Page 5 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 81 to 100 of 394
  1. #81
    Florida
    Thanked: 821
    Default Re: Lithium vs Lead Acid
    100%, but you are going to have to DIY the battery, that is the only ‘catch’.
    That and they are 2nd life cells.
  2. #82
    Thanked: 842
    He also sells new ones for around 30% more. I have 2nd life ones, which is fine I think for running fridges and stuff for camping purposes.
  3. #83
    Thanked: 34
    He sells both new as well as second life cells (in the case of second life it is clearly indicated) - friends as well as myself bought various cells and BMS's from him and I can recommend the kit for the price.
  4. #84
    Cape Winelands
    Thanked: 336
    How old are 2nd life cells, and how long for new ones before they need 2nd life refurbishment?
    2011 CashCow 1.6 (Swambo)
  5. #85
    Langebaan
    Thanked: 54
    So far my experiences with Bain at https://lithiumbatteriessa.co.za/ is that he is 100% top notch and completely legit.
    He is not only more than helpful, he also listens to customers and helps out where he can if he can.
    My "review" of https://lithiumbatteriessa.co.za/ is 100% my own nor will I receive any monetary or other remuneration for this "review".
    Fully agree with this opinion.... I bought four 2nd life cells and a bms a while ago and built a camping battery.
    The cells start life as 150+Ah when new, and when swopped out as part of "planned maintenance", are tested and resold as 120 Ah, second life. But the chemistry should be good for many (thousands) more cycles. I tested by fully charging and then running my nat luna fridge through an Ah meter.... Some 3 days and 127Ah later I switched off. Battery was still at 12.4 volt, probably 10% SOC.
    Since then through many cycles, camping all over. Charging (fast/little losses) with both solar and dc2dc.
    There should be upwards of 2000 cycles in this kit. Very happy !!!!
  6. The Following User Says Thank You to RiaanJ For This Useful Post:
  7. #86
    Cape Town, Plumstead
    Thanked: 319
    Quote Originally Posted by RiaanJ View Post
    Thanks for the feedback, very interesting indeed.
    Which solar and DC - DC chargers are you using ?
    Safe Diving - Andy
    2013 Isuzu KB6 300 DC 4X4
    http://www.flickr.com/photos/andrews_underwater_images/
  8. #87
    Jun 2008
    Latest news is that BN will be bringing out a 1.4kWh model with Bluetooth soon. The price and available date is not yet known. The BN13V-108-1.4k without Bluetooth is still available. I think that BN want to standardise their "drop in" range and would then have the 108 available with or without Bluetooth.
    They also have a 13V 154kW Mini HP battery (with Yittrium fortified cathodes) available which is in robust case with a complete BMS included plus local and remote monitoring for firmware updates. Useable capacity 2,000Wh. Weighs in at 25kg and dimensions are 410 x 290 x 300mm (W x D x H) thus it is not suitable as a "drop in" battery. Price is about 50% more that the current 104/108 models thus the cost per kW is slightly higher for the 154HP battery. I attach a spec sheet for information.
    If I was in the market for batteries (I have 2X108's installed in my Companion) that don't have to be drop in's and the space then I would go for a single 154kW Mini HP instead of my current set-up.
    I am interested in 154kw Mini HP Tron, can you suggest where to purchase one? Thanks
  9. #88
    Dec 2019
    Thanked: 79
    Correct on the 150+ Ah in the first live. I have founded that they there is actually 140ah left in them. I got 16 cells of Bain first batch that he imported last year November and a second set of 16 in his 2nd shipment in Feb. Over the lock-down time i had some time on my hands to keep a eye on the BMS and adjusted the settings. I spotted that at 119ah the batteries kept charging on for a bit till the BMS disconnected. So I adjusted the bms AH charging every week. What i founded was that there is about 140ah left in the batteries. I will post later today when i'm back at my house the Ah Cycles on the BMS units to show how many AH cycles my 2 setups did and they still going super strong and i did some hard testing on mine.
