Ranger Aux power sockets
Results 1 to 5 of 5
    Stilbaai
    Thanked: 92
    Default Ranger Aux power sockets
    According to the handbook, the aux power (lighter plugs) should stay on for 30 minutes after the ignition is switched off. Mine, however stays live permanently, which is a nuisance if you have to unplug everything every time you stop. Is this a setting which can be changed on a computer by the agents?
    Danie Gerryts
    2013 Nissan Patrol 4.8 GRX A/T
    2016 Ford Ranger 3.2TDCi 4x4 A/T Supercab
    Thanked: 11
    Default Re: Ranger Aux power sockets
    The Ranger has a CANBUS control system.
    Normally, the CANBUS enters sleep mode after about 15 minutes of the vehicle being locked with the remote.
    When the CANBUS goes to "sleep", the accessory functions like the auxiliary sockets should turn off.
    However, when you unlock the car via the remote, or open a door, the CANBUS "wakes up" and turns on all the accessory functions.
    To test if your socket does switch off, plug something like a USB outlet with an indication light into the socket, lock the car and check after about half an hour if the indication light is still on, without unlocking it or opening a door.
    Jan 2014
    Hermanus
    Thanked: 563
    I think on the pre-facelift models (2016) they stayed on permanently. With the facelift models, they will stay on until a door is opened.
    Stilbaai
    Thanked: 92
    I actually know that it stays on, if, for instance, I forget to unplug it, the dashcam would keep on recording until you unplug it, no matter when.
    Danie Gerryts
    Nov 2014
    Paarl
    Thanked: 50
    Quote Originally Posted by DanieG View Post
    Prefacelift it stays on permanently, Facelift you can adjust the duration it stays on by having BCM setting changed.
    2017 Ford Ranger 3.2 XLT
    ex 2013 Ford Ranger 3.2 XLT
    ex 2012 VW Polo GTi
    ex 2008 Audi A4 TDi
    ex 1998 Honda Civic Vtec
    ex 1998 Toyota Conquest RSi
  6. The Following User Says Thank You to rambo7 For This Useful Post:
