Lithium vs Lead Acid - Page 7
Page 7 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 121 to 140 of 246
  1. #121
    Thanked: 1038
    Default Re: Lithium vs Lead Acid
    Quote Originally Posted by Mypro-D View Post
    The idea was from Fredsport originally: Ask for the 4 cell kit (R5400) and upgrade to 8 cells with extra connectors (R4800).
    This titbit the key: That BMS can only take 4 cells - count the red wires.
    So one needs a 2nd BMS for 4 more cells, for a 12v system.
    Political Correctness
  2. #122
    Nov 2012
    Thanked: 9
    Yep, that's what I thought. Wonder how he is only using 1BMS. Id like to do it properly.
    Thank you!
  3. #123
    Nov 2012
    Thanked: 9
    So the very very friendly folk at Lithiumbatterysa gave me this diagram. This is how it should be wired with their BMS.
  4. #124
    Ellisras
    Thanked: 906
    Yip I done that, works
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 854 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 121 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 125 000 km
  5. The Following User Says Thank You to Dungbeetle For This Useful Post:
  6. #125
    Thanked: 1038
    And there I learnt something new!!! Thanks for posting that here.
  7. #126
    Nov 2012
    Thanked: 9
    Sharing is caring!
    I dont have enough busbars so I cant connect it up.
    Anyone know where I can get these in Cape Town? I am 4 short
  8. #127
    Ellisras
    Thanked: 906
    Sharing is caring!
    Get a alum flat bar from your local hardware shop. Make your own
  9. #128
    Thanked: 796
    At each BMS on the website there is a detail picture how to connect the cells and BMS and the load/charger connections.
    Full marks for the information provided.
  10. #129
    Nov 2012
    Thanked: 9
    No one had the alu bars so just to test I bought some Copper Earth Strip and doubled it up.
    I am posting this here because I know absolutely nothing about these things and perhaps someone could learn from this.
    I bought the DIY kit from from lithiumbatteriessa along with 4 extra cells. I did not know these were 2nd life until it was posted elsewhere. Its my own fault as I didn't read it properly but its not an issue for me.
    Anyways nevertheless the plan was to install them just like the pic I posted earlier. Alas, they did not fit.
    So I put them in a different way. Initially, they did not fit as the bottom of the box was a little narrower than the top.
    I made a false floor to raise the cells off the ground and to allow the box to flex a little to accommodate the cells.
    I did not use the wires from the BMS as it had shaved through the protective sheath from trying to bend the wire around the box.
    Instead I used their wires provided ( 8 awg silicone rated at 200 Degrees ) Cut off the ring of two lugs and drilled holes to screw onto the BMS and then crimped onto their wire.
    I measured the cells once all was connected and got 13.1 volts. Success!
    I charged them up and they took 68AH and now read 13.2 Volts, 3.3 per cell. I am guessing this is because they are now only at 80% of their initial capacity.
    I connected the inverter up and tested with a load ( Heat Gun ) it pulled 109 Amps for one minute and all was fine. Wires from the inverter were a little warm but not hot. I connected a Nespresso machine and made a cup of coffee, no problem. Inverter peaked at 1380 Watts. Voltage dropped to around 12.1 and once there was no load settled at 13.2 within 30 seconds.
    I was going to order a BMV 712 but considering this is a budget build I have ordered a TR16 350A from Banggood +- R 850-00.
    The charger in the vehicle is a NL 25A DC-DC and for home charging a Victron Energy Blue Smart 12/25.
    Excuse the pics as this was to test, I will get the correct Busbars soon and sort that out.
    Thanks for all the info in this thread, it was a great learning experience!
ID:	590519 Click image for larger version.
ID:	590520 Click image for larger version.
  11. The Following 4 Users Say Thank You to Mypro-D For This Useful Post:
  12. #130
    Thanked: 1038
    ... I will get the correct Busbars soon and sort that out.
    Just order more from LithiumBattSA, no?
    Because of THAT pic, how it is wired, now I want to double up on my APC UPS battery replacement too, using 8 more cells (24v), totaling 16 of these cells in the end, on the same BMS.
    It would then be 24v 12ah (2x6ah) with max 10amps relaxed charging (BMS limit), more than ok as the previous 4 x 12v 7ah cells was 24v 14ah.
    But for the life of me I cannot figure out how the red balancing wires should then be connected.
  13. #131
    Nov 2012
    Thanked: 9
    Full Disclosure here. The other half is an Engineer and helped me with my layout even after they sent me a pic. I will ask her to draw me a picture. Unfortunately her field is more Mechanical but, has a basic understanding of how these nodes should be positioned.
  14. #132
    Thanked: 1038
    That teeny titbit caught my attention ... please do.
    Full disclosure here too - between 2 males:
    1) I've blow one 16s 150amp BMS already.
    Being the first time ever that I had to wire said BMS in on 16 cells, it was not mentioned that on cell 9, that you connect the black wire to the neg pole, and not the pos pole.
    A teeny weeny extremely salient and easy to communicate piece of info for a first time newbie connecting a brand new BMS.
    2) 2nd one I did everything by the book ... yet it had to be sent back as faulty.
    This time I got a 2nd opinion in before sending it back ... by the book I say.
    Ps. I so wish, in the world we live in today, that we had more females in the driving seat, also in politics ... we desperately need them today to help un-f..k this world we live in. I'm dead serious.
  15. #133
    Hillcrest
    Thanked: 7292
    I really wouldnít bother getting the bus bars. Aluminum is coppers cheap underperforming cousin anyway.
    Those copper links will carry a 10 times what you are doing without breaking a sweat.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  16. #134
    Thanked: 1038
    Fluffy, this is very interesting!
    Just to confirm I understand properly, we can use the same Copper Earth Strip as in the picture, instead of those horrible aluminum busbars, to connect these type of cells?
    Can one go single or double up as Myprodol, whoops, Mypro-D did?
    My case call it 200amps max DC the inverter can do.
  17. #135
    Thanked: 796
    Those earth strips are only 3.5sq mm per single strip so perhaps you need 4 or even more for 200A.
  18. The Following User Says Thank You to ekkekan For This Useful Post:
  19. #136
    Feb 2012
    Thanked: 25
    Trying this for my alarm system back up, 4s2p 12ah.
  20. #137
    Thanked: 1038
    Quote Originally Posted by leoridge View Post
    Great idea! Where did you source those holders?
  21. #138
    Feb 2012
    Thanked: 25
    Banggood , AliExpress have as well.Click image for larger version.
  22. The Following User Says Thank You to leoridge For This Useful Post:
  23. #139
    Thanked: 1038
    Found some here in SA too: https://www.electromannsa.com/produc...osite-bracket?
  24. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
  25. #140
    Thanked: 797
    Mypro D,
    Your aux box looks mighty neat! I see on the outside it says 12V aux box but...Ö..
    But please explain to me what you did in the 1st pic.
    For the life of me, I cannot figure out how those cells are connected.
    This will bug me for the whole day and I need to know. It would've helped a lot if I could figure out which side of each battery is + and which is -
    It looks like parallel / serie connection? There just too many bars in my layman mind
    What capacity are the individual cells and how did you connect them?
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
