Results 1 to 7 of 7
Thread: Transom saver
    Jul 2010
    The Vale
    Thanked: 416
    Default Transom saver
    What is the general consensus wrt transom savers when towing. I am towing down to durbs , locally I normally just tilt the motor up and go.
    Ranger Wildtrak
    Ex Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
    Thanked: 2225
    Default Re: Transom saver
    Mechanically they work and reduce the cantilevered load but they scuff off all the paint where they mount on the lower unit. On a long trip I would fit one.
  3. The Following User Says Thank You to Andrew Leigh For This Useful Post:
    Jan 2020
    Thanked: 212
    I have a stay that fits onto cross member of trailer and has a mik on the other end so the leg of motor fits into. It has a spring in between to absorb any movement and then use a tie strap to keep motor in place. This will relieve any adverse torsion on transom and save later headaches. Have seen a couple of beautiful boats with cracked transom mounts, once repaired will never be the same. I wouldn't tempt fate.
  5. The Following 2 Users Say Thank You to Wylie E For This Useful Post:
    May 2010
    HONEYDEW
    Thanked: 3155
    Also very valid on rubber ducks where the transom misses the structural strength of the rest of boat.
  7. The Following User Says Thank You to Mal Hannes For This Useful Post:
  8. #5
    Jan 2021
    JHB
    Best piece of equipment I ever bought for my duck. I had forgotten to latch my motor in place on a short trip back from the vaal, and I noticed that the fibre on my deck was starting to crack due to my motor bouncing up and down.
    I immediately bought a transom saver and haven't looked back.
    i will add that I have launched once or twice and forgotten to remove the damn thing too. Bit like forgetting bungs
  9. #6
    Thanked: 2339
    Quote Originally Posted by Mike the Landyman View Post
    I have them on my rubber duck, which I am trying to flog, because the motors cannot hang down on the trailer. On my ski boat, I transport with the motors fully down and don't have any issues.
    As mentioned by others, the lower units gets pretty scuffed with those gadgets and I went to the local auto paint place in Midrand and got them to match some yamaha paint so that I can touch them up as and when needed.
  10. #7
    Thanked: 45
    I custom built one for my boat/motor - I never tow without it.
    Also remember to turn your steering wheel so that the rod is fully retracted (anti-clock wise) this will prevent the rod from bending.
    [SIGPIC]
    Nelspruit (Mbombela)
    2015 Pajero Sport - Shogun
    2009 Triton 2.5 DiD 4x4 - (EGR blanked off and DPF ("CAT") removed - )
    Echo 1 Trailer & Howling Moon Trailer Tent
    VHF - 4x4Com - 1047 / 29 Mhz - ZRB 4759
  11. The Following User Says Thank You to HannesvZ For This Useful Post:
