Page 2 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 40 of 394
  1. #21
    Thanked: 842
    Default Re: Lithium vs Lead Acid
    Quote Originally Posted by propofol View Post
    Thx fir the reply:
    i wonder if anyone have charged them off an alternator.. I have a NL solenoid box spare at home...
    Yes I have on the Touareg, but need to do a more thorough long term test still, i.e. a full charge cycle on a battery from empty to full. Charges at around 37 AH. Don't see any issues.
  2. #22
    Thanked: 842
    Ps:
    would love to see the boxes you made...
    I'll post some pictures.
  3. #23
    Thanked: 133
    I built myself two 120AH portable batteries using his cells and BMS. Wors very nicely. One does not need to overthink Lifep04 batteries too much, especially for occasional camping use. They are easily compatible with most chargers that charge lead acid batteries. What you don't want is something that does a pulse type of charge. Any DC DC converter is perfect. In my practical experience the Lifep04's charge up nicely at exactly the same voltage as lead acid batteries, even off an alternator is fine. If the battery only charges to 99%, it really does not matter. At 13.3 v it's at 90%, 13.4v 99%, 13.6v 100% and 14.4v still 100%.
    I can run my NL 90 fridge on full tilt non-stop flat out for around 48 hours on one 120AH battery. Real-life camping in extreme conditions that would translate to three or four days easy.
    If you run Lifepo4's daily on a system in your house, then you might want to give the charge cycle much more consideration, i.e. no float charge should be applied constantly. For the odd weekend camping, it's really not going to matter.
    Probably the most important thing for camping use is that you should store them at 50% charge, never fully charged or fully discharged.
    I made nice compact portable boxes for mine, - sorry don't have a photo now.
    But best thing I ever did. Would never go back to traditional batteries. The freedom of being able to use them down to 0% without much worry is awesome.
    Kortgat
    Thanks for your reply. Something I picked up that I had not heard before is the correct SOC for Storage. I am planing to do a permanent install under the 6th and 7th seats of the disco. So on returning from a trip I should unplug from the DC to DC charger a few hours before I get home and let the Battery discharge until I turn the fridge off. Then I should leave the battery unplugged from the DC to DC charger until I need it again. I see the spec sheet says discharge rate of 3% per month, so I should just watch this aiming to keep it around 50%
    Am I correct.
    Regards Gavin
    2015 Discovery 4 30 SDV6 SE
    2007 Defender 90 Puma 2.4
    Bush Lapa Baobab 2470
    Previous
    Metalian Off Road Trailer
    2010 Discovery 4 30 TDV6 SE
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Defender 110 V8 Hard Top
    Jurgens Xplorer
  4. #24
    Apr 2012
    Pretoria East
    Thanked: 20
    Thank you!!!
    Wouter
    Me:2018 Toy Fortuner 2.8 auto 4x4
    Swambo: 2017 Audi Q3 aka cutie
    Echo 2 in tow
  5. #25
    Aug 2015
    Thanked: 41
    I also bought some batteries from LithiumBatteriesSA. Second life Lithiums. I had a 60 kg lead acid 200AH for 2 years and it could not do even close to what the 12kg 100AH lithium can do now. Price wise it is a bargain. What is 2 fancy lead crystal 100AH going to cost which cannot even compare to 1 Lithium
  6. #26
    Thanked: 842
    Here are the photos.
    Built from 9mm ply wood. Aluminum edging. Foam rubber shock absorption internal. Coated with bakkie liner.
  7. The Following 2 Users Say Thank You to Kortgat For This Useful Post:
  8. #27
    Thanked: 842
    Quote Originally Posted by Wedwo View Post
    Kortgat
    Am I correct.
    Regards Gavin
    Yes. 100%
  9. The Following User Says Thank You to Kortgat For This Useful Post:
  10. #28
    Jul 2014
    Waterfall
    Thanked: 143
    Where is offering the best prices on a Blue Nove 104AH battery?
