Discovery 2: Discovery 2 No.2 - The Tourer
Results 1 to 8 of 8
    Forest Hills, KZN
    Thanked: 908
    Default Discovery 2 No.2 - The Tourer
    While this happened a couple months back, i'm only now getting to putting a thread together.
    Over a year ago, at a LROC GTG here in KZN, someone showed up with a Landy like not many that I have seen and I immediately loved it, registration plate HUSKY-WP.
    After deciding to get a D2 and doing the 'ultimate D2 thread', the opportunity came up to purchase 'Husky' and it has been a bit of a goal of mine to have 2 D2s. Keeping the D4 and 2 x D2s was not only impractical, but also with the pandemic, realised how much it costs for a car to sit in a driveway. So we ended up selling the D4 and acquired 'Husky'.
    Below are the pics that was sent when it went up for sale, along with the details:
    2003 Discovery II TD5 Automatic
    I’m not sure which specific trim my Disco is but it has:
    NO SUNROOFS (Big bonus), Semi leather/suede seats, ACE system (working perfect), came with rear air suspension(removed), was originally a 7-seater now 5-seater with rear completely removed for better utility.
    The vehicle has been exceptionally well cared for by all of its owners and comprehensively modified to improved what is fundamentally a very capable off-road vehicle. 0ver R160k worth in modifications outlined below.
    It is a weekend vehicle for me, not my primary transport.
    Exterior/Body:
    Silver metallic paint with extensive bush rash and a partial blacked out bonnet with some clear coat oxidising. Various vinyl stickers.
    Safari snorkel with Africa mesh cover
    Terrafirma TF001AC tube type bumper with T-maxx 9600 winch with 12mm synthetic rope 30m. Hella auxiliary 6ich LED Driving lights.
    Terrafirma TF115 Wide Wheel Arch Kit
    Terrafirma
    BURNCO Rock Sliders with hi lift jack points
    BURNCO Rear Bumper with Dual Spare Wheel Carrier – has tow hitch receiver with hi lift jack points
    BURNCO 40 mm Body Lift
    Frontrunner half roof rack – sand blasted and powder coated with jerry can mounts, hi-lift jack mount, spade mount, various eyelets for the rack
    Terrafirma TF864 Steel Fuel Tank Guard
    Interior:
    Smash and grab tint 35%
    Aircon blows ice cold, recently serviced and re-gassed. Heater works.
    The interior has had the roof lining redone and the leather upholstery is in fantastic condition.
    Escape Gear seat covers (front only) in Khaki with head rest covers which are Land Rover branded.
    Allmakes rubber floor mats.
    JVC stereo unit which still utilises the OEM steering controls and sports a USB port as well as been able to play MP3 and other formats on disc and features Bluetooth
    The steering wheel, low range/high range lever, brake lever has all been redone professionally in black leather as well as the centre cubby which is covered in colour matched padded leather. All the bad Land Rover chamois inserts in the doors have been removed and replaced with genuine leather in black.
    Nautilus air horn and pair of Fiamm conventional hooters (4 tones total), you will be heard
    The front passenger seat has a fire extinguisher affixed to the seat underside for easy access in emergencies.
    The vehicle has an LBB (Little Black Box) warning system as well as a Madman EGT gauge to monitor exhaust gas temperatures with an additional alarm built in.
    A National Luna Dual Battery Controller and wiring is fitted, no auxiliary battery fitted.
    A handy Maglite LED torch is above your head in the centre to access when needed. All interior bulbs – overhead and in the cubby, hole have been changed to LED lighting.
    160 l/hr air compressor mounted under driver’s seat and can be run from this position. Passenger under seat storage. TCU (Transmission control unit) has been re located 30cm higher under centre console
    Sharp knife mounted to 5th Door
    Engine:
    Original engine in perfect running order always with synthetic oil and correct coolant.
    Original engine cover (currently removed)
    Every filter Every service I generally use MAHLE filters and Fuchs Oils
    Terrafirma TF723 – Turbo Blue Silicone Hose Kit
    Terrafirma DA4631 – 30% Larger intercooler
    Silicone top coolant hose and Adaptors
    Rovertec tuning software, 1.5 bar map
    63mm side exit exhaust for better clearance with 1 small box
    2018 saw a New Power Steering pump a New Alternator
    New 672 105AH Energizer Commercial Battery
    New VDO 4 bar fuel pump
    MBD/LP4A Billet Aluminium Oil Cooler (Precautionary original was still perfect)
    Turbo still healthy, no EGR valves as original, 2018 New Boost Pressure Solenoid
    2019 New Glow Glugs (Beru)
    Drivetrain/Transmission:
    Full Transmission Overhaul in 2017
    OEM CDL (Centre Diff Lock)
    V8 torque converter and custom 2mm spring steel flex plate, modified boss
    Fresh oils in all diffs and gearbox (Fuchs Oils)
    New hi/lo range selector switch
    Donut delete Rear prop shaft – no ‘donuts’ to break – with greaseable UJ’s
    Front prop shaft rebuilt with double Cardon joint and new bearing with greaseable UJ’s
    Stock ratio Transfer case and Diffs
    Terrafirma TF838 – Front Diff Guard
    Terrafirma TF839 – Rear Diff Guard
    Suspension:
    Terrafirma heavy duty rear springs – original air suspension deleted
    Terrafirma TF052 - Heavy Duty +50 mm Front Coil Springs
    Terrafirma TF127 and TF128 - All Terrain +50 mm Shock Absorbers all round
    Terrafirma TF802 - Terrafirma Steering Damper
    Terrafirma TF526 - Rear Air Spring Spacers
    Terrafirma TF534 - Front Skeleton Shock Turrets
    Terrafirma TF255 Heavy Duty Steering Rod Kit
    Terrafirma TF256 - Heavy Duty Adjustable Panhard Rod
    Terrafirma TF220 - Anti Roll Bar Link Set for D2 with 2-3In lift
    Wheels/Tyres/ Brakes:
    6 x Matching OEM 6 spoke 16-inch discovery 2 wheels painted dark grey
    6 x GT Radial Adventuro Mud Tyres in 275/65/R16 (32inch) less than 2years and about 10k kms mileage on a 6-way rotation.
