Page 16 of 18 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 301 to 320 of 350
  1. #301
    Jan 2018
    CT
    Thanked: 190
    Default Re: Lithium vs Lead Acid
    Quote Originally Posted by Wedwo View Post
    BruceHun
    Hi. Please advise which 200ah Lifepo4 battery you are using. I am setting up a similar system thinking about a Blue Nova 200ah with Flexopower's Mojave 240w Foldable panel. I was looking at using a Vectron 100/30 controller but this might be overkill from what you are saying.
    Regards Gavin
    https://www.4x4community.co.za/forum...ova-two-or-one
    Post #2
  2. The Following User Says Thank You to LCamper For This Useful Post:
  3. #302
    Jan 2015
    Thanked: 259
    All the discussions around Lithium are interesting and informative.
    My take
    There are only a few BMS manufacturers with reasonable quality
    BMS's hate drained batteries
    Drop-in lithium will be toast very quickly due to alternator charging profiles
    Always use a DC-DC charge if using litjium as Auxiliary battery.
    If have built approx 12 Lifepo auxiliary batteries. I am running mine close to a year without a hitch. It powers my 1.5kw inverter for my Nespresso machine without blinking.
    The biggest advice for LiFepo4 batteries is to NEVER drain them completely when on tour. The BMS falls into a coma and the DC-DC charger closes shop. It is a mission yo bring those boys back to life. Run the battery between 10 and 90% and they will run gor ever
    2002 Discovery td5
  4. The Following 3 Users Say Thank You to Nambro For This Useful Post:
  5. #303
    Thanked: 1175
    One thing I've seen, to REALLY learn about lithium's and their quirks, is to get 2nd life cells and make them work in unison.
    O boy, it is a challenge but once you "get it", have a balanced bank, o my, that is so cool.
    Ps. Yeah, I don't like it easy ... see, the day ones main bank has a problem, no support or over a weekend, you have NO idea where to start, trust me, you are going to learn very hard and very fast the same skills.
    Lead acid is the same ... no-one knows as much about lead acid than the ones who had to sit somewhere in deep dark Africa, without power.
    Political Correctness
  6. The Following 3 Users Say Thank You to the_terrible_triplett For This Useful Post:
  7. #304
    Plett/Paulshof
    Thanked: 1379
    BruceHun
    Regards Gavin
    Byron is now selling the Vision 200ah that can also be paralleled if necessary. The mecers on the market are second life.
    If you have the moola for BN then go for it. You will only need the 75/15 mppt for that size panel.
    I am very happy with the BN 82ah that I have in battery box to run my dometic 50l. I recently ran it for 5 days non stop and it only dropped to 70% SOC.
    Bruce Hunter. 2019 FJ Cruiser, Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  8. The Following User Says Thank You to BruceHun For This Useful Post:
  9. #305
    Thanked: 119
    Hi
    If I google Sunsol I get Sunsol Geyser and I have just spoken to a William who does not know Byron. Can anyone supply a number or website for Byron
    I have one 200ah Sunsol battery. You will be happy and much cheaper than Blue Nova. Contact Byron at Sunsol solar.
    Regards Gavin
    2015 Discovery 4 30 SDV6 SE
    2007 Defender 90 Puma 2.4
    Bush Lapa Baobab (Ordered)
    Previous
    Metalian Off Road Trailer
    2010 Discovery 4 30 TDV6 SE
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Defender 110 V8 Hard Top
    Jurgens Xplorer
  10. #306
    Plett/Paulshof
    Thanked: 1379
    Hi
    Regards Gavin
    SunsolE solar ....0764583576
  11. The Following User Says Thank You to BruceHun For This Useful Post:
  12. #307
    Jun 2020
    Fourways
    Thanked: 12
    Does anyone know Hoselect battery brand? I've come across this deal and it seems too good to be true.
    https://www.electromannsa.com/produc...SABEgKpNPD_BwE
  13. #308
    Jan 2015
    Thanked: 259
    And the learning continues,
    120A lifepo4, 100A lifepo4, 50A lifepo4 with 120A, 60A and 20A BMS. Testing schedules for discharge with 1.5K inverter and Heatgun, 2x 12V fridges at different temp settings. Discharge rate vs charge rate. Balancing effectiveness etc etc.. Just as you think it is all understood one of the buggers decides to not balance properly. But I am getting closer to the perfect solution.
