ~135000km
    Hers: '19 Mitsu Eclipse Cross ~ 35000km
    Semi-retired: '12 Polo BlueMotion ~350000km
    Burned to a crisp: '05 WJ 2.7CRD
    https://www.instagram.com/fstopza/
    Mar 2012
    Thanked: 1676
    I have to ask why you want that stuff?
    I have to agree with Jelo Plywood is the way to go
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    4.0 XJ Jeep Cherokee - Sold
    JHB
    Thanked: 291
    https://maizeyarchitectural.co.za/pr...vc-foam-board/
    Don't know what you are planning to use it for but consider this.
    Someone wrote about it a few months ago apropos a drawer system.
    Finally tracked it down and it looks like a nice material to build drawers out of.
    Very light as well
    Mar 2012
    Ballito
    Thanked: 724
    Quote Originally Posted by Woolf View Post
    Very light as well
    How rigid is that stuff? Stiff like plywood or not? I was under the impression that it was pretty flexible?
    ZS5CMA
    Thanked: 561
    Im under the impression that we dont know what the board is or its texture, rigidity is. Ill admit I dont know.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
    JHB
    Thanked: 291
    Very rigid The sample I got could not be bent.
    Leroy Merlin sell a PVC board but the inside is very foamy and it can be bent.
    This stuff has a very rigid inside. FWIW I put a screw into the core from the side and was not able to dislodge it although I'm sure with enough force that is possible
    12mm sheet 2440x1220 is R971 ex VAT
ID:	592000   Click image for larger version.
  10. The Following 2 Users Say Thank You to Woolf For This Useful Post:
    In my search for a supplier of MR MDF, I also came across die product called PVC Foamboard at Davidsons Boards.
    I have never seen or really heard about it before until now. I have no idea though if it has similar characteristics as MDF in terms of rigidity. I also have not had a first hand look at the actual product.
    The reason why I was looking at MR MDF in stead of marine ply, is because of the finish that I want to achieve after painting, etc. I think MDF will require much less finishing after cutting, etc.
    A week or so back I was actually considering the PVC Foamboard, but I have to be honest I have no idea what to use in terms of adhesives, and if it will hold screws. Obviously wood glue won't work with that...
    Price of the PVC was more or less on par with a sheet of marine ply.
    Thanked: 561
    I see Leyroy Merlin has 15mm Mr MDF advertised.
    Board MDF Moisture Resistant 15mm thick-2500x1250mm
    Fortuner D4D
    Sp Tourer
  13. #11
    Thanks - It's listed on their website, but not in stock.
  14. #12
    Thanked: 561
    Thats not very nice of them.
    Fortuner D4D
    Sp Tourer
  15. #13
    JHB
    Thanked: 291
    Quote Originally Posted by mornesm View Post
    Maizey has a glue for it. Forgotten its name though.
  16. #14
    Dec 2014
    Thanked: 3514
    Look at OSB, Oriented Strand Board.
    Cheers,
    John Kilfoil
    'People who believe the vaccination will alter their DNA should probably consider it an opportunity"
    Rover P6
    Range Rover P38 HSE -- Sold
    Moto Guzzi LeMans
    Aprilia Tuono V2
  17. #15
    Oct 2020
    I went to the little falls branch today and they had a few sheets of 15mm MRMDF in the yard, the same ones listed on their website. They also had some 'planks'.
    I am also looking for some, 19mm and 6mm for painted cabinet doors. I see Leroy Merlin has valchromat MDF, I looked it up and it's a coloured moisture resistant MDF from the looks of it, costs a lot more than the MRMDF though.
    Not sure what your project requirements are, but I'm keen to make cabinet faces that will not develop paint cracks, and that will not puff up if they get wet.
  18. The Following User Says Thank You to DanielMessem For This Useful Post:
  19. #16
    Quote Originally Posted by DanielMessem View Post
    Thanks - When I phoned, they said that they did not have stock. It seems like MR MDF is not in high demand locally...
    Unfortunately I need 12mm.
  20. #17
    Aug 2020
    Thanked: 100
    I was told by Chipbase that thereís a shortage of 12mm MDF. Stock only in January
  21. #18
    Quote Originally Posted by XJ Junky View Post
    Same with steel it seems... Quite limited stock available.
  22. #19
    Back to the PVC Foamboard option - Has anyone had any experience working with these boards? Is it possible to use router on these for round over, grooves, etc?
  23. #20
    Aug 2020
    Thanked: 100
    I just bought some 12mm MDF at Donaldsons, but itís a Cape Branch.
    5 day waiting period for cutting & delivery (1 sheet)