    Terrafirma TF302 - 30mm wide Billet Aluminium Hub Centric Wheel Spacers
    Terrafirma TF610L - Extended Stainless-Steel Braided Brake Hoses
    Terrafirma Cross Drilled and Grooved (CDG) brake discs all around, recently skimmed and fitted with Delphi Brake pads all round, Mercedes DOT 4 Brake fluid, full flush and bleed
    ABS/Traction control/Hill Decent fully operational, no Amigos
    Extras:
    Haynes Manual for TD5 Disco 2
    New Spare Thermostat
    Serpentine Belt
    Spare Rear Bumper Light Covers
    There was a point in the whole change, where my driveway looked like the last pic. Man I wish it could have stayed that way. But in hindsight, better it didn't.
Name:	WhatsApp Image 2020-04-08 at 11.49.03 (2).jpg
ID:	583391   Click image for larger version.
Name:	WhatsApp Image 2020-04-08 at 11.49.03.jpg
ID:	583392   Click image for larger version.
Name:	WhatsApp Image 2020-04-08 at 11.49.03 (9).jpg
ID:	583393   Click image for larger version.
Name:	WhatsApp Image 2020-04-08 at 11.49.03 (4).jpg
ID:	583394   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.19.04 (2).jpg
ID:	583399   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.19.04 (1).jpg
    2003 LR Discovery 2 Td5 ES - Lots of Mods(check thread) - [Husky]
  2. The Following 6 Users Say Thank You to douglash For This Useful Post:
    Forest Hills, KZN
    Thanked: 908
    Default Re: Discovery 2 No.2 - The Tourer
    We then promptly took it for a wash, threw on some fresh decals and went on a trip.
Name:	WhatsApp Image 2020-08-07 at 12.19.04.jpg
ID:	583401   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.19.03.jpg
ID:	583402   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.19.03 (1).jpg
ID:	583403   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.19.03 (2).jpg
ID:	583404   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.33.14 (3).jpg
ID:	583408   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.33.14 (2).jpg
ID:	583409   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.33.14 (1).jpg
ID:	583410   Click image for larger version.
Name:	WhatsApp Image 2020-08-07 at 12.39.04 (2).jpg
Name:	WhatsApp Image 2020-08-07 at 12.33.14.jpg
  4. The Following User Says Thank You to douglash For This Useful Post:
  5. #3
    Forest Hills, KZN
    Thanked: 908
    This last weekend, the opportunity presented itself to purchase a set of 285/75/16s. While I was quite happy with the size on originally, 33's are just such a good fit for the car. The problem now is the gearing as well as the EGTs which were perfectly fine before the bigger wheels.
    Next up. It needs a bigger turbo and definitely now needs bigger, stronger, re-geared diffs and a locker in the rear. Watch this space.
Name:	WhatsApp Image 2020-08-06 at 20.54.49.jpg
ID:	583405   Click image for larger version.
Name:	WhatsApp Image 2020-08-06 at 20.54.49 (1).jpg
ID:	583406   Click image for larger version.
Name:	WhatsApp Image 2020-08-06 at 20.54.49 (3).jpg
  6. The Following 6 Users Say Thank You to douglash For This Useful Post:
  7. #4
    Jan 2017
    Thanked: 25
    Where is the dual spare wheel carrier ? From the pics it looks like a standard Spare On the Door?
    04 Discovery II V8 Auto - The Duchess
  8. #5
    Forest Hills, KZN
    Thanked: 908
    Quote Originally Posted by The_Hoff View Post
    Has the Burnco kind, so can be removed and single spare used. Still have the dual spare carrier at home.
  9. #6
    Winston Park, Durban
    Thanked: 11
    Hi Douglas,
    The 30cm shifting of the AT ECU. Please can you send some pics are where it ended up being mounted. Was an extension loom used? The current position is crap for water ....
    1998 Defender Tdi Hard Top with ARB rear locker aka Slasher
    2004 Disco 2 V8 GS with 4" lift and 35" tyres plus a couple of little extras aka Goat
    2012 Disco 4 V8 HSE aka Rocky
  10. #7
    Forest Hills, KZN
    Thanked: 908
    Quote Originally Posted by Oilrag View Post
    Hi Douglas,
    Hey B, it was relocated up to the inside lid of the centre console. Not sure exactly how but will try get pics the next time I get in there.
  11. #8
    Forest Hills, KZN
    Thanked: 908
    So I received some upgrades in the mail.... now just need to find the time to get them done.
  12. The Following 5 Users Say Thank You to douglash For This Useful Post:
