Results 1 to 20 of 29
    Richardsbay, KZN
    Thanked: 17187
    Default Stretcher legs/ feet tent floor protection
    As the title suggests, what do you use? I thought of cutting squares from a rubber car mat and plce them under the feet. The 10 year old will be sleeping on it so there is not much weight but I am still worried that the feet might damage the tent floor.
    Walker Evans, Photographer
    Planet of the Apes
    Thanked: 312
    Default Re: Stretcher legs/ feet tent floor protection
    Quote Originally Posted by Riaan van Wyk View Post
    Some Gorilla tape will also do the trick.
    Thanked: 464
    Hallo Riaan,
    I use a car rubber mat in conjunction with a piece of a foam mat below it. The car mat is still hard and it is possible that that will also "puncture" the tent if something hard/sharp is below it. The foam helps with that. I use the same under the ladder for the TTT.
    Jul 2017
    SSW
    Thanked: 571
    I saw someone cut a hole in tennis balls and then fit them over the feet. I think that should work well
    Triton 3.2 Auto 4x4
  5. The Following 3 Users Say Thank You to Die Uwe For This Useful Post:
    Thanked: 464
    Quote Originally Posted by jooste777 View Post
    I did this to telescopic poles which I use on the awning when it rains, to lift the areas where water accumulates on the awning. Works well
    Nov 2019
    I use little squares cut from an old carpet, one of those carpet tiles. Works a treat.
  8. The Following User Says Thank You to kang For This Useful Post:
    Thanked: 1468
    We use these
    https://www.takealot.com/10-piece-ev...E&gclsrc=aw.ds
    You just need to stick the middle of the numbers in place otherwise they fall all over the place. We look a bit odd being a 2 30 year olds with no kids traveling with our number mats but they are half the price of a plain black set.
    It does create some confusion when I bat my eyelids and ask if we can practice our multiplication
  10. The Following User Says Thank You to Half-Pint For This Useful Post:
  11. #8
    Jan 2014
    Thanked: 170
    Quote Originally Posted by Half-Pint View Post
    We use these
    Ground sheet under the tent will be the best option, together with a bit of a chicken run of the camp site before to remove stones . Keep the stones from touching the tent bottom.
  12. #9
    May 2016
    Thanked: 3996
    The problem is that the feet tend to move off the protection.
    Cut 100 x 100, 25mm thick pine squares.
    Drill a 40 / 50mm hole, 10 mm deep, with a Forstner bit.
    It you have a router, round the edges.
    The feet should centre in the hole, and not move off it.
    2006 VW Touareg V10 (Sold)
  13. #10
    Richardsbay, KZN
    Thanked: 17187
    Quote Originally Posted by kang View Post
    Thanks, I think I have some carpeting in the garage to cut some of those.
  14. #11
    Robertson/ Larissa, Greece
    Thanked: 4859
    My wife made some "socks" for the feet from a thickish fabric. Works well
  15. #12
    Rangeview Krugersdorp
    Thanked: 1597
    Small square of plywood with male velcro glued on both sides.
    Ford Figo 2016
  16. #13
    Aug 2018
    Thanked: 242
    I bought some "rail ends" from Builders, the big ones. They look like the plastic squares you get for the aluminum tube ends, just bigger. I think i got it in the curtain section.
    I was looking for the round ones you get for putting under chairs, but the square ends work really good.
    I was also considering peanut butter bottle lids. The edges keep the feet put, and they can slide within the cap and the cap can slide on the floor. So far so good for us.
    Barry Hall
    Land Cruiser 105
  17. #14
    Centurion + Others
    Thanked: 244
    Ive got firm foam rubber about 10mm thick
    BUT - the tennis ball is VERY ELEGANT - love that idea , a Bells for you
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
  18. The Following User Says Thank You to Capt Chaos For This Useful Post:
  19. #15
    Kuilsrivier
    Thanked: 175
    Quote Originally Posted by Mileage View Post
    Best of all!!!
  20. #16
    Nov 2011
    Mossel Bay
    Thanked: 425
    This has been an issue I have been contemplated with the RV3 Oz Tent. Now with the Bundutop it is no longer an immediate problem.
    The advice above mostly addresses the scuff/puncture issue from the inside. As long as one has the same pressure, even if the contact area is now soft, puncturing from outside/underside is still possible unless one spread the weight over a bigger area by using a piece of rigid material.
    Cobus
    Jimny
  21. #17
    Feb 2013
    Thanked: 1281
    As a budget solution caps from coffee bottles should also work well. If you use wood blocks or whatever, just be sure that it doesn't have sharp edges which can dig in to the tent floor.
    Tennis balls is a nice idea, but doesn't increase the serfice area by too much.
    "The problems we have today is because the guys who work for a living are outnumbered by those who vote for a living." - Magnus Heystek
  22. #18
    Dec 2016
    Thanked: 24
    Ek gebruik die groot square end caps. Stewig en geen skerp kante wat gate kan steek nie. Dalk dieselfde as wat BarryCH na werwys. Werk baie mooi.
    Hugo Burger
    Ranger 3.2
    Baobab 1796 "Boom Huis"
  23. The Following 3 Users Say Thank You to Hubu For This Useful Post:
  24. #19
    Jul 2013
    Thanked: 409
    Cheapest ,tear up a carboard box in lekker large squares. Dispose when you pack up.
    Or leave them inside the tent. No damage will result.
  25. #20
    Aug 2018
    Thanked: 242
    Quote Originally Posted by Hubu View Post
    Dit is einste daai, dankie Hubu
    Barry Hall
    Land Cruiser 105