  10. The Following 2 Users Say Thank You to Gerlach For This Useful Post:
  11. #89
    Florida
    Thanked: 821
    Quote Originally Posted by Dave Storm View Post
    Call Victor he should be able to assist.
    +2774 431 9336
    +2721 205 2000
    [email protected]
  12. #90
    Tshwanetoria
    Thanked: 1315
    Quote Originally Posted by Jola View Post
    Any ideas for a DC-DC 20A charger that does a Lithium profile ?
    The CTek D250SE is a bit expensive.
    National Luna
  13. The Following User Says Thank You to hatjohan For This Useful Post:
  14. #91
    Apr 2015
    Thanked: 302
    Victron Orion Smart TR 30A about R3k.
    Recommended seller for that price ?
    Also these Orion devices are a bit confusing, there are a variety of models and the output voltages seem weird.
    Discovery 1 1995 V8i 3.9l (Sold, owned for 20 years); Freelander 2 2013 SD4 SE; Discovery 4 2014 SDV6 SE; Bushlapa Boskriek
  15. #92
    Apr 2015
    Thanked: 302
    You should just have bought the Victron charger, in stock in SA. Price also better than the CTEK plus good back up.
    I managed to cancel the CTEK lithium charger before they shipped.
    So where can I get a Victron charger that supports Bluetooth and LIFEPO4 for a reasonable price ? About 5 to 10 Amp, depending on price.
  16. #93
    Thanked: 1367
    Current Automation aka https://victrondistributors.co.za/
    Also ask Google for prices ... as it can differ a wee bit.
    Political Correctness
  17. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
  18. #94
    Plett/Paulshof
    Thanked: 1849
    www.livestainable.co.za
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  19. The Following User Says Thank You to BruceHun For This Useful Post:
  20. #95
    Krugersdorp
    Thanked: 214
    The Victron OrionTr 18A and 30A smart (bluetooth) chargers are both available from www.EnergyOn.co.za:
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2019 Toyota Hilux Extracab 2.8GD6 4x4
    2018 Bush Lapa Ratel 4 (B1244)
  21. The Following User Says Thank You to Monkey-D For This Useful Post:
  22. #96
    Jun 2008
    Hi Guys
    Will be replacing Lead Acid batteries with Blue Nova Life PO4 Battery with Blue Tooth, my setup must support the BN Batteries.
    Setup as follows, could you guys comment, feel free to add or remove :
    * Victron MPPT 30amp Regulator
    * Victron Blue Smart Charger 12/30
    * CTEK D250S Dual Regulator - DC to Dc Charging & has Solar Panel Port(180w Max.)
    * 2 x Rigid Solar 135w 8,5amps Panels
  23. #97
    Apr 2015
    Thanked: 302
    Hi Guys
    You need the CTEK D250SE for the LIFEPO4 batteries.
    The rest seems fine.
  24. #98
    Jun 2008
    Many thanks for the info, have another quick question :
    Will the set up still be ok if 2 more 135w solar panels get added into the mix, so will have 4 x 135w solar panels
    * CTEK D250SE Dual Regulator - DC to DC Charging with Solar Panel Port(180w Max.)
    * 4 x Rigid Solar 135w 8,5amps Panel.
  25. #99
    Thanked: 1046
    Hi Guys
    Goes beyond saying, and I suppose you have already connected everything, but just be sure that your panels is in parallel. Not serie….
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  26. #100
    Thanked: 1046
    In a parallel connection, your watts and amps is added up taking you to 540W and 34 Amps , but the volts stays the same. So even 2 panels in parallel is too much for the Ctek
    The D250S will go poof if you say the max it can handle is 180W.
    Serie connecting also wont work as now you add the respective voltages up and the max the D250S can handle is 23V if I remember correctly.
    If the Victron MPPT are to be used exclusively for the solar, then all is good.
    Last edited by Die SwartKat; 2020/09/18 at 03:58 PM. Reason: Correcting a horrible stupid mistake
    Nico Swart
    ZS6NJS
