Land Rover Trailer
Results 1 to 10 of 10
    Jun 2015
    Thanked: 12
    Default Land Rover Trailer
    Go day all
    I have a 110 load bin that I have made into a Trailer to pull behind my Defender 300TDI. The rear differential
    Is still in but I would like to remove it and put a axle.
    What size axle do I get?
    Swakop
    Thanked: 888
    Default Re: Land Rover Trailer
    You going to have a hard time finding a axle which is the same strength and gives less hassles. Personally I would keep the axle.
    Walter aka "Meerkat"
    slightly modded 02' 105 series 1FZ-FE
    https://www.facebook.com/kepanamibia/
    My heart will always beat to an African drum...
  3. The Following User Says Thank You to AboutAfrica For This Useful Post:
    Nov 2018
    Mukifu
    Thanked: 582
    Quote Originally Posted by calitzfamily View Post
    Go day all
    I'd keep it complete, easy way to carry spare drive members, side shafts etc.
    Like About said you'll find it hard to find a stronger axel.
    Neil Rocher
    1997 2.8i Defender 110 (Fats)
    1996 300 TDI Defender 110 (Aqualung)
    1982 Mog 416
    1971 series 2a 109"
    1968 FJ40 (Piglet)
    1967 series 2a (dugudugu) 88"
    1958 series 2 (Betty) 88"
    1955 series 1 109"
  5. The Following 2 Users Say Thank You to 2.8i rocks For This Useful Post:
    Thanked: 257
    add a alternator to the diff output for a free battery charging system
    D90
    D130
  7. The Following User Says Thank You to D-tox For This Useful Post:
  8. #5
    Thanked: 15116
    That's a 109 load bin and has leaf springs.
    And doesn't an alternator need higher revs?
    Jakes Louw
  9. #6
    Thanked: 297
    Don't spoil the non existent free lunch.
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  10. #7
    Apr 2018
    RSA
    Thanked: 1098
    Considering wheel size and the 4.7:1 diff ratio, at 60 km/h the propshaft will be doing around 2000 RPM. A crankshaft pulley on that with a belt to a standard alternator will easily charge the battery.
  11. The Following User Says Thank You to Olyfboer For This Useful Post:
  12. #8
    Jan 2014
    Heliport
    Thanked: 292
    Go day all
    Why is it leaking oil?
    Using Tapatalk
  13. #9
    Dowerglen
    Thanked: 864
    mistake - apologies
    Regards - Marco Chezzi
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  14. #10
    S-West/Stellenbosch
    Thanked: 50
    I am sure you will get an axle within acceptable width from trailer parts suppliers like Burquip. The 5 bolt flange might be a problem.
    The advantage of the trailer axle will be less weight and more importantly you can get a braked axle. this will allow you to go higher than the unbraked limit of 750kg. You will not have a lot to spare with that ladder frame and axle.
    I would consider taking all the innards out of that axle, if you intend keeping it, for rolling resistance and weight.
