T&C 210 Trailer
Results 1 to 13 of 13
Thread: T&C 210 Trailer
    Aug 2020
    Default T&C 210 Trailer
    Hi Guys,
    While I searched this topic I found numerous similar threads but my needs are slightly different and I hope you may be willing to assist with sharing some knowledge. I drive a bakkie (2020 Isuzu D-Max X-Rider 250 A/T) and my Town & Country 210 trailer slopes when hitched. I donít want to put a tow ball dropper plate on as itís the correct height for my flatbed trailer. The trailer currently has 13Ē rims on and I was wondering if putting a 50mm leaf spring riser (maybe hub spacers too) would allow me to put 15Ē wheels on?
    I'm not looking to convert it to a camper by putting a tent on and as my bakkie is a 4x2 it won't be going over hectic terrain either. It will be used to go on dirt road and the occasional soft sand when going to Ponta for diving, hence the need for bigger and wider wheels.
    On previous threads there was mention of the people at Challenger in Nahboom but they seem to have closed down and my local trailer shop can't assist either hence why I have turned to you guys for assistance.
    Thank you kindly
    Scott
    Thanked: 450
    Default Re: T&C 210 Trailer
    Be aware that the tyre size of a 15" might be too much for your current fenders. I am thinking of putting a spacer between the hitch and the a-frame on the front of the trailer, to drop it there.
    Klipriver
    Thanked: 299
    Why not get one of these? can change the height fairly quick
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  4. The Following User Says Thank You to Alan Eveleigh For This Useful Post:
    Wartburg.
    Thanked: 635
    I have done exactly that, but...
    You will need to change the wheel arches and the axle, you don't get 15" rims to fit that 750 kg axle.
    The bigger axle has stronger hubs and bigger bearings.
    Lightest 15" set up will be a 1800kg axle, if I recall. And will be in the region of 8k.
    It makes a amazing little off road/sand trailer and tows like a dream.
    I basically built a complete trailer and just fitted the 210 shell on it.
    Feel free to ask should you need any more information.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  6. The Following User Says Thank You to Chris8d For This Useful Post:
    Thanked: 2269
    Quote Originally Posted by ScottC-M View Post
    Hi Guys,
    Thank you kindly
    Scott
    My take on this is you want the town and country to stand higher behind your Isuzu. You dont want to turn the trailer in to a badass camper with rooftop tent and butch wheels though the butch wheels and wider rubber will be handy when traversing the Moz sandy beaches.
    Your Trailer has about a 640kg GVM if I remember correctly that was probably allocated as the max that could be handled by the wheels, one of mine has the same GVM due to tyre size.
    You would need to raise the axle by a min of 50mm by either a spacer on the axle mount or preferably a combination of spacer and lengthened shackle on the spring, That should give you enough clearance on the mudguard. As for Hub spacers you might get away with just playing with the offset of the rim.
    The Town and Country has a 4 x 100 pcd and to get this in 15" is as easy as falling out of tree, all the golf ricers changed their 13" wheels to 15" low profiles and to get 15" trailer tyres are as easy as pie. I have done this conversion for a few people and it worked pretty well, one might even be able to get the steel rims in 15" .
    Your vehicle has to be retested to change the GVM so it would still be a 640kg GVM with slightly less load capacity to compensate for the heavier wheels. As far as I know the axles was 900kg, burquip sold ther special make ups for challenger at silly prices in the beginning of July. I was offered full axles at giveaway prices.
    Henk
    Follow us on Facebook
  8. The Following 2 Users Say Thank You to hbannink For This Useful Post:
  9. #6
    Thanked: 418
    Hi Scott, I went to 195 /14inch tyre and rims and I added blades to springs and I had more than sufficient height. see pics. I also made my own axle and added VW golf rear hubs. It tows like a dream and is used for holidays and bush trips over any terrain
Name:	Pre Tow Test.jpg
ID:	583511   Click image for larger version.
ID:	583512   Click image for larger version.
    [SIGPIC]MikevR Be determined to live the unlived life within you.
  10. #7
    Thanked: 418
    Sorry one picture upside down.
  11. #8
    Wartburg.
    Thanked: 635
    [QUOTE=hbannink;4449339]
    [/QUOTE
    I would love some 15" in 4x100 pcd
    Please share some more info.
  12. #9
    Aug 2020
    Thumbs up Re: T&C 210 Trailer
    Thank you Kindly Sir, yes i'm not intending to make a badass camper. I have dropped Burquip an email and await their response
  13. #10
    Aug 2020
    Quote Originally Posted by MikevR View Post
    Thanks for the info and pics. Does the taxi wheels suffice on soft sand once deflated?
  14. #11
    Thanked: 2269
    [QUOTE=Chris8d;4450747]
    [/QUOTE
    https://www.twt.co.za/by-wheel-brand...t_pattern=5530
    https://www.a-linewheels.co.za/cgi-b...utback%20Range
    Henk
  15. The Following User Says Thank You to hbannink For This Useful Post:
  16. #12
    Wartburg.
    Thanked: 635
    I don't see the white steel rim in 4x100 ?
  17. #13
    Aug 2019
    PTA
    Thanked: 9
    This is what 15Ē wheels look like on a Challenger that were fitted from factory if it helps at all. I just came back from a trip so it is a little dirty, normally try to store it away as clean as possible.
ID:	584194Click image for larger version.
ID:	584195Click image for larger version.
  18. The Following User Says Thank You to plakkie For This Useful Post:
