Heavy duty drawer sliders
Results 1 to 17 of 17
    Jun 2015
    Thanked: 12
    Default Heavy duty drawer sliders
    I'm looking for drawer sliders
    about 1600mm 80kg. I have a Land Rover Defender 130 load bin, that I've made into a Defender 4x4 trailer, that I want to make one big sliding drawer.
    Nov 2011
    Langebaanweg
    Thanked: 1219
    Default Re: Heavy duty drawer sliders
    Furnlock.
    Check out their website.
    Mine extends 1m out of 110 rear and can take about 80kg per slide at 400mm extension.
    ( Might be slightly out with my specs)
    '07 Land Rover Defender 110 TDI 300 Kalahari (Meisiekind²)
    Brackenfell
    Thanked: 296
    IIRC you are able to obtain an extra heavy duty 180kg's at 400mm. Furnlock or at 4x4 direct and 1520mm in length
    those long ones are expensive.
    They are good in general, but attract dust and dirt in the slides and eventually become sticky. Why not make slides from bearings running on angel iron?
  4. The Following User Says Thank You to Dwayne P For This Useful Post:
    Apr 2012
    Brackenfell
    Thanked: 19
    Quote Originally Posted by calitzfamily View Post
    Or Teflon strips could also work
    Ellisras
    Thanked: 688
    Have you perhaps got a design/sketch how to...
    Rudolf Ras
    Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 851 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 111 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 124 000 km
    Jun 2015
    Thanked: 12
    This might be a good idea
  8. The Following User Says Thank You to calitzfamily For This Useful Post:
    Tshwanetoria
    Thanked: 866
    They are VERY heavy - but do an excellent job.
  10. The Following User Says Thank You to hatjohan For This Useful Post:
  11. #8
    Feb 2013
    Thanked: 496
    Contact Sarel F or Witklipbank from Blinkgat products, I saw in their new camper build thread that they'll be using some super heavy duty slides for their bed in the new camper truck.
  12. The Following User Says Thank You to bigboy529 For This Useful Post:
  13. #9
    Thanked: 1342
    Go look here;
    https://bushbugga.wixsite.com/bushbugga
    I turned my DC load in into 1 large heavy duty slide, 180kg. It comes out by a meter..
    Best thing I ever did, no more crawling inside the bin, under the canopy to get stuff at the back and my wife can load and unload much easier.
  14. The Following 2 Users Say Thank You to NewLandy For This Useful Post:
  15. #10
    Brackenfell
    Thanked: 296
    I currently have a 1.2mt furnlock installed in mine, however I have lost some of the balls in the slides.
    See here for inspiration
    1
    2
    When my slide fails I will be going this route.
    don't get me wrong the furnlock slide are good, however they do not like dust. That dust is its downfall
  16. The Following User Says Thank You to Dwayne P For This Useful Post:
  17. #11
    Pretoria / Motopi Village, Northern Botswana
    Thanked: 283
    We are currently awaiting our canopy and binslider from Kanopi...they use ballbearings for their slide...looking fwd to getting it in...will post pics when done.
    2014 Land Cruiser 76 SW with extras
    2019 Jaguar Inkwe 4 Offroad Caravan
  18. #12
    Thanked: 21
    or just wash them well to remove the grease and lube with “white lightning” or similar dry lube from bicycle shops...
    mine is going strong and dirt free after ~4 years. And pre covid, we camped every month... so can definitely recommend this option
    Robin
    2010 Mitsubishi Triton 3.2 D ID D/C P/U
    Kitted out and ready for an African safari....
    Plenty of people miss their share of happiness, not because they never found it, but because they did not stop to enjoy it....
  19. The Following 3 Users Say Thank You to Terorris For This Useful Post:
  20. #13
    Dec 2015
    boksburg
    Default Morning
  21. #14
    Ellisras
    Thanked: 688
    Default Re: Morning
    Where to get?
    Rudolf Ras
  22. The Following 2 Users Say Thank You to Dungbeetle For This Useful Post:
  23. #15
    Thanked: 1090
    So if you have this at 1600mm long, you can only slide it out about 1000 to 1100mm. The piece inside is required to hold the drawer up and in place.That is unfortunately the downfall of this type of drawer slide.
    I've had my home made fridge slide since 1998 that I made for my Sani and have transferred it to each of my successive safari vehicles. It is now in my Patrol. It uses the Furnlock and Slide 800mm heavy duty slides.
    It has never give trouble, I have newer cleaned them and I have been on many Kalahari and Namib trips. Successive rails from FL & S for drawer systems have given trouble but not the set I bought from them back in the 90s. Maybe a different and much better make than their current lot.
    What I find with their current ones, is that the stoppers pack up and then the whole slide pulls out, all the balls fall out and scatter on the floor and then the drawer falls on the floor!!!
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
  24. The Following User Says Thank You to mvcoller For This Useful Post:
  25. #16
    Sep 2017
    Hout Bay
    I build these sliders about 4 years ago. I used Furlock heavy duty sliders on the bottom tray.
    Did find that dust make the sliders slide a bit rough. Other than that they still going strong.
    Done many many gravel roads through Africa. Enough space to load 2 National
    Lunar fridges and 4 high Amo boxes, gas bottle and area for working on.
    The space under the slider is for a 1460mm x 800mm table.
    Top slider take 2 Amo boxes.
ID:	584240   Click image for larger version.
ID:	584241   Click image for larger version.
ID:	584242   Click image for larger version.
  26. The Following 2 Users Say Thank You to bokkemanskloof For This Useful Post:
  27. #17
    Aug 2020
    Paris
    Lightbulb Re: Heavy duty drawer sliders
    Quote Originally Posted by bokkemanskloof View Post
    Here’s a smart plan. No fussing with drawers. These pull out beds allow a variety of packing options.
    Are there kits for installing these?
    Who makes these for a fair price?
    Thanks for this share
