Please help me fix this tractor.
Page 1 of 11 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 1 to 20 of 217
    Thanked: 1373
    Default Please help me fix this tractor.
    Original fred - refer here.
    I am looking at buying a FIAT 540 tractor in really good condition except that the engine does not start. Yes, I see irony in mentioning "Good condition" and "Broken engine" in the same sentence. But the rest of the tractor in mint condition - including very new tyres. The engine was running until somebody stole diesel from the tank and replaced it with water.
    Questions:
    1. Fiat 540 - 3 or 4 cylinder? Some sites say 3 other 4.
    2. What causes the failure in this case? Water through the diesel pump and injectors, how do they fail?
    3. Approximate price to fix the pump and injectors.
    4. Experiences with this tractor - I know the 640 well and it is very good tractor.
    I've never really worked n diesel engines before, just petrol. Now I have to fix this. I've started many tractor engines after running out of fuel before so I Know the bleeding procedure. I am pretty sure this is indeed a 640 not a 540 due to the 4 cylinders. But there is some small changes from the other 640 we I am currently using on the farm:
    1. Two separate diesel filters. The other one has two filters next to each other on the same housing.
    2. It has Bosch diesel pump - Not Lucas CAV. The manual does however mention that some models had the Bosch.
    After washing it I tried to bleed it, but the manual lever of the fuel lifter pump does not work. I suspect it does work from the cam follower side, but fro the outside I cannot get it to work. I loosened the discharge pipe on it and no fuel comes out. The I loosened the supply side and there is definitively fuel there. That makers first order of business tomorrow - new fuel lifter pump, new diesel filters.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  2. The Following User Says Thank You to Uys For This Useful Post:
    Langs die rivier, op n berg
    Thanked: 3188
    Default Re: Please help me fix this tractor.
    Eerste ding. Roteer die engine n paar grade. Heel moontlik staan die pomp se follower net op die lobe van die cam, so pomp is in vol compressed mode, so dit voel of die hand lever niks doen. Roteer engine effens dat die pomp follower nie op n cam lobe sit, dan kan die handpompie werk.
    Dan. Jy sÍ daar is diesel by inlet van pompie, maar nie by outlet.
    Maak die 6mm boutjie los, en maak die screen filter skoon.
    Diesel moet vrylik hier uitloop sinder dat engine loop of lifpimp gepomp word.
    Maak ook die hose clamp los, diesel moet vry daar uit loop
    Daarna maak die banjo bolt los met 17mm spanner, en kyk dat die dwars gaatjies, maar ook die centre gat, skoon is. Roes uit tenk is lief om daardie banjo bolt te verstop.
    Maak seker dat beude die fulters goed gebloei is, sowel as die injectorpomp.
    Maar, as dit is soos jy sÍ dat daar nie diesel is na lifpomp, kyk waar verstopping is.
    Daai lifpompies is baie eenvoudig, en breek nie gereeld. As hulle breek, is dit die diafragma wat gaan, en dan raak jou sump vol diesel. Kyk maar na jou diesel...
    640 is 4 silinder, 540 is 3 silinder.
    Thanked: 1373
    Reenen.
    Nadat ek die gepost het ek hom oopgemaak ja. Die filter is verstop gewees en die pomp werk defnitief. Hy druk wel teen die hidroliese pomp vas voor hy begin pomp, so jou lobe teorie maaksin. Ek kon nie die enjn nou draai nie want die battery is op die charger (hy was 3V, so dit gaan seker maar n nuwe battery kos.)
    Wat my wel pla is dat ek in die inlaat banjo bolt en in die filter blare en gras gekry het.
    So ek wil eers more die tank afhaal en skoonmaak voor ek aangaan.
    Die trekker het BEPCO filters op en ek kan nie die nommers sien nie - wat is die GUD equivalent? G629?
    Thanked: 3188
    G629 gud ja.
    Die blare is maar algemeen as mens uit kanne diesel gooi.
    Ek sou nie eens die tenk af haal, dalk is dit baie lank se akumasie. Heel moontlik, na jy nou skoongemaak het, loop hy n jaar voor hy weers stop, sonder moeite van tenk af haal.
    Maak dit skoon elke keer as jy filters vervang.
    Thanked: 3188
    Sit trekker in 4de hi, en rock agterwiel met hand. Dit is genoeg om engine genoeg te swaai.
