Please help me fix this tractor. - Page 2
Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 21 to 40 of 217
    Feb 2008
    Thanked: 1387
    Default Re: Please help me fix this tractor.
    New starter is on and the diesel is reaching the pump. If I undo the supply banjo on the pump the diesel comes out a a good rate when cranking the engine. But no diesel comes out on the other side of the pump.
    See here:
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Friemersheim, Southern Cape
    Thanked: 3416
    Ek loop vroer vandag by CAELEX in vir parte vir die starter. Die swart man agter die toonabnk se vir my (sonder om my te groet - ek het ook nog niks gese nie): Luister nou Ntate, daai ding kom van Fiat af. Kom ek en jy mors mekaar se tyd nie. Jy gaan nie nuwe contactors kry nie. Die spring is pap en ons het nie n nuwe een nie. En die coil is ook amper klaar.
    Hy draai om en loop weg, ek het nog nie n woord gese nie. Hy kom terug met n boks - wys na die toonbank toe en se: "Betaal daar"
    Lekker lag ek nou
    En hy jou sommer baie sukkel vorentoe gespaar!
    Robert van den Berg
    'The danger comes from hankering for normalcy again, rather than getting on with working out how to deal with whatever is ahead.' - CNN article
  3. The Following User Says Thank You to Prof For This Useful Post:
  4. #23
    Feb 2008
    Thanked: 1387
    So here is what I envisage for removing the pump:
    1. Remove the injectors.
    2. Remove the tappit cover.
    3. Turn the engine to TDC on no1 piston.
    4. Remove the front inspection cover:
    1. Turn the engine to line up the timing marks.
    2. Remove the pump......
    Sounds simple enough.
  5. #24
    Thanked: 15170
    First check the sieve under the banjo?
  6. The Following User Says Thank You to jelo For This Useful Post:
  7. #25
    Feb 2008
    Thanked: 1387
    Which Banjo? At the inlet to the pump?
  8. #26
    Thanked: 453
    You must get Reenen's number and sommer put him on speed dial.
  9. #27
    Feb 2008
    Thanked: 1387
    But then how will the rest of you learn?
    Yes, he has obviously done a couple of these in the past.
  10. #28
    Langs die rivier, op n berg
    Thanked: 3191
    Met n skerp bytel, merk die pomp en timingcover om spoeltiming te merk.
  11. #29
    Feb 2008
    Thanked: 1387
    Injectors are out:
ID:	583125 Click image for larger version.
ID:	583127 Click image for larger version.
  12. #30
    Feb 2008
    Thanked: 1387
    I removed the tappit cover and all looks good in there. I've not measured the clearances on the valves yet, but it feels good.
ID:	583194Click image for larger version.
  13. #31
    Jan 2011
    Mtwalume, South Coast
    Thanked: 132
    Uys, I see that you are in the Centurion area. Can I please send a tractor to you that needs injector/pump repairs, I see that you have plenty experience now ?
  14. #32
    Feb 2008
    Thanked: 1387
    Quote Originally Posted by Errol View Post
    Let me get this one running first.
  15. #33
    Jan 2011
    Thanked: 132
    Sterkte
  16. #34
    Feb 2008
    Thanked: 1387
    Timing marks. See the small punch mark below the top 4. This is with no1 on TDC (no 4 rocking)
  17. #35
    Thanked: 15170
    Never mind, reenen covered the sieve already in his first post.
    Is it the Bosch VA or the VE?
  18. #36
    Feb 2008
    Thanked: 1387
    It is the VA.
  19. #37
    Thanked: 15170
    It is the VA.
    eish, manuals are scarce for those, can only find the VE stuff
  20. #38
    Feb 2008
    Thanked: 1387
    Maybe true, but I have no intention to open this pump myself. I can already hear the springs and small parts fly around the workshop.
  21. #39
    Feb 2008
    Thanked: 1387
    After discussions with about 8 diesel experts(which all gave me the same advise) I came to the conclusion that this is the end of the road for the diesel pump.
    Like I've said before, most (90%) of FIAT's ran on the CAV pump. This is actually the first one I saw with the Bosch pump on.
    A new CAV pump with the the drive gear for it and 4 new injectors is R10 900.00.
    Now my only concern is that all my timing marks was made for the pump I took off. I don't know what marks the new system will have and apparently a timing light only works with spark plugs........ On top of that the injection timing for the Bosch is 10 degrees BTDC and for the CAV it is 17 degrees BTDC. SO I'll have to figure that part out. Youtube I guess.
  22. #40
    Thanked: 3191
    Ek wou nie negatief wees oor daai pomp nie. Maar hulle het nie meer parte nie. Cuv, of iets soos n nissan td27 pomp, maar dan moet jy van 3 gate na 2 gaan. N mitsibusi 3 ton lorrie pomp behoort net so te pas...
    Maar ek sal net bybscrapyaed n nuwe model 640 pomp net so in drop.
