Amarok Steering Wheel Upgrade
Results 1 to 14 of 14
    Aug 2020
    Leeds
    Default Amarok Steering Wheel Upgrade
    Hi All,
    Read a few threads but nothing really has the specific answer. Is a MK6, 7 and 8 Golf Steering wheel and Airbag a direct plug and play recplacement for the standard Amarok? Heard as well if it has paddle shifts it will also work out of the box?
    Just worried the airbag may not fit the plug, or I will need to replace more then originally planned!
    Any direct help will be appreciated!
    V6 Amarok, so 2017+
    Many Thanks
    Simon
    Dec 2013
    Thanked: 571
    Default Re: Amarok Steering Wheel Upgrade
    Yes it is. The plugs are all the same.
    So if you have a MFSW in your vehicle it's a simple 20 min excercise.
    Just note that the cruise control on the steering wheel won't work on the amarok, it will stay on the stalk as the amarok uses a different body control module with physical wires from the steering column to the BCM for cruise control and not activated via can-bus.
    I fitted a 2017 polo steering wheel in mine. I didn't have a MFSW so had to add some wiring in the steering column. My CC buttons on the steering wheel is just dead as explained above. I have heard of Golf 6 an Golf 7 steering wheel being fitted with no issues.
    Jul 2017
    Paulshof
    Thanked: 209
    Interesting.
    Nothing wrong with Amarok steering wheel but a MK7 R or GTI steering wheel would look great.
    2018 VW Amarok V6 Auto 4Motion
    2011 VW Golf GTI DSG
    2007 VW Golf GTI
    2003 VW Citi Life
    Dec 2013
    Thanked: 571
    Quote Originally Posted by Ooba View Post
    Interesting.
    Well that depends. Specify which amarok.
    I had the first steering wheel in my 2011 without controls. Went for the new design with controls and flat bottom. Huge difference!!
    Also if you want paddles on the auto you can switch out for one that has got it.
    Aug 2020
    Leeds
    This is excellent thanks! Didn't know the polo wheel fit as well, pretty sure they come in cheaper.
    Golf wise then anything MK6 and above will fit!
    Flat bottom is what we all love...
    JHB
    Thanked: 131
    As per Willems answers above, Golf 6/7 and Polo TSI shape steering wheels fit perfectly, airbag and MFSW plugs and all.
    I have a polo GTI / golf 6 steering wheel in my 2012 Amarok.
    Needed to lay 2 new wires from the slipring to the BCM to get it all working.
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  7. The Following User Says Thank You to JohnBoy For This Useful Post:
    Aug 2020
    Leeds
    Looks awesone! How come you needed to run new wires then? Was this for something additional/you didn't have before?
    Is that the original airbag then or do you need to make sure you get a steering wheel specific airbag?
    Thanks for all the help so far it's appreciated!
    Simon
    Dec 2013
    Thanked: 571
    Quote Originally Posted by Betty02 View Post
    Simon
    Airbags are mostly steering wheel specific.
    Both my and Johns amaroks didn’t have mfsw’s so we neede to add a ln and 12v wire.
    If you already have a mfsw then it’s a bolt off bolt on exercise. Your old airbag should fit some of the steering wheels but it will need a different wiring harness inside that can connect the control module aswell and not just the airbag.
    Oct 2017
    Rustenburg
    Thanked: 3924
    The Ford guys put Raptor stickers on... But you guys tune your 'dubs with a GTi steering wheel!!! Sweet.. Bru
    Andrew van Staden
  11. The Following User Says Thank You to Hedgehog For This Useful Post:
    Aug 2020
    Leeds
    Quote Originally Posted by WillemT View Post
    This is great, will try get a wheel with an airbag, think it's better to keep it plug and play and keep the old if I was ever to reverse it!
    Thanks for this!
  13. The Following User Says Thank You to Betty02 For This Useful Post:
  14. #11
    Dec 2013
    Thanked: 571
    Thanks for this!
    Did exactly the same, kept my old one in a box, to just swap back...
  15. #12
    Apr 2011
    PTA/BALLITO
    Looks Great, thanks for the idea need a wheel with no buttons BUT looks the part will suit my interior
  16. #13
    JHB
    Hi
    I would really appreciate some imput and guidance, I swapped out a non-mfsw on a treadline amarok for a mulitfunction wheel. But although two of the buttons cause the radio to react, most the buttons don't work.
    I added in the two wires advised.
    Maybe the wrong steering wheel ? I notice the buttons are a bit different.
    Any ideas?
ID:	588591   Click image for larger version.
  17. #14
    Jul 2017
    Paulshof
    Thanked: 209
    Quote Originally Posted by Monroe View Post
    Hi
    Any ideas?
    That's the steering wheel the facelifted Amarok Highline comes with.
    2007 VW Golf GTI
    2003 VW Citi Life