    Of, in neutral, en draai aan fan blade met een hand, en ander hand palm op belt om belt styf te druk dat hy kan crank kan draai. Daai engine swaai maklik met hand
    Thanked: 1373
    G629 gud ja.
    Dankie. Maar die trekker werk 200km van my af, terwyl on strip word alles skoongemaak.
    Thanked: 1373
    Ons het nou alles skoon.
    • Diesel tank afgehaal en herhaaldelik gespoel. Omtrend 2 hande vol "grond/modder/sludge" uitgehaal.
    • Al die pypies is afgehaal en met lug skoongeblaas
    • Twee nuwe filters.
    • Diesel loop uit op die uitlaat van die lifter pomp as ek die banjo afhaal.
    • Diesel deurgebloei tot op die eerste filter.
    • Van daar deurgebloei to op die tweede een.
    • En toe tot op die hoedruk pomp.
    • Die return van die hoe druk pomp na die tank is los gemaak en deur gebloei tot op die tank
    • Toe n injector pypie op agter op die pomp losgemaak en probeer deurbloei, maar natuurlik gaan dit nie werk nie want dit hang af waar die verdeler staan.
    Dis toe nou waar ek probeer om hom met die starter te draai en net n "klonk" kry.
    Thanked: 1373
    Toe kom die starter af, en word oopgemaak.
    Die contactor se "skakelaar" is die probleem - die een been is baie langer as die ander en maak nie ordentelik kontak nie. So paar min met n vyl toe is altwee mooi plat en hy maak kontak op albei kante.
    Maar die motor draai nogsteeds nie. As ek die "jumper" kabel direk na die motor toe vat dan loop die motor - goeie nuus.
    Die probleem is - die twee kontak plaatjies is uitgewerk:
    As ek n plat yster bo-oor die twee kontakte sit dan loop die starter mooi so dis defnitief die swak kontak punte wat my probleem is.
    Oplossing:
    • Kry nuwe contactor by Calex more (glo nie hulle gaan hom he nie)
    • Skuur hulle net met skuur papier to hulle werk.
    • Vul dit op met iets soos copper weld en skuur plt.
    • Nuwe starter
    Thanked: 3188
    Draai engine met hand, kyk of engine los is
    Thanked: 1373
    Hy is los. Hom vandag teen die afdraende laat hardloop, hy draai mooi.
    Thanked: 3188
    Daardie is n baie ou starter. Die nuwer starters werk baie beter.
    Thanked: 1373
    Ek het Ali flatbar, dit behoort te werk om n nuwe een te maak?
    Kathu
    Thanked: 3019
    Aluminium kan dalk te sag wees. Jy kan koper busbar by elektriese groothandelaars koop. Mens kry dit in 300mm stukke.
    Of copper weld die laer kontak op. Dalk die goedkoopste opsie.
  15. #14
    Thanked: 1373
    Is dit die rods?
    Hoe werk hulle? Gewone sweis masjien of n vlam?
  16. #15
    Kathu
    Thanked: 3019
    Is dit die rods?
    Jip dit is hulle. Meeste verkoelings ouens gebruik dit. Omtrent alle hardeware plekke hou dit aan. Matweld afdeling. Kyk vir coperflow. Jy gas sweis hom met `n aankool(carburizing) vlam.
    https://leroymerlin.co.za/weld-rod-m...CABEgLhtvD_BwE
  17. #16
    Thanked: 1373
    Nou dat ek daaraan dink - my buurman doen aircons. Miskien moet ek n draai gaan maak daar.
  18. The Following User Says Thank You to Uys For This Useful Post:
  19. #17
    Thanked: 1373
    Ek loop vroer vandag by CAELEX in vir parte vir die starter. Die swart man agter die toonabnk se vir my (sonder om my te groet - ek het ook nog niks gese nie): Luister nou Ntate, daai ding kom van Fiat af. Kom ek en jy mors mekaar se tyd nie. Jy gaan nie nuwe contactors kry nie. Die spring is pap en ons het nie n nuwe een nie. En die coil is ook amper klaar.
    Hy draai om en loop weg, ek het nog nie n woord gese nie. Hy kom terug met n boks - wys na die toonbank toe en se: "Betaal daar"
  20. #18
    Thanked: 3188
    Pretty much wat ek daar vir jou gesÍ het...
  21. #19
    Thanked: 15075
    Ek stem saam met hom. Koop 'n nuwe.
    Jakes Louw
  22. #20
    Kathu
    Thanked: 3019
    Jy het die regte ding gedoen. Jy moes daardie man `n soen gee.
