Gull wing replacements for slide canopy windows
Results 1 to 6 of 6
    Somerset East
    Default Gull wing replacements for slide canopy windows
    I am thinking of replacing the conventional slide windows of my fiberglass canopy on my double cab with gull wings, probably in aluminium. Is there anyone with ideas/ suggestions ?
    Jun 2007
    Thanked: 36
    Default Re: Gull wing replacements for slide canopy windows
    Quote Originally Posted by Dupie2 View Post
    I did this years ago with my Ranger, will never have a canopy without gull wings again. It was done by a crowd in Silverton back then.
    Will dig out a pic this evening for you
    New & Used Car Sales Exec.
    Brackenfell
    Thanked: 298
    I did this about 2 years ago on my canopy. Did the DIY Route and it worked well for my need.
    removed the windows and made a template from hardboard and had 3mm alu tread plate laser cut.
    bought all the other hardware at 4x4 direct (shocks, brakcets, rubbers, hinges and pressure locks). it is still expensive to do though. Recently sold that canopy and bought a proper alu for my navara d40.
    Malmesbury
    Thanked: 17
    I attached a few photos of the process we followed on a Beekman canopy.
    1. Trace the profile of the glass window and have the aluminium laser cut.
    2. Remove the glass carefully with piano wire.
    3. Clean the old adhesive off, prime and paint.
    4. Fit rubber seal.
    5. Fit the powder coated wings.
    I am going away for a few days and would not be able to visit the Forum. If you need more info you are welcome to contact me on 08two8nine 55 two two7.
ID:	583355   Click image for larger version.
ID:	583356   Click image for larger version.
ID:	583357   Click image for larger version.
ID:	583358   Click image for larger version.
  5. The Following 2 Users Say Thank You to Pa Andre For This Useful Post:
    Jun 2007
    Thanked: 36
    @Dupie2
    here are some pics of the gullwing doors on my ranger canopy. never really took pics specifically of them.
ID:	583652   Click image for larger version.
  7. The Following User Says Thank You to DouglasN For This Useful Post:
    Jun 2007
    Thanked: 36
    @Dupie2
    found the pics I was originally looking for !
ID:	589654   Click image for larger version.
ID:	589655   Click image for larger version.
  9. The Following User Says Thank You to DouglasN For This Useful Post:
