Who did shock spacers
Results 1 to 12 of 12
    Mar 2019
    Default Who did shock spacers
    Hi guys want to know if you contacted Ford about any warranty issues by doing this. My local Ford dealer says its going to void my warranty.
    Anyone know if this is correct or who I can speak to to find out.
    Thanked: 973
    Default Re: Who did shock spacers
    Also want to know. As it is I have a fromt suspension issue on a brand new Ranger. Going in for its first service in 2000km then it must be sorted. So I am hesitant to do spacers but really need some extra height.
    12 Conqueror courage
    Dawie van der Merwe
    If you fail to plan, you plan to fail.
    A goal without a plan is just a dream.
    Gaborone, Botswana
    Thanked: 1252
    I have no idea how a Ford is put together but to my knowledge a shock spacer will provide absolute no lift.
    In fact, it may limit the downward travel under compression and may cause damage.
    The dealer is correct.
    Kobus
    Thanked: 973
    As far as I know its actually one of those coil over shock things. So both gets lifted together.
    Dawie van der Merwe
    Gaborone, Botswana
    Thanked: 1252
    Then it is a coil spacer (not a shock spacer)
    Kobus
  6. The Following User Says Thank You to KobusDJ For This Useful Post:
    Thanked: 312
    If they are "lifted together", this means the front has McPherson struts. Is this the case?
    So it is neither a shock spacer nor a coil spacer, but a strut spacer.
    The wheels are simply pushed out by the spacer thickness. No suspension travel changes take place and the ride is not affected. Camber needs adjusting.
    Limiting factors on a mild lift, say 20mm, are the drive shaft angles and drop link length.
    Johnie
    Volvo XC60 T5
    180kW/350Nm (1500 - 4800 rpm)
    Mar 2019
    Quote Originally Posted by JJJ View Post
    Sorry yes a strut spacers
    Sandton
    Thanked: 464
    It would make sense if it voids your suspension warranty. It puts more strain on everything involved - shock, coil, upper and lower control arms - but particularly the shock and lower bush.
    Gavin Pike
    Thanked: 297
    A 20mm spacer will give a 40mm+ lift because of geometry. Placing the CV joints at a greater angle.
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
    Thanked: 48
    I would say it all depends on your dealer and what they are willing to do or not do for you.
    We have more than ten Rangers in our fleet, six of them are running strut spacers up front to level the vehicles out with no ill effect on any of the suspension components.
    We have has turbo, inter-cooler, and gearbox failures in the fleet and our declined any of the warranty claims. These claims have not directed at the font suspension but at other major components.
    I know most people complain about their dealers but there are some good once out there, you just need to find them!
    PS: The dealership that I use actually fitted the strut spacers on two of the vehicles for me before I took delivery........
    2017 3.2 Ford Ranger Wildtrak D/C
    Old Man Emu lift kit
    Stofpad Box rocksliders
    Aline Dagger
    BFG KO2 285-75-16
    Ironman 4x4 Protector bull bar
    Stedi 6.5 inch spotlights
    Stanium aluminum canopy with some goodies and stuff inside
    and loads of attitude
  12. #11
    Nov 2014
    Paarl
    Thanked: 50
    They are actually talking about a strut spacer, it goes ontop of the coil/spring assembly
    2017 Ford Ranger 3.2 XLT
    ex 2013 Ford Ranger 3.2 XLT
    ex 2012 VW Polo GTi
    ex 2008 Audi A4 TDi
    ex 1998 Honda Civic Vtec
    ex 1998 Toyota Conquest RSi
  13. #12
    Feb 2015
    Thanked: 98
    I had 23mm spacers (mounted to the top of the coil), as a leveling kit, on my 2014 Ranger. Fitted them at 42k km, and never had suspension issues, and my dealership never gave me issues.
    Sold the vehicle in 2019 with 108k km, with the original shocks and coils still going strong
    2000 Land Rover Defender 90 2.8i
    2016 Ford Everest 3.2Tdci XLT AWD A/T
    Always go for the deepest mud, muddy stories make the best memories!
