What glue to use?
Results 1 to 20 of 24
    Klipriver
    Thanked: 299
    Default What glue to use?
    Gents I need some help please. I am a real novice when it comes to woodwork, but am now trying to make a bread/ cutting board. I am using a mixture of hard wood strips that I need to glue together but am not sure what type of glue to use. I know the normal wood glue is not happy if exposed to a lot of moisture, hence me turning here for help.
    What glue do you suggest?
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Mar 2012
    Thanked: 1274
    Default Re: What glue to use?
    Use this one
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
  3. The Following 4 Users Say Thank You to ViperR For This Useful Post:
    Oct 2006
    Melkbosstrand
    Thanked: 894
    I use Cascamite for that.
    Sedgefield
    Thanked: 79
    Exactly what Viper R says, and some interesting facts about it.
    “take a closer look at the Alcolin Ultra (Blue & Yellow) label. This adhesive in actually TiteBond III. Permoseal South Africa imports it in bulk and distributes it under their Alcolin brand. They have done so for some years.
    You can also buy it in 5 Litre containers, just ask BPM Toolcraft to order it for you.
    It combines the strength, sandability, ease of use and water cleanup of PVAs (aliphatic resins) with the durability, open time and water-resistance of polyurethanes.
    -Waterproof - Passes ANSI/HPVA Type I -
    -Specification
    -Superior strength
    -Longer open time
    -Lower application temperature
    -Resists solvents, heat and mildew
    Unaffected by finishes
    Water cleanup & Non-toxic
    FDA approved for indirect food contact
    Sands easily without softening
    Safer than traditional waterproof glues
    Titebond:registered: III is especially useful for outdoor applications in cooler temperatures or when concern for substantial moisture calls for the use of a Type I glue. For interior applications, the longer working time of Titebond:registered: III provides woodworkers the necessary latitude to ensure that substrates are precisely aligned before being bonded. Overall, Titebond:registered: III combines superior strength, Type I water-resistance, long open time and low chalk temperature into one easy-to-use formulation.”
    Toyota
    2019 Toyota 2.8 GD-6 4x4 Raider DC Auto
  6. The Following 9 Users Say Thank You to Iggi For This Useful Post:
    Thanked: 295
    Quote Originally Posted by Kola View Post
    Now that is what I was taught to use nearly 45 years ago.
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
    Oct 2006
    Melkbosstrand
    Thanked: 894
    Quote Originally Posted by Robbief View Post
    Got that from my dad.
    But modern adhesives are likely much better now, so maybe time for me to change.
  9. The Following User Says Thank You to Kola For This Useful Post:
  10. #7
    Mar 2012
    Thanked: 1274
    Then my recipe for once you done with your final sanding use this and see how the grain comes alives. It’s expensive but it works.
    GaryG
    Honda Civic Type R
    - Daily Drive
  11. The Following 3 Users Say Thank You to ViperR For This Useful Post:
  12. #8
    Sedgefield
    Thanked: 79
    Just some pointers, if using hard woods it is always good to glue within a couple of hours of planing the wood, as the planing opens the pores and therefore creates a greater bond between the two surfaces. Also if using an oily wood like Blackwood.Click image for larger version.
    The attached both laminated Blackwood using alcolin ultra within an hour of going through the thicknesser.
    They even go in the dishwasher
    Toyota
  13. The Following 3 Users Say Thank You to Iggi For This Useful Post:
  14. #9
    Sedgefield
    Thanked: 79
    Other products that also work well, on any wood projects to be used with food products.
    https://mybutchersblock.co.za/collec...nd-maintenance
    Toyota
  15. #10
    Sep 2015
    port elizabeth
    Thanked: 73
    This is what i use. R140 per bottle. Good shelf life.
  16. #11
    Rangeview Krugersdorp
    Thanked: 1313
    Bet Dad also used the glue made from horse's hooves ?
    Now that stuck !!
    Ford Figo 2016
  17. The Following User Says Thank You to duncang For This Useful Post:
  18. #12
    May 2018
    Paarl
    Thanked: 88
    Some glues are water resistand, but I prefer to use a waterproof glue.
    Brummer Balcotan Waterproof Glue works for me!
    BALCOTAN 100 is a one part polyurethane based waterproof wood glue. Unlike the PVA Cold Glue which is only water resistant, BALCOTAN 100 is completely waterproof. It also has tremendous gap filling properties. BALCOTAN 100 is not affected by UV or any other outside elements. Bonds may be permanently submerged under water.
  19. #13
    Klipriver
    Thanked: 299
    Thanks to everyone for your input, it seems I have a bit of homework to do now. And after reading the comments made by Iggi, it would seem that I have a lot to learn about wood.
    @ Iggi, (others are free to answer as well) the strips I am using are only roughly 50x40 x 150 long, how does one feed them through the thicknesser? Does a person not need a minimum length to make the feed work?
    Alan
    _________________
    Range Rover P38
  20. #14
    Friemersheim, Southern Cape
    Thanked: 3381
    Quote Originally Posted by Dirkba View Post
    How do you clean your fingers? It sticks like sh$t
    Robert van den Berg
  21. The Following User Says Thank You to Prof For This Useful Post:
  22. #15
    Sedgefield
    Thanked: 79
    Quote Originally Posted by Alan Eveleigh View Post
    Hi Alan
    Only a pleasure, I normally start with a plank, that I send through the thicknesser then cut into slats and then glue and clamp, glueing the planed edges, Once dry I cut the leading and trailing edges off and then glue scraps to these edges to help feeding through the thicknesser and to prevent tear out where the spinning blade damages the edges.
    Unfortunately no pictures, but if you google tear out on chopping boards normal and end grain there is tons of helpful information.
    Not my picture or thicknesser but it will give you the idea.Click image for larger version.
    One tips for the thicknesser
    Always use sharp blades
    1/8 turns only
    Sacrificial pieces glued to front and back to prevent tearout
    Longer runners glued to side to prevent snipe on the cutting board and if glued right, provides flat reference to ensure perfectly flat board.
ID:	582962Click image for larger version.
    Toyota
  23. The Following 2 Users Say Thank You to Iggi For This Useful Post:
  24. #16
    May 2016
    Thanked: 3094
    Me too.
    2006 VW Touareg V10 TDi
  25. #17
    Thanked: 295
    If all fails google ... flattering boards with a router
    Roberto Forbes
    Fortuner D4D
    Sp Tourer
  26. The Following User Says Thank You to Robbief For This Useful Post:
  27. #18
    Dec 2014
    Thanked: 1961
    I used to do rowing at school, and we used Balcotan to repair the wood hulled boats if they got damaged.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  28. #19
    Thanked: 295
    I use Adtec Or Bondtec W150 (same thing) Manufactured in Edenvale.
    although its water resistant, its used by garage door manufactures and good enough for cutting boards.
    come in 500ml squeeze bottles or 25 lt drums.(6 month shelf life)
    cost effective compared to imported glue. Adtec 011 451 9800
    Roberto Forbes
    Fortuner D4D
    Sp Tourer
  29. #20
    Pietermaritzburg
    Cascamite is the best but you cant buy it in SA. Have to import as far as I know and i have really tried.
