Namibia re-opens to international tourists 1 Sept
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 49
    WC
    Thanked: 340
    Default Namibia re-opens to international tourists 1 Sept
    https://www.eturbonews.com/580591/na...onal-tourists/
    They require a negative Covid test no older than 72 hours.
    www.namibiatourism.com.na
    2004 Jeep Grand Cherokee 4.7L V8
  2. The Following 2 Users Say Thank You to Chuckzoo For This Useful Post:
    Apr 2019
    Thanked: 946
    Default Re: Namibia re-opens to international tourists 1 Sept
    So very much looking forward to getting back there. Just need SA to play ball.
    Gansbaai
    Thanked: 348
    From the linked article
    "As from 01 September 2020, Namibia re-opens the Hosea International Airport to international tourists. This is a targeted initiative for leisure travelers and will be reviewed bi-weekly and amend as necessary."
    and so on.
    It refers to the Namibia tourism website, also linked, but at Namibia tourism, the updates of the regulations seem to be lagging behind.
    Does anyone have a proper link to the most recent and ***gazetted*** Namibian regulations?
    In any event, Vioolsdrif/Noordoewer is still closed for tourism.
    Swakop
    Thanked: 932
    still no incoming flights though...
    and the local covid test is still putting people off.
    No mention on road borders yet.
    Walter aka "Meerkat"
    slightly modded 02' 105 series 1FZ-FE
    https://www.facebook.com/kepanamibia/
    My heart beats to an African Bush drum...
  6. The Following 2 Users Say Thank You to AboutAfrica For This Useful Post:
    Gaborone
    Thanked: 1068
    As far as good-will is concerned i'ts a good initiative.
    However the practicalities are less than favourable for the visitors.
    Considering the average duration of a typical European tourist (2-3 weeks) and the target to see the country as a whole, the 7 days quarantine should put most of them off for wasting their time.
    I doubt very much that government approved quarantine locations will include Etosha or Sossus Vlei, not even Swakop.
    They would be holed up at some place in Windhoek with nothing to do but watching advertising on TV.
    Walter Rene Gygax
    Kalahari Safari
    ORRA Call:​ WB58 | ICASA ZRF430
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  8. The Following User Says Thank You to Kalahari Safari For This Useful Post:
  9. #6
    Okahandja, Windhoek
    Thanked: 911
    Quote Originally Posted by Kalahari Safari View Post
    Looks like some flights will start soon.
    Results from test done by the Authorities takes up to 5 days, so you are 7+5 days in quarantine.
    Johan Kriel
  10. #7
    Gaborone
    Thanked: 1068
    Showstopper then
    Walter Rene Gygax
    Kalahari Safari
  11. #8
    Apr 2014
    Thanked: 12
    Quite a disappointment that one can visit Kgalaghadi but not camp on the Botswana side. One would have thought that as long as one enters and exits at Tweerivieren and does not exit at either the Namibian or Botswana gates that this would be allowed. I verified this to be correct earlier today with Sanparks.
    Alan H
    Toyota LC #3
    Conqueror camper #3 a Companion
  12. #9
    Thanked: 4171
    OK, just some context:
    1. Upon arrival at the Hosea Kutako International Airport, the tourists proceed to the pre-booked destination and engage in the planned daily tourist activities at the facility for the number of days the tourist is staying there.
    1. If the tourist intends to spend less than five days at the pre-booked facility, the tourist can proceed to the next destination. However, on day five (5), the tourist must be available for swabbing wherever they find themselves.
    1. The tourist must be reachable on day seven (7) to receive the results of the swabbing.
    1. If the result is negative, the tourist is released from any surveillance. If the result is positive, the tourist will be taken to the isolation facilities identified by the Ministry of Health and Social Services and treated at their own cost and according to national case management guidelines.
    Last edited by Nys; 2020/09/10 at 04:07 PM. Reason: Aligned with doc Walter posted
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 105
    Bush Lapa Boskriek 816
  13. The Following User Says Thank You to Nys For This Useful Post:
  14. #10
    Swakop
    Thanked: 932
    1. You can travel to your intended destination immediately. You must just ensure you are available for a test and remain at first destination for 5 days.
