Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 101 to 120 of 129
  1. #101
    Thanked: 2979
    Default Re: My next project......
    Cool - I guess the rivets were throwing me off. I hope it's a goer.
    The Devil is in the details, as they say. Most of the rivets won't even be visible unless you get under it, but for those who do get under, they will be an added treat.
    I reckon it will go very nicely indeed.
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  2. #102
    cape Town - 0624206806
    Thanked: 523
    6Ē ground clearance...... donít think there gonna be many who get under there ( unless they become a speed bump )
  3. #103
    Thanked: 523
    Default My next project......
ID:	602340Click image for larger version.
ID:	602341Click image for larger version.
    Busy positioning the firewall to check bonnet height..... carbs are gonna be a problem so it looks like Iíll have to go for the Weber 38 DGES conversion and hide it in the spare wheel on the bonnet...
    Rob (Hagu13) popped in and confirmed what Johnno said about my ďopen driveĒ mounts being too flimsy.....need a separate ďmid plateĒ for the gearbox.
    Once again, donít you just hate it when your ďfriendsĒ put stupid ideas in your head .....(the worst bit is that you know theyíre right)
  4. #104
    Sep 2015
    Thanked: 198
    Quote Originally Posted by GaryFrank View Post
    I look forward to seeing how you hid the Weber and secured the spare wheel.
  5. #105
    Thanked: 3963
    I have once did a Weber conversion on a 3.5 Rover V8. Milled the stock intake to get rid of the carb runners. Installed an adaptor plate which I tapped and screwed to the manifold.
    Easy conversion
  6. #106
    Thanked: 523
    I still have to make the bonnet so thatís still far away ..... but I have a plan
  7. #107
    Thanked: 2979
    NO! A thousand times, NO!
    Philistine.
    Put power bulges in your bonnet if you have to, but keep it original.
    Something like this...
    Besides, how will you see over a spare wheel on the bonnet with your arse nearly on the ground?
    You need to hang the spare in front like the SAS pink Panthers used to, in place of a bumper...
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  8. #108
    Thanked: 523
    I was waiting for you to see that bit.....
    Original pic had a spare wheel on the bonnet ( wrong rim size & tread....)
    I was just thinking ďoutta the boxĒ, besides, you look ďaroundĒ the spare
  9. #109
    Sep 2015
    Thanked: 198
    Weber also make side drafts for a lower profile...might be time to think about fuel injection, but then you'd need an ECU and MAF.
  10. #110
    Thanked: 2979
    That on an MGB V8 manifold, maybe.
    or, just relocate the SUs, but those manifolds had a rep for being even more restrictive on an already partially strangled set-up.
    Mmmm, injection....
    a cool GBP 3 995.00.....
    https://rennsportfactory.co.uk/product/rover-v8-itbs/
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  11. #111
    Thanked: 523
    Thatís too much for an asthmatic 3.5 V8.......
    Besides, thatís gonna cost $$$ - remember, Iím working with whatís available
  12. #112
    Thanked: 523
    Busy working on customers Landys so play time is limited.
    Playing with the outriggers.....not gonna have much space underneath so Iím gonna run the exhausts through the outriggers Click image for larger version.
  13. #113
    Sep 2015
    Thanked: 198
    Pity Lake Pipes aren't legal, but that diameter looks like it will handle a monster motor.
  14. #114
    Thanked: 523
    Those pipes would work nicely on my 6,5 GMC diesel....
  15. #115
    May 2011
    Klipriver
    Thanked: 387
    Maybe spice it up a bit
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  16. #116
    Thanked: 523
    Iím already thinking about my breakdown crane...
  17. #117
    Dec 2015
    Thanked: 33
    Tagging along... Want to really do something like this some day when my son is older
  18. #118
    Thanked: 1389
    Quote Originally Posted by King_Triton View Post
    Like the zero turn assault vehicle?
  19. #119
    Thanked: 523
    Got a little bit further....Click image for larger version.
ID:	607430Click image for larger version.
ID:	607431Click image for larger version.
  20. The Following 3 Users Say Thank You to GaryFrank For This Useful Post:
  21. #120
    May 2011
    Klipriver
    Thanked: 387
    At least it's got a British motor
    Alan
    _________________
    Range Rover P38
  22. The Following 2 Users Say Thank You to Alan Eveleigh For This Useful Post:
