Xtrail T31 2012 DIY drawer system
Results 1 to 10 of 10
    Feb 2019
    Thanked: 8
    Default Xtrail T31 2012 DIY drawer system
    For anyone interested in a DIY SUV drawer system, suitable for a few days' worth camping, here is my recent build detailed, in the hope that it might help others, as various drawer-system threads on the site have helped me.
    This build was done with my father, without his help it would have either taken much longer, been more skew, but most likely both of the above.
    I hope to be very much to the point but also very detailed at the same time, so apologies if it comes across as very bullet-pointed.
    The aim is to help anybody else who might be toying with the same ideas.
    My previous thread showcasing very first "packing system" for my Xtrail is here (https://www.4x4community.co.za/forum/showthread.php/311144-Nissan-xtrail-camping-packing-and-capabilities?=)
    So, let's begin.
    a) Considerations and limitations:
    • Rear seating had to be available - minimum 2, ideally all 3, since I often lift friends to camping/hiking locations.
    • Possibility (for me) to sleep in the car by taking out left-side box (Xtrail is long enough to sleep full length with seats folded down, and I'm basically 180cm tall), placing box on right hand side rear seat (seat folded down, of course)
    • Rear visibility desired - mostly over my left shoulder. I check the middle mirror often.
    • Modularity - take out one, take out both, leave them in permanently, keep the base only, use for shopping, replace cooler wih fridge... you get the picture.
    • Transfer to different vehicle (by changing base only)
    • Weight
    • Cost
    • Ease of construction/modification (I have ready access to carpentry machinery, plus my father is a woodworking genius, so that was a factor)
    • Access to spare tire (underneath flooring, unfortunately)
    b) Construction (units in mm where relevant):
    • 9mm Plywood and pine (plywood mostly, pine where additional stresses expected)
    • Yes, the plywood usually has tendency to warp, but the pine sorts that out where needed, tolerances on the build are very good as far as I am concerned.
    • That being said, for version 3 I will consider 12mm ply.
    • Drawer runners - 2x 700mm and 2x 500mm (700mm purchased from Eclipse group in Walmer, Port Elizabeth, only place I could find that sold the stuff here)
    • The 700mm runners (outers) were chosen for their 90kg weight capacity (they weigh quite a bit themselves, to be honest, and they are not cheap).
    • The 500mm runners (inners) are straight from Buco, they have 45kg capacity each.
    • Wood screws (as opposed to chipboard screws)
    • Low sheen, water-based acrylic paint (Duram brand)
    • I only applied one coat of paint thus far
    • Boating carpet (bought a lot but used very little of it in the end), applied with some Genkem contact adhesive.
    • Dimensions given below are rounded up and depict external measurements, so you can see if they will fit in your car
    • Bear in mind that Xtrail has a sloping rear window, which influences the overall dimensions heavily - too high, and you have less depth and move further inward, etc etc.
    • Base: 1000d x 1090w (worst-case)
    • Taller box: 710d x 420w x 590h
    • Wider box: 710d x 450w x 420h
    c) Installation
    • The base requires cutouts, since my Xtrail came with a metal guard which bolts near bottom of the floor, these bolts are in the way of the edges of the base.
    • I do not know if these cutouts will be needed for all Xtrail models.
    • Additional "stopper" strips of plywood are screwed onto the base
    • Additional "stopper" strips of pine were screwed onto the boxes, near their tops.
    • The plywood stoppers prevent the boxes from sliding on the base
    • The pine stoppers prevent the boxes from lifting when drawers slide out, since they are tightly squeezed against the bottom of the metal guard when the boxes are in place
    • This placement will most likely change in the future, to make the system less reliant on the mesh guard, and simply fasten base to body, boxes to base
    • Carpeting and painting done easily before placing boxes into place, modularity helps a lot with this.
    • Owing to a unexpected design change, the right hand side box ended up with a open space at bottom, I am using this as additional slide out surface, which will eventually become a basin for dishwashing.
    d) Future considerations:
    • Top storage securing - currently nothing except bungee cord stopping the top stuff, this needs to be improved by placing strips of wood or similar to the top of the boxes
    • Better fastening to the vehicle (don't rely on mesh guard)
    • Anticipate using something like ammo/wolf boxes for storing stuff (or build a proper closed drawer), as opposed to basic crate currently used, lots of unused space in left box.
    • Dishwashing basin cutout (right side slideout surface)
    e) What can be packed in and around these boxes? (all in the cargo area, nothing in front)
    • 4 man tent, ground sheet, bigger than average camping chair, sleeping bag, air mattress, pump for mattress
    • Braai stuff - grid, tripod, some charcoal, heat resistant gloves, fire starting stuff, some wood (1 or 2 bags max)
    • 3kg Cadac bottle, cooker top, smaller Alva butane stove, gas kettle
    • Crockery/plates for 2 people
    • 66L cooler box (could probably replace with a 12V fridge, if I am not mistaken)
    • Water
    • Dishwashing stuff
    • Toiletry and cleaning stuff
    f) What might have to go onto rear seats (havent yet tried to fit these)
    • Dry foodstuffs
    • Clothing
    • Second chair, if packing for two.
    Anyway, if you managed to stay awake this far, thank you for reading!
    Herewith photos (hopefully they are clear)
ID:	583454   Click image for larger version.
ID:	583455   Click image for larger version.
ID:	583456   Click image for larger version.
ID:	583457   Click image for larger version.
ID:	583458   Click image for larger version.
ID:	583459   Click image for larger version.
ID:	583460   Click image for larger version.
  2. The Following 3 Users Say Thank You to ajestza For This Useful Post:
  3. #2
    Feb 2020
    Melkbosstrand
    Thanked: 18
    Default Re: Xtrail T31 2012 DIY drawer system
    Nicely done.
    Mark Prutton
    Feb 2019
    Thanked: 8
    Quote Originally Posted by Prune View Post
    Nicely done.
    Thank you!
  5. The Following User Says Thank You to ajestza For This Useful Post:
  6. #4
    Debbin
    Thanked: 90
    Nicely done
    I really appreciate the "slides within slides" .... might have to steal that one day...
    just a suggestion, but why not try one of those Thule roof box kind of things, for tent, chair, ground sheet, bedding, soft squishy not square type of stuff, maybe even dirty clothes on the way home....
  7. The Following User Says Thank You to RvanZ For This Useful Post:
  8. #5
    Feb 2019
    Thanked: 8
    Quote Originally Posted by RvanZ View Post
    Nicely done
    The "slides within slides" still remains to be load-tested in my case, but I have seen them on quite a few Youtube videos so they can definitely add a lot of functionality.
    Thanks for the suggestion re the roofboxes!
    Believe it or not, I have deliberated those roofboxes recently, especially since I already have the Thule loadbars, so currently considering the roofbox vs just making a roofrack (aluminium extrusion-based).
    My main motivation for the roofrack is that I would like to keep the LP-gas and spare tire on the roof for safety/easier access, plus the roofboxes are quite a bit more than I would like to pay for at the moment, although I absolutely love their streamlined look.
    One more advantage about the slides-within-slides - you can actually take out the entire inner slide and box, so it can become e.g a small dinner tray on your lap, chopping surface, etc.
  9. #6
    Thanked: 1006
    Welkom Andre! Ek besef nou eers jy het hier ingesluip. Jou projek lyk baie netjies sover. Ons moet gaan kamp sodat jy dit wat jy nou het kan toets, dit wys jou die vinnigste wat jy waar/hoe moet verander/verbeter.
    Ek sou voorstel jy hang eers terug met die wasbak idee. Die hout en slides gaan nie baie van die water wat jy mors hou nie, en ek vermoed dit gaan dalk effens laag wees, jy gaan ongemaklik oorgebuk staan en was? Sit liewer die wasbak op 'n tafel vir nou
  10. #7
    Feb 2019
    Thanked: 8
    Quote Originally Posted by MrTolbos View Post
    Dagsę Tolbos!
    Jy het 'n punt daar beet, maar ek moet sę die stuk hout waarop die wasbak tans rus ( Sondag die gat uitgesny) is maklik vervangbaar en is in elk geval nie heeltemal die regte wydte nie, so ek gebruik hom vir nou as 'n proefkonyn, juis om te sien wat ek wil verander.
    Ek vermoed my rug gaan juis 'n ernstige gesprek met my wil aangaan na die eerste paar kere wat ek skottelgoed was...
  11. #8
    Ruimsig
    Thanked: 19227
    Built, not Bought
    Great to see and you have definitely given this some width and depth of thought.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  12. #9
    Jul 2017
    Louis Trichardt
    Thanked: 229
    self deleted
    My Life Loving It
  13. #10
    Feb 2019
    Thanked: 8
    Built, not Bought
    Thank you very much - the whole built-not-bought thing you mention above added some fire under my behind to get my roofrack sorted too 😁
