Results 1 to 13 of 13
    Nigel
    Thanked: 2570
    Default 1KDFTV in a 90 Prado
    Difference is that this one has a mechanical injection pump.
    We have one running in a 120 Prado already.
    This one is destined for a 90 swb.
    https://youtu.be/0VC_5L1UrsA
    https://youtu.be/LurfixJOn00
    Uniglide
    +27 zero eight 2 four 95 9252
  2. The Following 3 Users Say Thank You to Henris For This Useful Post:
    Thanked: 289
    Default Re: 1KDFTV in a 90 Prado
    Is geen ECU, MAF sensors, ens. meer nodig nie Henrie?
    Indien wel kan dit die silver bullet van diesel engin upgrades/swap- outs wees.
    Engins en parte gaan baie meer bekombaar wees as die QD32ti conversion opsies van ons Nissan Hardbodies en Patrols.
    '00 Nissan D22 QD32Ti 4x4 D/C - many, many mods.
    '10 Toyota LC150 1GR-FE VX - stock
    '10 Yamaha XT1200Z Super Ténéré - stock with some farkles
    - Our lives were governed by the Ten Commandments, good judgment, and common sense. -
    Nigel
    Thanked: 2570
    Quote Originally Posted by swakop_toe View Post
    Is dan geen ECU, MAF sensors, ens. meer nodig nie Hennie?
    Indien wel kan dit die suiwer bullet van van diesel engin upgrades/swap- outs wees.
    Engels en parte gaan baie meer bekombaar wees as die QD32ti conversion opsies van ons Nissan Hardbodies en Patrols.
    Presies reg.
    1 draad vir die fuel cutoff solinoid.
    1 vir die rev counter
    1 vir die olie druk
    1 vir die water temp
    1 vir die sump oil level.
    Uniglide
  5. The Following User Says Thank You to Henris For This Useful Post:
    Thanked: 90
    Het jy al n bellhousing ens om hom the match met n H55F 5sp box ?
    UZJ 42 LX: Olive (Sold and bought her Back !)
    HDJ 75 RV Troopy
    Nigel
    Thanked: 2570
    Nee. Maar Toyota bellhousings is gewoonlik nie 'n probleem nie. Baie comparable.
    Uniglide
    Wartburg.
    Thanked: 707
    Wel gedaan Henris!
    Dit lyk of jy n wenner daar gaan he.
    Ek volg die draad.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    ZS5CL
    Thanked: 17104
    1KD with the 1KZ pump?
    Nice. How much is it down on power compared to the common rail system?
    Jakes Louw
    Nigel
    Thanked: 2570
    No. KZ pump doesn't work.
    Straight mechanical pump.
    Uniglide
    Thanked: 17104
    Original 1KZ-T came with a plain mechanical.
    OK, 5L pump? But that had no boost compensation?
    Jakes Louw
    Thanked: 289
    You're wanting him to give up all his trade secrets Jakes?
  13. #11
    Thanked: 17104
    I suppose not. Just curious.
    The Ozzies seem to use the Mitsu 4M40 pump and injectors. Since the Japs use the same pumps, it stands to reason that you'll find some combo that works.
    All of the top manufacturers (Toy, Mitsu, Nissan) use a copy of the Bosch pumps. In fact, Bosch and Zexel have now merged.
    Jakes Louw
  14. #12
    Nov 2018
    Meyerton
    Hi manne, klink interesnt, Henry hou ons op hoogte asb
  15. The Following User Says Thank You to TRD For This Useful Post:
  16. #13
    UK version came out with the 1kdftv in 2001 and 2002 for the 90-series. 2003 onwards it was the 120-series.
