Page 20 of 20 FirstFirst ... 10 11 12 13 14 15 16 17 18 19 20
Results 381 to 394 of 394
  1. #381
    Apr 2011
    Thanked: 92
    Default Re: Lithium vs Lead Acid
    Quote Originally Posted by WantOnsKan View Post
    I did a test with mine, connected to an empty 65l SM, set it to - 22 deg C and ambient temps in side around 18 deg C. It ran for about 39 hours and battery reached +-10%. Opened lid once or twice.
    It increasingly appears that my test was not fair to the point of exclusion. I set the Engle to where I know it will stay at about 3, in an eye-wateringly cold house, opened about twice, with a bottle of water. It probably almost never cycled.
    I'll do a detailed tv-station test, with constant draw, when the power goes down again. That event at least is as certain as death and taxes.
    Leon Smith
    2020 Toyota Hilux XtraCab 2.8 4x4
    Fiat 500 0.9l turbo flattie
  2. The Following User Says Thank You to leons For This Useful Post:
  3. #382
    Nov 2012
    Thanked: 25
    I bought it from Tentpro, this is the 50 cal. Fat ammo box.
    Thank you!
  4. #383
    Mar 2009
    Thanked: 242
    Quote Originally Posted by leons View Post
    Ran a 40l Engel for 30 hours, with some phone charging, and brought the SOC down to 94%.
    Leons, I had similar-ish results camping 2 weekends ago in Marakele. The engel 40L has (or had when I got mine) the lowest power draw out of all 40L 12V fridges, max 2.5A / hour. I guess this would be at freezing.
    Mine is in a bag, insulated. After +- 48 hours, cold, 2 and 5 at night, running fridge at 1, camping so using the fridge, charging cell phone, my BN108 was at 72% soc. That was from 100% soc with no recharging.
    Needless to say, pleasantly surprised
    Stuart
    2006 Toyota Land Cruiser 100 4.7L V8
  5. #384
    Apr 2011
    Thanked: 92
    Quote Originally Posted by slodj View Post
    Thanks for the feedback Stuart! I tell you, these little Engel's seem to be the bee's knees. And the BN batteries are amazing. Mine just won't lose charge...
    Leon Smith
  6. #385
    Apr 2011
    Thanked: 92
    I can't find an insulated bag anywhere! Where did you get yours?
    Leon Smith
  7. #386
    Mar 2009
    Thanked: 242
    It's a Howling Moon Engel 40L cover. IIRC from Outdoor Warehouse, though I can't find it now on their site.
    4x4 MW also have a cover which looks similar to mine.
    https://www.4x4megaworldonline.com/r...-fridge-cover/
    The picture here is wrong:
    https://www.howlingmoon.co.za/produc...dge-cover-40l/
    Stuart
  8. #387
    Jan 2015
    Thanked: 285
    You're installation is very very neat. But I swallow a little hard on this part. Maybe run that test for us again to make sure.
    Even with the fridge outside with ambient temps around 10 degrees. That sounds a little too good to be true.
    I have testet my 60l NL on a 100Ah lifepo. Fridge set @1Deg [email protected] Just left it. After 80hrs the battery was plat. It is winter but still very impressive
    2002 Discovery td5
  9. #388
    Nov 2008
    Ellisras
    Thanked: 1350
    It is not about how long it runs without use. It is all about how many times you open it and or replenish stock....
    Dont blame yourself over past mistakes. Its like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" chugging along towards 900 000 km.
    2014 Patrol GU 3.0CRD "teenager" in puberty - 126 000 km
    2007 Echo3 Trailer "the nest" with Braked Axle fitted >60 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 125 000 km
  10. The Following User Says Thank You to Dungbeetle For This Useful Post:
  11. #389
    Apr 2011
    Thanked: 92
    I suppose this discussion really has to do with the efficiency of LFP batteries vs. that of lead based ones. We know that LFP's can be discharged to a lower SOC. So that's a plus.
    I wonder if there is a big difference in C rates. The Blue Nova is rated as 108Ah at C10. So what about at C30, or C50? Because that's what's happening here, and even slower C rates. And how does lead handle C rates? Any experts out there?
    Leon Smith
  12. The Following 2 Users Say Thank You to leons For This Useful Post:
  13. #390
    Mar 2009
    Thanked: 242
    Firstly, definitely not an expert, but I'll give it a try.
    The interwebs say:
    'The C Rating is defined by the rate of time it takes to charge or discharge a battery.
    As the rate of discharge increases, the battery's available capacity decreases.'
    For example: 1C is 1 hour. C10 is 10 hours.
    This means that one should get the full power of the BN108 battery if it is discharged at a rate of 10.8A/hour for 10 hours.
    If a battery is discharged at a lower rate that its C rate, one gets ever-so slightly more power. At a higher rate, increasingly less power.
    In the latter case the capacity / power is not 'lost'. It's still there, just currently unavailable, 'scuse the pun
    If the then-flat battery is left for some hours, or a day or more, it recovers and the last remaining power can be used.
    Each battery chemistry, and possibly battery construction, is affected to a greater or lesser extent by this phenomenon,
    which is known as Peukert's Law.
    Stuart
  14. The Following User Says Thank You to slodj For This Useful Post:
  15. #391
    Jan 2015
    Thanked: 285
    The interwebs say:
    You are correct. Defenition of c-rate
    Charge and discharge rates of a battery are governed by C-rates. The capacity of a battery is commonly rated at 1C, meaning that a fully charged battery rated at 1Ah should provide 1A for one hour.
    2002 Discovery td5
  16. #392
    Jan 2015
    Thanked: 285
    The interwebs say:
    The Peukert Law expresses the efficiency factor of a battery on discharge. W. Peukert, a German scientist (18551932), was aware that the available capacity of a battery decreases with increasing discharge rate and he devised a formula to calculate the losses in numbers. The law is applied mostly to lead acid to help estimate the runtime under different discharge loads.
    2002 Discovery td5
  17. The Following 5 Users Say Thank You to Nambro For This Useful Post:
  18. #393
    Krugersdorp
    Thanked: 214
    Just got this info from BlueNova themselves:
    The BN13V-108-1.4k MPS battery is 108Ah at C10, but 100Ah at C1. So there's really not much difference in capacity at different rates.
    Do however take note that the MPS range has a 3year warranty when sticking to the stated specs (Discharge @ C1 max, Charge @ C2 max).
    The warranty does not tell you how long the battery will last as it should last 5-10+ years if used correctly.
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2019 Toyota Hilux Extracab 2.8GD6 4x4
    2018 Bush Lapa Ratel 4 (B1244)
  19. The Following 2 Users Say Thank You to Monkey-D For This Useful Post:
  20. #394
    Nov 2012
    Thanked: 25
    Does anyone know of any 3.2v 120Ah cells that are in stock.
    Cant find them anywhere.
