The hinge linkage for "The Coffin" on my trailer
Results 1 to 5 of 5
    Thanked: 1905
    Default The hinge linkage for "The Coffin" on my trailer
    The previous box on my trailer was hastily made from plywood one year before a December holiday.
    I knew that was not permanent, but at that time I had little choce.
    I now had a box made up from a light angle iron framed and cladded with Aluminium Checkered plate.
    I did not want straight hinges, as the problem with that is that it usually damage the sealing rubber over time.
    This linkage in effect puts the lid down from the top so that it does not rub the seals, and secondly, I had to make it go over the side in order to miss the external cage of the trailer.
    The linkage was designed on a link simulator and works very well. Perfectly balanced one can open an close it with the palm of your hand up or down.
    Now I can have all the camping goodies like the tent, stretchers and chairs safely kept in the trailer, locked, water tight and no entry for vermin.
    Something I should have done a long time ago..
    https://www.youtube.com/watch?v=2iR40gbTJH8
    1999 Discovery 1, 300 Tdi - "Tink Tanky"
    2004 Discovery 2 Td5 - "Blink Tanky"
    "Logic is a systematic method of coming to the wrong conclusion with confidence."
    "A technician will let a system degenerate to the level of his understanding and maintain it there."
    "...it is abundantly clear that you are an arrogant C-nut." - Estee. (I was overwhelmed. It was the nicest thing someone has said to me in a week!)
  2. The Following User Says Thank You to biltong For This Useful Post:
    Rangeview Krugersdorp
    Thanked: 1319
    Default Re: The hinge linkage for "The Coffin" on my trailer
    Very nice indeed !
    Ford Figo 2016
    Apr 2012
    Thanked: 1318
    Looks great.
    Errol Cornelius
    Citroen C5
    Touareg V8
    Audi A6 3.0 Avant
    Ballito
    Thanked: 11
    Quote Originally Posted by biltong View Post
    Perfect. Well done. Just one thing, Turn the gas strut upside down to ensure internal lubrication.
    What simulator did you use?
    HiLUXURIOUS
  6. The Following User Says Thank You to pclouwrens For This Useful Post:
    Thanked: 1905
    Quote Originally Posted by pclouwrens View Post
    Was not aware of that.
    Simulator: https://blog.rectorsquid.com/linkage...and-simulator/
