Which tyre jack. - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 55 of 55
    Thanked: 15091
    Default Re: Which tyre jack.
    What are you on about? When did I ever say a trolley jack was too high?
    Not you, some of the other guys implied that.
  2. #42
    Aug 2008
    Thanked: 43
    If you have a roofrack, build a hinged lifting arm with a boat winch.
    Damned good idea!
    Give me something to mess around with.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
  3. #43
    Thanked: 15091
    yep, a small 12v winch will work, and make it removable
  4. The Following 2 Users Say Thank You to jelo For This Useful Post:
  5. #44
    Aug 2008
    Thanked: 43
    Just been having a look and I have already welded a frame onto the swing spare bracket to take a shovel & chopper.
    I reckon I could get away with a double & a single small rope pulley (sort of yacht rigging size) bolted on to that bracket when necessary.
    12v winch type would first prize, but then TOUCH WOOD! I haven't had to change a wheel as yet.
    This thread got me to have a look at my jacking situation and my'Toyota' type wind up progressive jack extends from 210mm to 480mm. Bought it at Midas. It's also known as a 'Taxi" jack.
    '94 LC 80 GX
  6. The Following User Says Thank You to steamer For This Useful Post:
  7. #45
    Dec 2016
    Thanked: 144
    Quote Originally Posted by ed rouillard View Post
    Placing a jack stand under an axle, a common place, is in itself dangerous, although it can be pushed or slid there on hard paving.
    Off road and on a track? Not sure.
    I use a Toyota screw jack if I can. Easy, but then do not try to get under vehicle
    In passing. the LC 79 standard jack has a safe working load of 1800 kg and is 180 mm at the lowest.
    i use a piece of wood that fits under the leg of a Hi Lift jack to spread the load and fits the bottle jack as well as a spacer to lift a pumped wheel axle when needed. Has retainer lugs to stop the jack from sliding or slipping off. The jack fits on the wood and i push the jack and wood to the axle using the standard handle, which extends to allow a lift from outside the car. Simple to use and convenient. The wheel load is somewhere 950 kg per side loaded.
  8. #46
    Dec 2015
    Thanked: 17
    Quote Originally Posted by Walnut View Post
    So I had a few hydraulic jacks in my bakkie, but they always leak. I think it's cos they mounted horizontally and with all the gravel roads.
    I also have Ironman Suspension, slightly larger tyres and body lift, and I didn't want to carry a massive 10ton jack as it must fit in the standard space.
    I bought a extended 2ton mechanical jack, put it under the lower control arm etc for the wheel which needs lifting and it works great. 2 tons works fine for lifting 1 corner of the car at a time.
    Nice and small, works well if you supplement it with a hi lift. Just make sure it's the extended version.
    Attachment 583666
    I also use this on my Navara. Have a 50mm lift. Works perfectly and fits behind the seat.
    You can use the same base that you use on a highlight fir softer surfaces. And if it falls into sand, it's pretty simple to open, clean and relube.
  9. The Following User Says Thank You to King_Triton For This Useful Post:
  10. #47
    Dec 2015
    Thanked: 17
    Quote Originally Posted by King_Triton View Post
    Pic
  11. The Following 2 Users Say Thank You to King_Triton For This Useful Post:
  12. #48
    Jan 2010
    By the sea
    Thanked: 73
    Gents thank you very much for all the feedback, I settled for the 2 Ton Mechanical Jack with a max height of 385mm,cost R350.00 I will get some wood inserts made up if more height is needed,
  13. The Following User Says Thank You to Raider4x4 For This Useful Post:
  14. #49
    Thanked: 297
    Quote Originally Posted by Raider4x4 View Post
    Jelo is your ground clearance standard or lifted?
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  15. #50
    Dec 2015
    Thanked: 17
    Good on you mate
  16. The Following User Says Thank You to King_Triton For This Useful Post:
  17. #51
    Nigel
    Thanked: 2330
    Same one used on the Land Cruisers. Works a treat.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  18. The Following User Says Thank You to Henris For This Useful Post:
  19. #52
    Jul 2017
    Thanked: 173
    Works great.
    Mine had a rounded cap on top, I took a grinder to it to make it concave. Just feels more secure under the car.
    2008 Ford Ranger 3.0 XLT 4x4
  20. #53
    Dec 2009
    Thanked: 435
    With the Landy having solid axles I made this drive on Jack. I cannot remember the last time I used a jack on the landies.They also act as a trestle as they are quite stable once over the tipping point.The ones in the photo was the 1St ones. I have since redesigned and made it quite a bit stronger.
    Phillip DreyerMe Defender TD5 110 (Betty Boob) Swambo Defender TD5 90 (Komba) VW Caddy (MINIROK) Land Rover Series 2A (Lilly)
  21. The Following 2 Users Say Thank You to Disco Smiley For This Useful Post:
  22. #54
    Apr 2015
    Thanked: 292
    The toyota jack is getting alot of mentions on the various forums - will contact toyota for pricing, thanks.
    Let us know if you find attractive options.
    Discovery 1 1995 V8i 3.9l (Sold, owned for 20 years); Freelander 2 2013 SD4 SE; Discovery 4 2014 SDV6 SE; Bushlapa Boskriek
  23. #55
    Thanked: 373
    I would like to have an ARB hydraulic jack but at almost R20k a bit steep.
