Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 80
    Default Aftermarket tyre pressure monitoring system
    Hi
    Any advise on a reliable aftermarket tyre pressure monitoring system for a Amarok.
    Tshwanetoria
    Thanked: 1122
    Default Re: Aftermarket tyre pressure monitoring system
    Valor from Tyreco - have mine for 5 years now
    http://www.tyreco.co.za/
    Thanks Johan. Where did you have it fitted?
    Tshwanetoria
    Thanked: 1122
    Quote Originally Posted by sanjayd View Post
    Tyre Mart Menlyn on the Vitara. And had them refitted on the Amarok at Tyre Mart Montana. Yes, they must be careful during fitment, but they seem to be familiar with the process.
    I bought 5 wheel sensors, so that I can bring the spare into the rotation.
    Sorry incomplete answer.
    Tyre Mart did the sensors. I installed the monitor myself. Technically very easy - instructions included - but it will take a while. Also depending from where you get the power and if you want it permanent powered.
  5. The Following User Says Thank You to hatjohan For This Useful Post:
    Mar 2013
    Molopo
    Thanked: 267
    Johan could you please post a photo of the screen installed in the Amarok if you don't mind?
    Tshwanetoria
    Thanked: 1122
    [QUOTE=HannoK;4475524]Johan could you please post a photo of the screen installed in the Amarok if you don't mind?[
    There you go. I used some malleable plastic SUGRU. From Builders, to get the angles right
    https://sugru.com/
ID:	588824   Click image for larger version.
ID:	588825   Click image for larger version.
  8. The Following 4 Users Say Thank You to hatjohan For This Useful Post:
    Jun 2016
    Thanked: 75
    I fitted these to my car and bike.
    http://cawe.co.za/index.php/products/ngauge4x4
  10. The Following 4 Users Say Thank You to Takashi For This Useful Post:
  11. #8
    Jul 2014
    Thanked: 2006
    Ooh these things will drive me crazy if they dont show exactly the same pressure per wheel
    Willem
    (workshop whore)
  12. The Following 4 Users Say Thank You to WAJ For This Useful Post:
  13. #9
    Tshwanetoria
    Thanked: 1122
    It is actually quite easy to balance them - but the change (pressure and temp) as soon as you have traveled a few k's. On the Amarok the right front wheel always changes the most - due to the turbo being on that side?
    BUT. The pressure differs quite a bit from the readings from an external pressure gauge - they will give you nice explanation if you ask - physics I do not understand and I did not care about after a few days.
  14. #10
    Oct 2012
    otjiwarongo
    Thanked: 237
    Hi
    i have the tire moni TM100 on my amarok. They work and saved me 2 tyres already, no wires in the cab and have a bracket so u can put it againts your windscreen or any place u like.
    https://images.app.goo.gl/TaXSYPsLde5trCiPA
    2017 VW Amarok 3.0 TDi V6 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
  15. The Following 2 Users Say Thank You to hein100 For This Useful Post:
  16. #11
    Tshwanetoria
    Thanked: 1122
    Quote Originally Posted by Takashi View Post
    Really impressive!
  17. #12
    Mar 2013
    Molopo
    Thanked: 267
    Thanks for the photos Johan
  18. The Following User Says Thank You to HannoK For This Useful Post:
  19. #13
    Mar 2013
    Molopo
    Thanked: 267
    I like!
  20. The Following User Says Thank You to HannoK For This Useful Post:
  21. #14
    Melkbosstrand
    Thanked: 256
    That is the greatest thing I've seen today!
    Thanks for sharing!
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  22. #15
    Oct 2018
    Magaliesig
    Thanked: 694
    Looks awesome, and at a good price. How long have you had them - asking to try and gauge how robust they are....??
    Rob Kirk
    Amarok V6.
    Sym 200 scooter 2 x 1, CVT transmission, 4V OHC, 11.4 kW, 15NM
    0-60km/h in about 10s (downhill), Top speed - 100km/h (on a steeper downhill)
    Ground clearance : 125mm on 16-inch rims
    Tare : 134kg, GVM : 250kg (approx), GCM : 250kg (approx), Towing capacity : 0kg
    Best of all : 4L/100km, town driving and pinning it...
  23. #16
    Ellisras
    Thanked: 1070
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 857 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 123 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 125 000 km
  24. The Following User Says Thank You to Dungbeetle For This Useful Post:
  25. #17
    Jun 2016
    Thanked: 75
    Quote Originally Posted by Ama-newbie View Post
    I have only had mine for about 2 months but the quality seems great and the phone app works well.
    The sensors do show battery level and tire temperature as well.
    A slow leak function is also present to alarm if you have a slow puncture.
  26. The Following 4 Users Say Thank You to Takashi For This Useful Post:
  27. #18
    Oct 2019
    Thanked: 51
    I fitted these to my car and bike.http://cawe.co.za/index.php/products/ngauge4x4
    I see that there is no difference in pricing between the internal and external units.
    I was wondering, if you use the external units, how much of a mission is it to remove them to top-up tyres when they need air?
    Anton van Graan
    2009 Touareg 3.6 VR6
    2007 VW Caddy Life TDi
    2004 VW Polo 1.6 Comfortline
    1997 Citigolf 1.3
  28. #19
    Melkbosstrand
    Thanked: 256
    Quote Originally Posted by OettingerTDi View Post
    Iíve got external sensors... not these ones though, and itís just like removing a valve cap... sometimes they stick a bit due to the salt air, but itís not a mission
  29. The Following 2 Users Say Thank You to BobMabena For This Useful Post:
  30. #20
    Jun 2016
    Thanked: 75
    I have externals and they come with a locking nut and little spanner to tighten the sensor to the valve so you can't be stolen.
    But I have not used them and taking them off is just like removing a valve.
  31. The Following 3 Users Say Thank You to Takashi For This Useful Post:
