Page 19 of 20 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 361 to 380 of 394
  1. #361
    May 2017
    Thanked: 1682
    Default Re: Lithium vs Lead Acid
    Quote Originally Posted by WantOnsKan View Post
    My recently built 12V battery box with 100Ah cells from lithiumbatteriessa.co.za, 80A Daly Smart BMS from Banggood. 100/20 victron mppt. One red Harrison plug feeding directly from battery via BMS for bigger loads and 2 red Harrison plugs for fridge and 12V lights via mppt load output. Blue Harrison plug for solar panels.
    Many thanks to stormjp for his battery box idea and for giving me some pointers.
    That looks very neat!
    Flying Spaghetti Monster
    ZS1ETphonehome
  2. The Following User Says Thank You to EHoffmann For This Useful Post:
  3. #362
    May 2007
    Durbanville Cape Town
    Thanked: 189
    Very nice. How did you mount the breaker?
  4. #363
    Mar 2018
    Ellisras
    Thanked: 69
    Quote Originally Posted by bees View Post
    Thanks! It was quite an effort to get everything to fit. I used a small wooden wedge between the breaker and battery wood casing to keep it in place, if it rattles out I'll try improving it.
  5. #364
    Apr 2011
    Thanked: 92
    I have never run a lead acid battery before, so can't compare, but darn, my 1400Wh lithium is a pleasure. Ran a 40l Engel for 30 hours, with some phone charging, and brought the SOC down to 94%. Expensive, worth it.
    Leon Smith
    2020 Toyota Hilux XtraCab 2.8 4x4
    Fiat 500 0.9l turbo flattie
  6. The Following 5 Users Say Thank You to leons For This Useful Post:
  7. #365
    Jun 2020
    Fourways
    Thanked: 13
    Quote Originally Posted by leons View Post
    Wow that's a neat and professional installation. Where did you buy your bus bars?
  8. The Following User Says Thank You to VVTi For This Useful Post:
  9. #366
    Apr 2011
    Thanked: 92
    Quote Originally Posted by VVTi View Post
    Thanks! I bought the busbars at ACDC in Cape Town, and ground the positive bar's fuse indents down with an angle grinder.
    Leon Smith
  10. The Following 2 Users Say Thank You to leons For This Useful Post:
  11. #367
    Thanked: 1100
    Do I read your consumption correct that the fridge only used 6% of the 1400Wh available in the 30 hrs which is 84Wh?
  12. #368
    Jul 2016
    cape town
    Thanked: 68
    if, say i want to buy that setup from you, what will it cost me? to much info out there for my doodle i just want to "plug and play"
    Currently(Katryn) 2011 FL2 SD4 stock
    K6 GSXR750 (With all the BAZZAZ goodies)
    EX: 2012 Mazda CX7 Individual 2.3disi (sold)
    2010 Mazda 3 Sport Dynamic (sold)
    2004 VW 1.9Tdi (sold)
    2007 Fiat Strada (sold)
    (Thandi) K7 gsxr600 (wrecked)
  13. #369
    Apr 2011
    Thanked: 92
    That's right, according to the BMV-712. Granted, indoors on a cold Cape day, opened very occasionally.
    Leon Smith
  14. #370
    Apr 2011
    Thanked: 92
    Quote Originally Posted by dieselwa View Post
    Therein lies the rub. I estimate the completed box, together with the battery and all the Victron equipment, cost about R32,000.00.
    Leon Smith
  15. The Following User Says Thank You to leons For This Useful Post:
  16. #371
    Thanked: 1100
    For a cheaper MPPT this could also be used.
    https://www.communica.co.za/products...BoC9dMQAvD_BwE
    Not taking anything away from Victron but there are pieces of kit that is cheaper. This happens to be one.
    https://www.youtube.com/watch?v=E6O76Okmt08
  17. #372
    Apr 2011
    Thanked: 92
    Oh, no doubt. My solution is expensive, and certainly isn't the only one. In fact, it's not necessarily even the best one. I just had a bee in my bonnet .
    Leon Smith
  18. The Following User Says Thank You to leons For This Useful Post:
  19. #373
    Thanked: 1100
    Yes you have built a masterpiece with great ideas.
  20. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
  21. #374
    Thanked: 1049
    You're installation is very very neat. But I swallow a little hard on this part. Maybe run that test for us again to make sure.
    Even with the fridge outside with ambient temps around 10 degrees. That sounds a little too good to be true.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  22. #375
    Jul 2014
    Thanked: 13
    Baie netjies!
    I really like the idea of a smart BMS to monitor the charge whilst out and about, without having to get into the back of the vehicle to look.
    Is that a normal AC breaker you're using? I've been advised against using that in a DC setup, so opted for a 100A resettable breaker from 4x4direct.
    I really like your setup and might make a few tweaks to mine in future.
  23. The Following User Says Thank You to stormjp For This Useful Post:
  24. #376
    Mar 2018
    Ellisras
    Thanked: 69
    Quote Originally Posted by stormjp View Post
    Baie netjies!
    It is indeed a 125A DC breaker from lithiumbatteriessa.co.za
    I have added the wooden casing to protect it from the ammo box sides and to give some compression to the cells.
    The BMS also have some short circuit protection but if all else fails... I have the DC breaker. And it's just good to know when it's off, everything is dead.
    The Bluetooth works very nicely and you can adjust BMS settings on the fly.
ID:	618673   Click image for larger version.
ID:	618674   Click image for larger version.
  25. The Following User Says Thank You to WantOnsKan For This Useful Post:
  26. #377
    Nov 2012
    Thanked: 25
    I like this. I made one in a National Luna box with 240AH but I find its way over what I need.
    Where did you get the Ammo Box from? I might look at going this route instead.
  27. #378
    Mar 2018
    Ellisras
    Thanked: 69
    Quote Originally Posted by Mypro-D View Post
    I bought it from Tentpro, this is the 50 cal. Fat ammo box.
  28. #379
    Apr 2011
    Thanked: 92
    Yes, I will. Probably the better field test will be in a few weeks time when we'll be camping in the Kruger for a week. I'll try to keep track of all inputs and outputs.
    Leon Smith
  29. The Following User Says Thank You to leons For This Useful Post:
  30. #380
    Mar 2018
    Ellisras
    Thanked: 69
    I did a test with mine, connected to an empty 65l SM, set it to - 22 deg C and ambient temps in side around 18 deg C. It ran for about 39 hours and battery reached +-10%. Opened lid once or twice.
