2020 Jimny Shocks
Results 1 to 16 of 16
    May 2007
    Langebaan
    Thanked: 113
    Default 2020 Jimny Shocks
    My daughter bought a new Jimny.
    Has 241 km on the clock.
    First thing is the rear is already hanging to the right, 5mm lower on the right than the left.
    Other thing is I am not impressed with the shocks. If I sway the car at about 80 km/h it keeps on swinging for about 2 to 3 cycles before it stops swaying.
    Pretty much the same behaviour as a car with worn shocks. I removed the shocks, they are KYB gas shocks and they feel a bit pap, but then again I am used to working with Hilux, Cruiser and Willys shocks, do not know how tight a Jimny shock must be.
    I considered replacing the shocks but all the spare shops we phoned this week say they do not stock shocks for the New Jimny yet.
    That is one of the reasons I removed them today, to measure them.
    I think they might be the same size as the previous Jimny.
    Is there anybody with a shocks catalog with sizes or with a set of previous Jimny shocks so we can compare?
    Rear:
    KYB 41700-78R00
    Length centre to centre = 450
    Eye/Eye - ID of eye is 12.1mm
    thickness of eye is 32mm
    Travel = 150mm
    Dimensions of vehicle itself:
    When rested on floor with shock removed:
    centre to centre is 415mm
    Max length is 500mm
    Front:
    KYB 41600-78R00
    Eye/stud
    Length centre of eye to bottom of stud = 410
    Stud is 10mm thick and 50mm long
    Travel = 130mm
    The stud has a bush on it.
    Bush OD is 13.6 and is 28mm long and fits the 10mm stud
    Rubbers for top mount on the bush is ID=14 OD=30 and thickness = 14
    Size of bottom eye is the same as the rear shocks.
    Dimensions on vehicle itself:
    Centre of eye to bottom of top mounting is 365mm
    Max length is 460mm
    1999 Hilux Raider 4x4 2700i, 'n groene met swart tyres
    19 Voertsheck Jeep CJ5 Built on 1984 Nissan Safari mechanics
    2011 Touareg 4.2 V8 Diesel.
    Series IIA Landy being Rebuilt (for the past 4 years)
    1963 Willys Traveller
    Pretoria East
    Thanked: 283
    Default Re: 2020 Jimny Shocks
    Quote Originally Posted by pietpetoors View Post
    Rear:
    KYB 41700-78R00
    Travel = 150mm
    Max length is 500mm
    Front:
    KYB 41600-78R00
    Eye/stud
    Travel = 130mm
    Max length is 460mm
    Previous gen 3 Jimny had pin/loop type front shocks while the gen 4 has a pin/pin setup up front. Lenghts I only have for lifted applications but the Gen 4 fronts are 10mm shorter than the Gen 3 while the Gen4 rears are some 15mm longer than the Gen 3. Not a good fit then.
    For the sag/lean, as a start pick up an Emu trim packer for the RHS front from the Somerset/Paarden Island MW or I can send them to you via Louis/Dawie in your Centurion store. Even dealers are resorting to packers given the low cost of resolving client complaints. If the front one alone does not fix the lean, chuck one in the RHS rear also.
    Proper shocks (and ideally coils) should solve that pogo stick effect.
    Parys
    Thanked: 30
    Most probably a stupid question, but with your new Jimny, and only 200 + kilometres covered, surely you should consider this as factory fault or warranty case? I'll be back to the dealer so quickly, they won't know what hit them!!!
    1984 SJ 410 ("Ben Laden" ) sold
    2013 Jimny ("Seuntjie") Wizerd rock sliders and underwear, Steering damper
    2011 Suzuki Grand Vitara 2.4 ("Moeder") DASTEK chip (Sold)
    2010 Audi S3 ("Silvo")
    2013 VW Touareg V6 TDi ("Geit")
    2 bicycles ("Blitz" and "Monstrosity")
    2014 SYM 300i GTS Scooter ("Babatjie")
  4. The Following User Says Thank You to Nico Wassermann For This Useful Post:
    Thanked: 15067
    KYB is a good brand.
    Thanked: 1525
    Quote Originally Posted by Nico Wassermann View Post
    If he removed it, warranty is ka-poof!
    Sent from my iPhone
  7. The Following User Says Thank You to Rebel 4x4 For This Useful Post:
    Parys
    Thanked: 30
    Agreed! But, I always revert back to the dealer first .... same subject, but different application. My caravan had a similar problem and after 2 years still got the manufacturer to accept responsibility - now that is good service!
    Thanked: 1525
    Agree, take back to dealer. Don’t remove shocks.
    Sent from my iPhone
    Oct 2012
    Thanked: 89
    Why do you remove the shocks to test them? the car is still under warrenty?
    Omly reason to remove is to directly replace with Gabriel safari Hdp.
    Use the same as the gen3 (jb43).
    no spares shop will say they keep gen3 or gen4 parts for it. cause it is not a Toyota or a vw where you can get parts via a kfc drive through.
    google Search for the Gabriel catalog, you will find the part number there, or just contact De-sol and he will supply with gabriel safari hdp's, if you are still not happy with your Suzuki dealer's response.
    Oh.. and definitely do not tell them you removed the shocks your self.. that is good bye suspension warranty.
    Explain your problem to dealership workshop foreman. and also go and test another Jimny..
