Hi guys
Would appreciate your input.
The catalytic converters were toast on my 2013 3.6 JK - rattling on acceleration. Instead of 40k for new cats, I took it in for a decat (minicats etc installed.)
Jeep runs great, although my regrets as follows:
- It's louder than I'd like, especially on cold start.
- Sounds 'tinnier' - think E46 M3.
- It stinks! When windows are open all I smell is carbon monoxide.
How can I fix this aside from installing new units?
Any exhaust shops recommended out in the Vale?
2013 Jeep Wrangler Unlimited Rubicon
2006 Mazda MX-5: Daily driver/stress relief (SOLD)
maybe chat to exhaust shop about adding another silencer to the system. Your are still stock on the exhaust, then add or replace with larger if possible
I agree! I wanted to upgrade my lexus exhaust because it has no sound really and that beauty of a V6 should be heard but im scared I mess that up.
I think as someone has mentioned, try chatting to an exhaust place and see if they can add another silencer / muffler to help reduce the noise.
No need to scare the old tannies when you driving past the shops for milk!![]()
Lexus GS350
Nissan X-trail 2.5 4x4 (old rattle donkey)
Ex - Polo Vivo 1.6 sedan(Stolen), Nissan Hardbody 2.4 4x4 D/cab, Steed 5 2.5tci 4x4 D/cab
also adding does not do harm N/A motors, back pressure does not cause worse performance, unlike the turbo and turbo diesel counterparts where it is better to get rid of warm gassed etc asap.
I suspect your definition on backpressure on a NA engine is not entirely correct. Back pressure on a NA engine is meant to be a negative pressure at the exhaust port. Adding silencers lowers the negative pressure, with loss of performance. The correct backpressure is obtained by calibrated branches and the correct size exhaust pipe, to optimise gas flow through the system to scavenge exhaust gasses from the ports and to minimise detonation of unburnt gas in the pipe.
Pieter Kemp.
2011 Isuzu 300d-teq 4x4 d/c
Home built Blapsie caravan.
I think we need a video or sound clip!
Did it make any difference to the fuel consumption?
So, the only thing that you changed was the full CATs for mini- or fast CATs?
It could be running great due to slightly less back pressure, but still sufficient for a NA. If you were replacing your headers, I'd look the anti-reversion style slightly smaller than the port size.
* Yes, fast CATs are not as restrictive and thus, louder.
* OEMs work hard at getting their models to sound a certain way. You have changed that. You could add an absorptive style of silencer to reduce high frequencies (tinny) without changing the back pressure significantly. Offset absorptive silencers are even quieter with a slight bit more loss of flow.
* Have your fabricator turn the tailpipe down and away from the vehicle.
Renault Duster 4WD Gen1: No Meow, GC = 254mm, WD = 820mm
Apologies for the delay gentts.
Here's a video - not entirely convincingly terrible.
Fuel consumption... i'm bad at sums.
The exhaust gasses may be coming in through the tailgate. It does let dust in when off roading.
The smell is annoying/dangerous. Only when I have the windows down, and it lingers around the vehicle. Unless it's everyone around me!
The middle cylinder box is a resonator and the rear box is a muffler.
I think in your case you could change the muffler and improve the exhaust sound. I've got a Magaflow axleback on my JKU which sounds great. But I haven't touched the cats.
As for the exhaust fumes I'd say there is a leak somewhere. Something hasn't been sealed properly. I seem to remember a test one can do with light or gas to pick up leaks.
See this Landrover thread as well
https://www.4x4community.co.za/forum...-cat-now-smell
- Jeep Wrangler Sahara Unlimited 2014 (Cooper Discover P285/70/17 // Mickey Thompson Sidewinder II's // Teraflex 2" levelling kit // Renegade front/rear steel bumpers)
- (SOLD 2017/03) Ford Ranger 4.0 V6 XLE 4x2 Manual 2005 (Falken Landair 31/10.5/15)
Follow on Instagram: https://www.instagram.com/doomrider
Do you have a drone in the cabin at certain rpm? From the clip, it sounds like that could be possible.
I'd seal the tailgate starting with replacing the seals. You can thread a long rubber tube through some seals for an even better fit. I added sound proofing to the back side of the doors (so that it couldn't been seen from outside). My road noise and dust went down dramatically thereafter.
Remove the CATs and the smell goes up, especially in a diesel. CATs also catch a lot of exhaust noise, but they are very flow restrictive.
An update:
I've grown accustomed to the 'new' noise. Not that bad.
The fumes are annoying - with windows down exhaust gases come in via the vents behind the spare wheel.
With windows up the problem goes away.
However with soft top down, all windows down it does linger.
I've since tried ordering replacement cats from Rock Auto - about $600 (R10,000) including shipping, ex taxes and duties. A big saving on the R40 odd thousand from local dealer.
Two different payment attempts failed (CC and Paypal), after which my credit card was hammered by several ClickFunne* Trial Over charges for a similar amount.
Looking into it and will revert.
Convertibles have been around longer than catalytic converters.
I'd fix the leaks as they contain deadly carbon monoxide. Just because you can't smell the fumes doesn't mean that you can't get asphyxiated.
You can restrict the tip to increase the flow which must be pointed down and away from the vehicle so that you don't die when backing up. N/A loves restricted exhausts. Turbo engines can stack the charge the length of the system during hard acceleration and release during normal load conditions.
Jason my best advice would be to take it to a proper exhaust shop get them to sort it out it will be much cheaper than new cats!
get a complete stainless exhaust roughly around R10k with the right mufflers, high flow cat and silencers!
I will send you a few guys in a pm!
To replace the stock cat is not necessarily going to solve your problem, it might be that the guys that removed it did a bad job
2012 Jeep Wrangler Sahara 2.8 Unlimited
2015 Jeep Grand Cherokee 3.0 Overland
@HansieK Thanks for the great info! Will definitely check it out.
@jelo It was a considered and expensive exercise, performed by a reputable indie. Although I do enjoy the thought of you filing yet another throwaway chirp in your crack, alongside all the others.
An update!
I went to a popular exhaust shop here in the Vale, the guys there recommended I go see HM Tuning down the road before doing anything else.
Performed a basic tune on the ECU, deleted cats from the computer, corrected timing and all is good.
Jeep was over-fueling, which caused the fumes. Not completely gone (no cats) but a major improvement. Wife commented that it's now more responsive.
