RangeRover Help !!!! Workshops in PE are scared to work on my vehicle. - Page 2
Results 21 to 40 of 43
  1. #21
    Nov 2016
    Thanked: 161
    Default Re: Help !!!! Workshops in PE are scared to work on my vehicle.
    Quote Originally Posted by Bluerover View Post
    Just an update guys.
    He said that the bolts can be used twice , and there is no need to do the guides unless you want to refurbish the entire heads. He says it has only happened twice in his lifetime. But these motors dont break or crack easily.
    Dont bolts stretch to spec when torqued down?
  2. #22
    Aug 2020
    Pe
    Quote Originally Posted by JadeDsantos View Post
    According to the l322 workshop manual , the bolts may be used twice.
    And this is the first time that I will be doing this.
  3. #23
    Mar 2016
    Thanked: 2158
    I would feel better using new bolts
    André Opperman
  4. The Following 4 Users Say Thank You to Oppies3800 For This Useful Post:
  5. #24
    Feb 2016
    Thanked: 955
    Quote Originally Posted by Oppies3800 View Post
    yeah, not worth risking an engine when the cost of new bolts is low.
  6. #25
    Dowerglen
    Thanked: 855
    Managed to source a jaguar mechanic in port elizabeth that works on these types of v8 engines. He works from home.Total cost of the job 7k. I just need to supply my own spare parts and material ( oil filters and oil )
    He'll send it to the engineering, if there is engineering work to be done at my cost.
    Thanks , again for all the feedback guys.
    Please, for your own sanity and safety, get new bolts, its a small expense but a potentially large saving..
    And there was a bulletin somewhere on the earlier Jag V8 SC motors having the supercharger coolant pump cabled incorrectly from factory, pump ran in reverse... but its old memories, still worth a google search though..
    Regards - Marco Chezzi
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  7. #26
    Thanked: 901
    You guys that buy these brand X with brand Y engines have big Khahunas.
    Good luck to you.
    Carry on.
  8. #27
    Secunda
    Thanked: 41
    Did you do a compression test to confirm that it the gaskets? Oil in cooling water, Bubbles in cooling water reserve?
  9. #28
    Dec 2014
    Thanked: 1969
    Quote Originally Posted by Rustie View Post
    Good luck to you.
    Carry on.
    OEM fitted.
    JLR, Jaguar Land Rover....
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  10. #29
    Malawi
    Thanked: 1318
    Quote Originally Posted by Marcochezzi View Post
    What??
  11. #30
    Dowerglen
    Thanked: 855
    Quote Originally Posted by tashtego9 View Post
    What??
    Yep, see attached..
  12. The Following User Says Thank You to Marcochezzi For This Useful Post:
  13. #31
    Dec 2014
    Thanked: 1969
    What??
    TATA ma chance....
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  14. #32
    Aug 2020
    Pe
    Quote Originally Posted by Nico H View Post
    Its overflowing from the reservoir water tank.
  15. #33
    Aug 2020
    Pe
    Good luck to you.
    Carry on.
    This is a OEM fitment sir, landrover doesnt have their own engines. You get jaguar , ford Lincoln, bmw and Chevy engines in different brand landrover and also the year model.
  16. #34
    Aug 2020
    Pe
    That was the first thing a check. But I get sufficient flow from the aux waterpump. This was also listed of the main defects on the range rovers l320 and l322 on rover.uk.com
  17. The Following User Says Thank You to Bluerover For This Useful Post:
  18. #35
    Sep 2011
    Range Rovers are only designed to last 6 years according to their research & development director on "How it's made" program I was watching.
    2004 LandCruiser 100vx V8
    Warn 12000lb winch, LED Spots & ARB Front Bumper, Ratel Rear Bumper, 55lt Sub Tank, Sanji HID Xenon Headlight upgrade
  19. #36
    Dowerglen
    Thanked: 855
    Quote Originally Posted by AlexvdW View Post
    As much as that..!
  20. The Following User Says Thank You to Marcochezzi For This Useful Post:
  21. #37
    Malawi
    Thanked: 1318
  22. #38
    Dowerglen
    Thanked: 855
    Well then go get yourself a Polo and consider yourself satisfied......
  23. The Following User Says Thank You to Marcochezzi For This Useful Post:
  24. #39
    Aug 2017
    Thanked: 307
    Good news for the 2.4 pumas
  25. #40
    Aug 2020
    Pe
    Wink Re: Help !!!! Workshops in PE are scared to work on my vehicle.
