Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 21 to 40 of 129
  1. #21
    cape Town - 0624206806
    Thanked: 514
    Default Re: My next project......
    the whole idea of doing a “project”, is to spend as little as possible ( well in my case )
    I have:
    BMW 318i.... man & auto box, complete wiring loom & all electrickery -just missing the starter & flywheel
    2,6 side valve ( fitted in my Tug- running and works once in 3 months when I need to move Landys in the yard) I also have a 3lt Weslake head & 28 degree dizzy which will push it past the 3,5 V8
    2,5 Falcon diesel & LT95 box
    3,5 V8 & LT95......
    To me the 2,6 side valve had got the best “sound”....
  2. The Following 2 Users Say Thank You to GaryFrank For This Useful Post:
  3. #22
    Dec 2014
    Thanked: 2862
    I have:
    3,5 V8 & LT95......
    Eh, past 118kWOr is it those low-fat post P5/6 jobbies you refer to?
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  4. #23
    Thanked: 17104
    It's the pathetic 100kW defender engine.
    Jakes Louw
  5. #24
    Dec 2014
    Thanked: 2862
    Ah, the ones that convert petrol into noise....
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  6. The Following User Says Thank You to JohnnoK For This Useful Post:
  7. #25
    Thanked: 17104
    Indeed. The Converter V8.
    Jakes Louw
  8. #26
    Thanked: 514
    Weslake conversion :
    Weslake head(1966-67)
    swept engine volume: 2625cc
    cylinder bore: 77.8mm
    piston stroke: 92.1mm
    compression ratio: 8.8:1
    power: 123bhp at 5000rpm
    torque: 142ft lb at 3000rpm......
    Rover 3.5 V8: 118bhp....
  9. #27
    Dec 2014
    Thanked: 2862
    And, the SOUND of the 6 through a cherry bomb...
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  10. #28
    Thanked: 514
    Got the suicide front end boxed up.....next is the back axle, and then the chassis Click image for larger version.
ID:	590915Click image for larger version.
ID:	590916Click image for larger version.
ID:	590917Click image for larger version.
  11. #29
    Dec 2014
    Thanked: 2862
    Looking good, man!
    Must come around and critique for you....
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  12. #30
    Thanked: 514
    Default My next project......
    Just had a brain fart......sitting at home waiting for the garage door motor replacing dude and was looking at the drawings of the front end again.....
    My whole problem was that the connecting rod was is the way of dropping the spring behind the I beam, so I opted to mount above the axle. I looked at reversing the whole axle to get the connecting rod in front, but this would interfere with the caster angle ( easy fix -tilt the axle to compensate) and the Ackerman steering geometry..... not such an easy fix.
    Looking at the drawings today, I thought of anti-Ackerman.... all the F1 cars are doing it cos it gives a higher slip angle (more traction in corners)
    looks like it’s back to the drawing board
  13. #31
    Thanked: 514
    Finally got a chance to do a bit of work....
    Some 5 x 40 reinforcement- don’t want the front axle mounts shearing off ( V8 power and all)
    Started welding up the back rails....Click image for larger version.
  14. The Following User Says Thank You to GaryFrank For This Useful Post:
  15. #32
    Thanked: 514
    Just about done with the rails....Click image for larger version.
ID:	594337Click image for larger version.
ID:	594338Click image for larger version.
ID:	594340Click image for larger version.
  16. The Following 3 Users Say Thank You to GaryFrank For This Useful Post:
  17. #33
    Dec 2014
    Thanked: 2862
    Nice going, Gary!
    I like the table....
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  18. #34
    Thanked: 514
    I’ve got about 6 of them.....
    Some guy (can’t remember his name) just left them in my shop ....
  19. The Following User Says Thank You to GaryFrank For This Useful Post:
  20. #35
    Thanked: 514
    Just gonna put this here .......Click image for larger version.
    Sad thing is that it’s gonna get covered by the gusset plates
  21. The Following User Says Thank You to GaryFrank For This Useful Post:
  22. #36
    Dec 2014
    Thanked: 2862
    Sod's Law isn't it? Your first decent weld and you have to grind it flat and hide it.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  23. #37
    Thanked: 514
  24. #38
    Dowerglen
    Thanked: 1125
    Oh that is so nice, real steel and all on the forum... finally...
    Regards - Marco Chezzi
    There are two kinds of people in this world, those that can extrapolate from incomplete data..
  25. The Following User Says Thank You to Marcochezzi For This Useful Post:
  26. #39
    Thanked: 514
    I’m looking for a Rover V8 to 21R gearbox bell housing ( or adaptor plate)....
    Anyone other than the “just buy one from Gilo” option
  27. #40
    Dec 2014
    Thanked: 2862
    Do the gearbox on Puttanesca and you will have a suitable bellhousing, then, make and adapter plate.....
    I told you I will help you do the job, stop being lazy...
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
