Results 1 to 2 of 2
    Sep 2020
    Default Daihatsu Gran Max (spares list )
    Daihatsu Gran Max 1.5 (2010)
    Uses Toyota 3SZ engine at agents quote avanza 1.5 import or townace or liteace
    Clutch
    use Valeo kit TY 67 or convert Valeo number to Luk number
    Air filter
    AG1759 or CA 12383
    Fanbelt
    6PK1580
    Plugs
    DCPR7EA-9
    Oxygen sensor
    Bosch 15730 R850 keep cap on, solder up wires use heat shrink tubing then remove cap when done.
    5th Gear
    33336 avanza R2100
    Tappet cover gasket
    discontinued at agents use Payen JM5149 or Victor Reinz 15-53121-01
    How to use Toyota part numbers
    On the schematic use that number eg:11213 is tappet gasket on any Toyota then add the vehicle series code eg: BZ060 or BZ080 or BZ010  then search google using the full number eg:11213BZ060
  2. The Following 2 Users Say Thank You to MadMax21 For This Useful Post:
    Thanked: 1966
    Default Re: Daihatsu Gran Max (spares list )
    Quote Originally Posted by MadMax21 View Post
    Clutch
    R1010 at Midas Centurion.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    083 399 2046
