Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 121 to 129 of 129
  1. #121
    Thanked: 510
    Default My next project......
    That’s nice....Click image for larger version.
ID:	610621Click image for larger version.
    Been busy with other “stuff”
  2. #122
    Thanked: 510
    Default Re: My next project......
    Prototype...... wanna get as low as possible (also helps position the pedals)Click image for larger version.
ID:	610737Click image for larger version.
  3. The Following User Says Thank You to GaryFrank For This Useful Post:
  4. #123
    Sep 2015
    Thanked: 184
    That resembles a Kirkey racing bucket.
    The problem with sitting on the frame is that your legs don't have the mechanical advantage like in a big off-roader. You have to pull your leg to your chest and don't have the advantage of gravity to assist with a heavy push. Therefore, many Cobras use automagics.
    Renault Duster 4WD Gen1: No Meow, GC = 254mm, WD = 820mm
  5. The Following User Says Thank You to Butch Dassie For This Useful Post:
  6. #124
    Thanked: 510
    Hydraulic clutch is gonna help a bit
  7. #125
    Apr 2011
    Hartbeespoort
    Thanked: 82
    Very cool project.
    If seat going that low I would consider making the lower section of the seat longer for more leg support or add an extension section to adjust according to driver needs.
  8. #126
    Thanked: 510
    Made a set of dimple dies.....Click image for larger version.
    Prototype kinda works.... now to do it outta 2mm aluminum
  9. The Following User Says Thank You to GaryFrank For This Useful Post:
  10. #127
    Sep 2015
    Thanked: 184
    Found on Speed and Sound's Facebook page (17 April 2015)
  11. #128
    Thanked: 510
    That is sweet...there are some pretty good rods in SA (and then there’s some really nasty ones)
  12. #129
    Sep 2015
    Thanked: 184
    This one gives a whole new meaning to skid pan.