    May 2007
    Langebaan
    Thanked: 113
    Last week we chatted to 3 clients with new Jimnies and all experience the same.
    So dealers will either tell me it is normal and nothing wrong or they will replace it with the same shocks.
    But I guess you are right, we should first try them and see what they say.
    Jan 2007
    Thanked: 330
    Quote Originally Posted by locklaw View Post
    Not correct. The shocks on the gen 4 are the same configuration as on the gen 3. The lengths may be different.
    Vic
  13. #11
    Jan 2007
    Thanked: 330
    Rear:
    KYB 41700-78R00
    Travel = 150mm
    Max length is 500mm
    Front:
    KYB 41600-78R00
    Eye/stud
    Travel = 130mm
    Max length is 460mm
    A lot of us have had good results with the setup from Des-Sol. I don't think it is even worth the effort to try and get Suzuki to fix it.
    Vic
  14. #12
    May 2007
    Langebaan
    Thanked: 113
    As expected.
    Took it to Suzuki today , they phoned and said nothing wrong I can collect. I asked the mechanic if he loosened the shocks and felt how stiff they are or if it had any play, he said no need to do it. He checked, they not leaking oil and normally if something wrong with the shock it will leak oil. Point, end of story, visual inspection is enough.
    Another two arguments were:
    1. It is normal because they all do it.
    2. It is normal because it is a 4x4.
    He cannot tell me exactly what part of warranty will fall away when I replace shocks and springs but will find out and let me know.
    Sadly car is going to its new home in Pretoria next week. I hoped to sort it out before the two ladies take the long road back.
    Will replace shocks and coils some time while it is in Pretoria, am now very curious to feel the difference with proper shocks and coils.
  15. #13
    Mar 2009
    Wonderboom Pretoria
    Thanked: 55
    Experienced the same in my girlfriend's Jimny, loaded on the N4 at different speeds and it scared her so much that she wanted to get rid of the Jimny! Then I searched the internet and realized that it is the stability control and not the shocks.......
    Suzuki Jimny stability control 'phantom skid' problem uncovered
    Autocar test reveals unusual problem with 4x4's ESP system, confirmed by Suzuki, but no recall is currently planned
    Once alerted, Suzuki immediately despatched additional engineers to the Angeles Crest Highway near Pasadena, California, to investigate. They were able to replicate the behaviour, but have not been able to reproduce it at the company’s test facility in Japan.
    In a statement, Suzuki has said that "the continuous activation" of stability control occurred "when a specific road condition, tilt angle in the road, incline and slope, and degree of the curve was combined with a certain level of speed."
    "There is a possibility that the (stability control) is instantaneously switched on (by) reacting to the vehicle sway when departing the S-shaped curve - and then consecutively switches on because the vehicle is circling the curve at high speeds."
    During this reporter’s test of the car, with chief engineer Yonezawa aboard, the Jimny was driven briskly not only on the particular incline and bend sequence that triggered the behavior, but along an eight mile stretch of the Angeles Crest Highway. On this longer section the nearside front wheel occasionally braked, as did the offside rear wheel.
    Suzuki has also said that ‘the intervention of the stability control may give a sense of discomfort to the driver but is not an event that would disturb the vehicle’s direction of movement.’ This would reporter would agree that the vehicle’s direction of travel remains unaltered.
    But the side-to-side rocking motion triggered by quick-repeat, single wheel brake interventions, which occurred only on one particular stretch of road taken at a speed higher than the (cautious) mandated limit, would probably alarm an inexperienced driver.
    Suzuki says that it will "further analyse the event and carefully consider how to adjust the program while maintaining the Jimny’s performance balance. Therefore, we regret to say we are unable to inform you when exactly we will be able to implement any changes to the program at the moment."
    https://www.autocar.co.uk/car-news/...bility-control-phantom-skid-problem-uncovered
    Real 4x4's don't have
    curved windscreens!!
    Jeep TJ 4l Sahara 33'
    Suzuki SJ 80 "Jeepie"
    + 2 classic roadsters
    some dangerous toys
  16. #14
    Sep 2015
    Thanked: 150
    Quote Originally Posted by Pablo View Post
    Sorry, but that is a problem with the overseas full spec Jimnys with lane control enable.
    We do not have that here, please google a bit............
    Jimny, the most underestimated 4x4xfar
  17. #15
    Mar 2009
    Wonderboom Pretoria
    Thanked: 55
    Quote Originally Posted by Gustav Jimny View Post
    "But the side-to-side rocking motion triggered by quick-repeat, single wheel brake interventions, which occurred only on one particular stretch of road"
    That is exactly what I experienced! It happened three times in a row at exactly the same two places, and only there, on the whole N4 between Pretoria and Middelburg, as well as on one spot on the N1, between Sormvoël and Zambezi off ramps. The worst was the first time, with weight in the rear.
    some dangerous toys
  18. #16
    Mar 2009
    Wonderboom Pretoria
    Thanked: 55
    "During certain cornering conditions the Jimny's ESP system brakes an individual front wheel as if to correct a skid that isn’t actually occurring. The effect is to cause the car to rock from side-to-side, as the front spring of the braked wheel compresses and expands with the pulsing intervention of the ESP. The condition can also affect one of the rear wheels."
    some dangerous toys
