Gearbox Identification Help Please?
Results 1 to 4 of 4
    Mar 2017
    Grahamstown
    Default Gearbox Identification Help Please?
    Good day to you all
    Can you guys please help me identify this gearbox? It is in a 1992 Toyota Surf LN130 - but the original gearbox was an automatic. Now it has this...
    It looks like a toyota gearbox. The transfer lever is behind the gear lever if that helps?
    As you can see, i need to get another speedo drive gear. this one was modified to work with the electronic speedo (which obviously is no longer the case).
ID:	583901   Click image for larger version.
ID:	583902   Click image for larger version.
ID:	583903   Click image for larger version.
ID:	583904   Click image for larger version.
ID:	583905   Click image for larger version.
    Kathu
    Thanked: 3021
    Default Re: Gearbox Identification Help Please?
    Looks like a W56 from a SFA Hilux
    Mar 2017
    Grahamstown
    OK, did a bit more searching and came across these links below. I think it might be a G52 box (please correct me if I'm wrong), due to the fact that the filler plug is just below the gear lever - same as in the G52 picture from Marlin Crawler.
    The G56 filler plug is in the front housing part?
    https://www.marlincrawler.com/transm...t-complete/g52
    https://www.marlincrawler.com/transm...complete/w56-c
    Also, on the left hand side of the gearbox, the reverse light switch is just forward of the lower plug (the ones with the spring and ball behind it).
    Kathu
    Thanked: 3021
    You could be right. Very difficult to identify Toyota boxes. The G52, W56, R151 are all look a like. They differ in size and some small details. Not easy to identify from a Pic if you does not have a top view