    2016 V8 D/Cab Cruiser
    Land Cruiser VDJ 71
    2020 LC 200 GXR
    2020 LC FJ
  11. #29
    Apr 2019
    Thanked: 2585
    Quote Originally Posted by geoff norton View Post
    Takealot was cheaper than Bushpower. Bushpower service was much much better tho!
  12. #30
    Plett/Paulshof
    Thanked: 1849
    If you have a business you can register as a dealer and get a nice disount
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  13. #31
    Jul 2014
    Waterfall
    Thanked: 143
    Bruce, with which company must I register?
    Land Cruiser VDJ 71
    2020 LC 200 GXR
    2020 LC FJ
  14. #32
    Dec 2019
    Thanked: 79
    Quote Originally Posted by Ama-newbie View Post
    Their prices seem really good - about half that of Blue Nova. What battery charger do you use? Do you charge from 220v, or from Solar panels?
    I'm running mine on a 48v inverter with mppts. I adjusted the inverter to 54.6v bulk and 53.6v for float with 10% amp charge if i need to run from tje grid. The mppts the same volts but running 95% amp charge. It's 2 x 60a mppts.
    The bms I'm using is a Smart Ant bms that got Bluetooth and it's own screen. So i can check all the info of the battery or i can use my phone to log on to the BMS and check all the settings state of the battery. Click image for larger version.
  15. #33
    Krugersdorp
    Thanked: 214
    Cheapest I can find is at https://www.energyon.co.za/shop/blue...ithium-battery
    Less than Takealot and BushPower.
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2019 Toyota Hilux Extracab 2.8GD6 4x4
    2018 Bush Lapa Ratel 4 (B1244)
  16. #34
    Apr 2012
    Pretoria East
    Thanked: 20
    wowow... Looks really pro...
    dankie vir die photies
    Wouter
    Echo 2 in tow
  17. #35
    Florida
    Thanked: 825
    I received the following update on the availability (or not) of the BN13V-104-1.3k. The BN13V-108 is available see the attachment.
    "Good day Ron,
    ...................................... we’ve sold out and discontinued the BN13V-104-1.3k
    Regards,
    Victor Smit
    Sales Executive"
  18. The Following User Says Thank You to TRON For This Useful Post:
  19. #36
    Apr 2019
    Thanked: 2585
    "Good day Ron,
    Regards,
    Victor Smit
    Sales Executive"
    Wow. I’d assumed that was their “newer” product (hence Bluetooth) - wonder what happened.
  20. #37
    Florida
    Thanked: 825
    Latest news is that BN will be bringing out a 1.4kWh model with Bluetooth soon. The price and available date is not yet known. The BN13V-108-1.4k without Bluetooth is still available. I think that BN want to standardise their "drop in" range and would then have the 108 available with or without Bluetooth.
    They also have a 13V 154kW Mini HP battery (with Yittrium fortified cathodes) available which is in robust case with a complete BMS included plus local and remote monitoring for firmware updates. Useable capacity 2,000Wh. Weighs in at 25kg and dimensions are 410 x 290 x 300mm (W x D x H) thus it is not suitable as a "drop in" battery. Price is about 50% more that the current 104/108 models thus the cost per kW is slightly higher for the 154HP battery. I attach a spec sheet for information.
    If I was in the market for batteries (I have 2X108's installed in my Companion) that don't have to be drop in's and the space then I would go for a single 154kW Mini HP instead of my current set-up.
  21. The Following User Says Thank You to TRON For This Useful Post:
  22. #38
    Melkbosstrand
    Thanked: 275
    Takealot have the 82AH on their Daily Deal today..
    https://www.takealot.com/blue-nova-l...h/PLID60693610
    Not sure if that's useful?
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  23. #39
    Nov 2012
    Thanked: 25
    Oh Dear
    I picked up a BN 104 this morning from Takealot.
    That is disappointing.
  24. #40
    Florida
    Thanked: 825
    Quote Originally Posted by BobMabena View Post
    That's an extremely good price for an extremely good LiFePO4!
