Erratic EGT on Madman
Results 1 to 20 of 22
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Default Erratic EGT on Madman
    Just took a drive now and saw that I now have an erratic EGT reading.
    It's all over the place 200°C to 1200°c and back in a matter of seconds.
    Driving at 90Km/h in 5th gear.
    No other issues and everything sounds fine.
    So where do I start?
    Thermocouple wiring?
    Mar 2013
    Thanked: 431
    Default Re: Erratic EGT on Madman
    My Water temp reading is also jumping 5 or so degrees.
    From what I have read the first place to start is the earthing points.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -Land Rover Defender 110 Td5
    -BMW F800GS
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Mine just gave a message "Check sensor"
    So might be probe or wiring.
    Thanked: 175
    Earth and where that flimsy paddle clip attach to the probes.
    I was forever having to crimp them tighter, in an effort to avoid that horrifying shock and sinking feeling when that peep-peep-peep starts!
    '00 Nissan D22 QD32Ti 4x4 D/C
    '10 Toyota LC150 4.0V6 VX
    Thanked: 96
    Jfh
    On the egt reading mine does that every now and then and a good squeeze / push of the connector block coming into the madman unit fixes it
    On the erratic water reading the connector on the actual sensor is probably a spade terminal - just nip it up with a pair of pliers or a bit of a twist also helps
    I wish they had left a hole in the top of the water temp sensor so one could screw it in place instead of relying on the spade terminal retaining its stiffness
  6. The Following User Says Thank You to RossJ For This Useful Post:
    Nov 2011
    Langebaanweg
    Thanked: 1216
    All other readings stable, so I'll check out the thermocouple wiring harness and connections.
    Thanks.
    Hopefully easy fix.
    Out of Town
    Thanked: 741
    Jfh
    Mine does the same on the boost sensor connector. Fiddling with the cable block sorts it out. And I havr had a look at the plug to if there is something I can fix, but can't find anything. Not very impressed with the plug on the rear of the madman, nearly all the wires are stripped back too far, so you have a tiny bit of copper exposed outside of the rear of the block. I thought of setting it in some resin, but with my luck, I set it in the faulty position, and that will be the last time I have a boost gauge.
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Removed the plug behind the display and sprayed with contact cleaner.
    After test drive everything seems fine.
    Thanks for helping.
    Apr 2014
    Thanked: 131
    I did not spray anything. I just wiggel it a bit and then it is fine again.
    Thanks for helping.
  11. The Following User Says Thank You to LdLL For This Useful Post:
    jfh
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Did some driving today, 50% gravel and the fault is back.
    Tomorrow I will check the thermocouple connections as well as the plug again.
    Last time it also came up with some gravel travel.
  13. #11
    Nov 2011
    Langebaanweg
    Thanked: 1216
    I removed those stupid crimp connectors and soldered the wires.
    I must admit the thermocouple wires didn't solder that easily and after soldering my EGT was at -34°C.
    All was back to normal after a smoke break.
    The pins on the display and the multi plug were cleaned with a very fine wire and screwdriver. I could see the change in colour as I removed some deposit on them.
    Only time will tell if this was successful.
  14. #12
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Nope! I wasn't successful.
    Maybe it's the probe. I'll contact Madman and hear what they think.
  15. #13
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Brian Cotton from Madman just answered my query and confirmed that my thermocouple is shot.
  16. #14
    Nov 2011
    Langebaanweg
    Thanked: 1216
    Okay... So here's my current way of thinking.
    The original way of fitting the thermocouple is at 90° to the blanking plate.
    For the thermocouple to go to the right place it has to be bent.
    This might lead to the thermocouple failing. I never felt comfortable with bending it and it looks like it can be done.
    So my next project will be to make a blanking plate that can hold an unbended thermocouple onto the right position.
    Something like this.
  17. The Following User Says Thank You to jfh For This Useful Post:
  18. #15
    Out of Town
    Thanked: 741
    Mine is also too long to fit in its spot, but I was told it can protrude out the back a bit. I drove out to their workshop and checked with them that it is acceptable. What I was worried about, was that the probe bottomed out against the opposite wall, and could possibly pick up some shock or unfair vibration from being seated too deep. So I insert mine, and lift it out a "smidge".
    What was a shock for me in February, was, on replacing my probe, I could not extract it from its fitting as it had melted into a blob which could not pass through the hole. To add insult to injury, the darn screw in fitting stripped, and for no love or money could I get it out of its hole. In fear of leaving something behind in the manifold, I had to strip off the turbo to access the pickup from inside. It was mounted in a horrible place, so I took the oppertunity to weld up the old hole, and drill and tap a new one on a much thicker portion of the outlet right on the turbo flange.
  19. #16
    Nov 2011
    Langebaanweg
    Thanked: 1216
    So to do this...
    I'll need to get the correct angle for the thermocouple.
    So I made this.
    I know! It ain't pretty, but it must only work for 10 minutes.
    The pin swivels on a shaft so that I can determine the angles where the pin touches the top and bottom of the manifold.
    I'll get the centre of the 2 angles to place the thermocouple.
    I don't want to thumb suck this.
  20. #17
    Thanked: 545
    Most thermocouples can be bent a reasonable degree.
    Most have the sensing part at the very tip.
    Inside is two wires of different metals
    Inside those wires are protected normally by a powdery substance.
    So a careful bend will do nothing wrong.
    A very sharp bend with pliers will give you problems and kink.
    So the two different metals are joined at the very tip.
    Mine in the Kalahari is bent and running a few years without issues.
    Are we using type K or type J thermocouples.
    Defender Kalahari
    Series 3 SWB
    Series 1 De Luxe Cab Pickup
    Series 1 Station Wagon 88''
  21. #18
    Nov 2011
    Langebaanweg
    Thanked: 1216
    K-type.
    I know they can be bent. I just don't like it and it gives me a new project to keep me busy with.
  22. #19
    Thanked: 545
    Mmmm. Typical Kalahari owner. You do realise i have to copy you AGAIN
    K-type.
    Defender Kalahari
    Series 3 SWB
  23. The Following User Says Thank You to imgreg For This Useful Post:
    jfh
  24. #20
    Nov 2011
    Langebaanweg
    Thanked: 1216
    This is where it failed. It's about 100mm from the base of the thermocouple.
    So I assume it's because of vibration/chaffing.
    Now as I'm not the richest guy around and I have time on my side, I'll try a repair until I can buy a new one.
    I've tested it off vehicle,now I'll install it and see.