    2. You can do all planned activities at destination, as long as you remain contactable
    3. After tested, you can travel to next destination as long as you remain contactable
    4. If tested positive, you must be quarantined.
    NB: above typed from memory, so days might be wrong, but it is no longer 7 days. Will find regs and publish it
    See attached.
    Problem is yes if you are tested positive. Other problem is how does the test get done?
    It is at least a step in the right direction, but still too many questions.
    Also for overseas visitors we are still off the books as we are still on the high risk list, so most of them have to do a 14 day quarantine when they return home.
    Holding thumbs though
    Attached Files Attached Files
  15. The Following User Says Thank You to AboutAfrica For This Useful Post:
    Nys
  16. #11
    Garsfontein
    Thanked: 625
    Just curious. I've passed through Namibia quite frequently on the way to or back from places. For example: a year or two ago, I headed back from the North West ZA coast, overnighted in Oranjemund and clocked back out to ZA at Rietfontein the next day. Likewise, I'm considering a trip to the Northern Cape again shortly. The original idea was to head there or return via Nam. The lockdown has changed a bunch of plans, and the lack of lockdown might change them again.
    Anyways, without derailing this thread too much.
    Tansit travel. ie: Clock in via road at border X and out at border Y on the same day. Is it allowed ?
    Edit: Yes - I know that ZA borders must also be open.
    Ian de Villiers
    Nissan Patrol GRX 4.5
  17. #12
    Jan 2019
    White River
    Thanked: 26
    From what I understand you have to stay at 1st destination for 7 days. You will have to stay at border y for 7 days before proceeding.
  18. The Following User Says Thank You to desdrake For This Useful Post:
  19. #13
    May 2012
    Thanked: 174
    Quote Originally Posted by AboutAfrica View Post
    See attached.
    So is there any further detail on this from our honourable leaders?
    My mother-in-law wants to come and visit from SA from 1 Oct to 4 Oct, so the way I have it is that she needs to get a COVID test while here so that she can re-enter SA, but that Namibia does not require that if she is staying for less that 5 days?
  20. #14
    Swakop
    Thanked: 932
    no new news. Current regulations still stand until we hear something new.
  21. #15
    May 2012
    Thanked: 174
    Thanks Walter - so my understanding is correct that she can just fly up to Nam, stay with us for those couple of days, get tested while here in Nam and then fly back without having to go into quarantine (unless she tests positive of course)
  22. #16
    Apr 2019
    Thanked: 946
    Quote Originally Posted by Lou07 View Post
    Except that nobody is operating flights direct. Right now, she'd need to go via Addis Ababa on Ethiopian... Not exactly direct.
    Air Namibia may resume at some point. SAA and COMAIR (BA) are not operating.
  23. #17
    Robertson
    Thanked: 446
    So the state of emergency has been lifted it seems
    Heard from my family there that some regulations will remain and will be reviewed in 14 days or something to that extend
    Some car, some bike and two legs
  24. #18
    By the sea
    Thanked: 78
    I would not rush to start ravelling, yes we have been home bound for along time but the reality is Covid-19 isnt over, just because borders are opening up doesnt mean that you re now safe against the virus, it is still very real.
  25. The Following User Says Thank You to Raider4x4 For This Useful Post:
  26. #19
    Mar 2016
    Thanked: 2204
    Quote Originally Posted by Raider4x4 View Post
    Also, Covid is no reason to not travel. Life is short, something will kill you. Might as well enjoy life
    Andr Opperman
  27. The Following 2 Users Say Thank You to Oppies3800 For This Useful Post:
  28. #20
    Jan 2009
    Potchefstroom
    Thanked: 341
    Just a question - will it be more dangerous to travel to a country with the same infection rate, than it will be to go to the local packed and overcrowded mall or shop? If you observe the same precautions as you did at home in SA, you should be fine.
  29. The Following User Says Thank You to Sias For This Useful Post:
