Foam tape on the edges of the baskets??
https://www.builders.co.za/Fasteners...00000000407920
Hi Guys
I have my National Luna permanently installed in my Fortuna and the plastic baskets rattle around allot when driving as they are normally empty and the noise is driving me mad. Before i take the baskets out when not being used, have you guys come up with an idea to stop them rattling around when driving?
Many thanks
Jayson
2016 Toyota Fortuner GD6 Auto
2012 Jeep Grand Cherokee 3.0CRD
2011 Jeep Cherokee
2006 Jeep Grand Cherokee 3.0CRD-50mm EFS Lift, GDE Tune
2009 Jeep Rubicon-50mm Coil Lift, Branches, Free Flow, K&N, MT`s
2013 Suzuki Vitara-40mm lift
2012 Suzuki Jimny-Fully Kitted.
2007 Jeep Cherokee-Std
Lynx Bashplate
DIY Drawer system
DIY Drop Fridge Slide
My ULTIMATE dual battery box
Prestik
Some good ideas there guys, i am really looking for a solution i can just forget about after doing it, such an odd problem to have, you would think they would make it a perfect fit considering its application....
2011 Jeep Cherokee
Adhesive foam rubber tape as per SinWolf would be the best solution. But rather stick onto the fridge where the basket steps are.
The huge range in temperature the baskets have to deal with will not allow for a tight fit. You are asking for the impossible.
Put some stuff in there.
Thanks guys, I will try these suggestions, appreciate it.
2011 Jeep Cherokee
Get some water pipe for mist sprayers (black) or clear plastic as used for fish tanks. Split it and put it over the wires. Snowmasters come out with pieces of white plastic that as such on the bottom of the baskets which prevents scuffing the finish. I also keep and use a piece of high density foam to separate frozen goods from cold goods if I only need one freezer. That is also very effective.
Peter
SOMETIMES I WAKE UP GRUMPY,
Some of the NL plastic baskets are known to shrink/expand (due to moisture?)
Having said that, can you not determine where the surfaces touch - scuff. abrasion marks perhaps? that will determine you cure. Otherwise you may end up sticking those foam strips all over - and tey do tend to deteriorate given time an moisture. And may prove to hinder the cleaning of the baskets - or remain unhygienic.
Glue some bicycle tube rubber onto areas touching.
2x spotlight,2x fog lights
215/80/R15c tyres
1 x great humourous driver
GPS,Bluetooth
Eagle eye dash cam --stolen..bought another one
snorkel soon
Craig
