electricity question: extra connection after meter
Results 1 to 20 of 25
    Dec 2006
    Thanked: 7
    Default electricity question: extra connection after meter
    My house db board is quite far from my driveway entrance - guess about 100m. I'm busy fitting a gate and wondering if I could tap of the meter box, it's 5 meters from the gate. I'll add earth leakage as part of the install. Is this legal?
    I guess the down side is that if I go solar then I won't electrify the gate as the solar will be doen from the main db.
    thx
    Thanked: 15601
    Default Re: electricity question: extra connection after meter
    I'm no sparky but I doubt it.
    Jakes Louw
    Jan 2019
    White River
    Thanked: 27
    The meter box houses the suppliers metering equipment and the suppliers don't like consumers messing around in the meter box. I suggest that you install a waterproof db close to the meter box and split the power there.
    Ellisras
    Thanked: 714
    Those gate installations draw very little current. I would install a borehole cable all the way to the house and simply plug it in an existing house plug. Bonus if you have an external plug somewhere. I am also no registered sparky.....but I am sure that is legal.
    Rudolf Ras
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 851 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 111 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 124 000 km
    Apr 2014
    Richards Bay
    Thanked: 108
    Most gates I know of are run off a plug in the garage. Also no need for a coc if itís plugged in
    1985 Land Rover 110 - 300tdi conversion
    It's always more fun on the road less travelled
    Jan 2019
    White River
    Thanked: 27
    Gate motor is a fixed appliance and can only legally be plugged in if within 2 meters of plug.
    Thanked: 15601
    Aren't most gate motors running off 12v?
    Jakes Louw
    Jun 2012
    Thanked: 1582
    Quote Originally Posted by froggie View Post
    thx
    Solar panel, mounted next to the gate motor - you can buy kits that contain everything
    Probably be cheaper to install that a DB board or digging for a new cable
    First thing to pop up on google R600:
    https://www.electromannsa.com/produc...RoCNRMQAvD_BwE
    Anton Muller
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Malmesbury
    Thanked: 49
    Riaan
    Mahindra S10 DC Pikup
    GWM Steed DC 2.8 TCi - Dastek(Sold)
    Thanked: 94
    Yes 12 volt but charging the battery from 220v
    Jun 2012
    Thanked: 1582
    Quote Originally Posted by Louis J View Post
    bypass the charger and connect your solar setup directly to the battery. have done it for 2 gates here at work that see regular duty and still going strong almost a year later.
    Anton Muller
    2012 Q7 4.2 TDI
    Thanked: 94
    thx
    If you have a double sided meter box no problem, then you can install a earth leakage with a plug on your side of the box
    Aug 2017
    Thanked: 979
    Can install a solar charger that keeps the battery fed at the source, bypassing the whole 220v thing altogether.
    Thanked: 15601
    yes, was responding to this which I've never heard of:
    Quote Originally Posted by desdrake View Post
    Jakes Louw
    Jun 2007
    Pietermaritzburg
    Thanked: 163
    SANS 10142-1 Edition 3.
    A fixed appliance can be fed from an extension cable not more than 3 meters in length.
    Gen 4 Pajero GLX 3.2 DiD
    Forum Radio Licence 1037
    Mar 2012
    Ballito
    Thanked: 153
    Quote Originally Posted by Diversions View Post
    OK, but what if I replace the appliance cable with one > 3m in length? That's not an extension cable, it's the appliance cable.
    Chris
    ZS5CMA
    '17 Hilux 2.8GD-6 D/C 4x4 A/T
    https://www.instagram.com/fstopza/
  17. The Following User Says Thank You to cainslie For This Useful Post:
  18. #17
    Jun 2007
    Pietermaritzburg
    Thanked: 163
    Okay.
    I said extension cable so as not to cause confusion. In fact the Specification says you may not use flexible cords over 3 meters so it doesnt matter if its connected as an extension cable or "an appliance cable"
  19. The Following User Says Thank You to Diversions For This Useful Post:
  20. #18
    Thanked: 15601
    My water pressure compensation pump is 30m from the house........fed with a plug.
    Jakes Louw
  21. #19
    Jun 2012
    Thanked: 1582
    as is every gate motor installation I know of. Is this a new regulation?
    Anton Muller
    2012 Q7 4.2 TDI
  22. #20
    Paradise Beach
    Thanked: 47
    The way I understand the requirements, The 3m is a recommendation according to SANS. However if you exceed this length there are conditions that need to be met to make the installation legal.
