Ford Ranger 3.2 auto
Results 1 to 2 of 2
    May 2015
    Table View
    Default Ford Ranger 3.2 auto
    Hi Guys,
    Need some technical assistance, my Ford Ranger is a 2017 facelift, intermittently but not frequently over the last 3-4 months the car would cut-out when i approached a stop position, actually while driving and slowing down to stop i notice that the car will lose power and when i applied the brake the car cuts off - i put the car back into "P" and start again easily. Two weeks ago i did this cut out twice in one morning, i took the car to battery center, they tested the battery and said it had some charge and suggested before i decide to replace the original battery i show take the car to my Ford dealer. I did it the same morning but they could not find on the computer any error code and suggest i leave the car with them so that they can do a proper battery check. After the check they phoned saying the battery is not holding the charge, so i decided to fit a new battery ( as mentioned the old battery was the original installed at the factory ). Sunday, September 27, 2020, near my home i could feel the same lose of power and as i pulled into my driveway and applied the brake the car cut out, as before put it into "P" as before the car started easily. This morning zero issues - has anyone experience this before.
    Oct 2017
    Rustenburg
    Thanked: 4107
    Default Re: Ford Ranger 3.2 auto
    Quote Originally Posted by Jose de Sousa View Post
    Hi Guys,
    You need to go and ask your money back from that Ford dealer. There is no way a diesel engine with an electronic fuel pump will die due to a faulty battery if the alternator is still working..
    I suggest letting them check the diesel filters, if they are ok then it is most probably either a diesel pump, DPF or Cat issue. It could also be a faulty MAF sensor
    Edit: It could also be your throttle regulator from the gearbox control module.... It could be many things, but it definitely cannot be your battery
    Andrew van Staden