    2002 Discovery td5
  14. #309
    Mar 2009
    Thanked: 135
    Quote Originally Posted by VVTi View Post
    Note that the name on the front is Hoselest, whereas on the back it's Hoselect and it's marketed as Hoselect. Makes me a bit suspicious . . .
    Stuart
    2006 Toyota Land Cruiser 100 4.7L V8
  15. The Following User Says Thank You to slodj For This Useful Post:
  16. #310
    Jun 2020
    Fourways
    Thanked: 12
    Quote Originally Posted by slodj View Post
    Good observation. No reputable brand will make such an obvious mistake
  17. #311
    Jun 2020
    Fourways
    Thanked: 12
    What makes it more suspicious is that its price is in the gel batteries price range.
  18. #312
    Thanked: 903
    Also refer to post #261 Also spelling mistakes not just the name.
  19. #313
    Randburg
    Thanked: 79
    I see a couple of places have them on offer. Apart from the obvious name discrepancy and bad English translation, I noted that the sticker on the battery states 12kg but website has it at 22.8kg (pointed out in an earlier post by Ekkekan). Another website mentions a 6 month warrantee. Most probably some sort of second life battery.
    At that price I would be tempted to overlook the bad English and give it a bash.
  20. #314
    Jun 2020
    Fourways
    Thanked: 12
    Quote Originally Posted by bloudraad View Post
    I see a couple of places have them on offer. Another website mentions a 6 month warrantee. Most probably some sort of second life battery.
    Links please.
    There seems to be many shenanigans going with this battery. I personally like to buy something used and liked by most people as it gives me some confidence level. I think the best bang for buck currently is the Vision 12V 200ah with claimed 4000 cycles at 80% DOD with a retention capacity of 80% at 1C. Most reputable online stores are selling it as can be seen at links below:
    https://mhn.co.za/shop/vision-12v-lithium-200ah/
    https://thepowerstore.co.za/products...-lithium-200ah
    https://pclinkshop.co.za/ups-inverte...lithium-200ah/
    Note: this battery is new to the market but seems to provides better specs than the much loved (at least from what I read on another forum) Mecer counterpart, therefore I expect it to unseat it in this territory. Just my 2c worth.
  21. #315
    Jan 2015
    Thanked: 259
    Links please.
    I would be carefull using them. Even for solar since the BMS/Balancing board may be of substandard. To discharge at 100A you do need a FRIS BMS that does good balancing. To charge at 100A same as above.
    For 200Ah the price is very very cheap. With bulk discount a reasonable 100Ah lifepo4 battery will sell for +-ZAR7000.00.
    2002 Discovery td5
  22. #316
    Randburg
    Thanked: 79
    Wink Re: Lithium vs Lead Acid
    Links please.
    Some links I found:
    https://www.sellsa.co.za/solar-battery-1210
    https://doodah.co.za/solar-power/339...ttery-12v.html
    https://gasolar.co.za/product-catego...-backup-units/
    https://www.facebook.com/pg/Linkssolar/posts/
    https://www.facebook.com/batteryrs/
    I see Battery mart in Klerksdorp mention them on their Facebook page. Perhaps worth while giving them a call and getting some more info. There seems to be some conflicting info about the batteries (the little which is available). I read somewhere else that there is a 3 year warrantee on the battery, so best to do some homework.
    Somebody needs to be the guinea pig...
  23. The Following User Says Thank You to bloudraad For This Useful Post:
  24. #317
    Mar 2018
    Ellisras
    Thanked: 16
    https://mhn.co.za/shop/mecer-lifepo4...attery-200-ah/ Referring to these type battery
    Attached picture is how it looks inside apparently
    Found on powerforum
  25. #318
    Thanked: 1175
    This is a 48v 150ah 16 cell LifePo4 bank (7.68kWh i.e 51.2v (3.2v x 16) x 150ah) with:
    1) 200amp BMS with built in Bluetooth,
    2) Factory added RS485 port connecting to the Victron Venus via USB,
    3) Victron SmartShunt for more accurate SOC, that also has Bluetooth, connecting to same Venus via VE.Direct cable.
  26. The Following 2 Users Say Thank You to the_terrible_triplett For This Useful Post:
  27. #319
    Jun 2020
    Fourways
    Thanked: 12
    It can't be me
  28. #320
    Jun 2020
    Fourways
    Thanked: 12
    Quote Originally Posted by WantOnsKan View Post
    Found on powerforum
    Yes, there's also good reviews on the same thread.
    Link: https://powerforum.co.za/topic/5439-...ny-experience/
