Please help me fix this tractor. - Page 2
Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 21 to 40 of 204
  1. #21
    Thanked: 1369
    Default Re: Please help me fix this tractor.
    New starter is on and the diesel is reaching the pump. If I undo the supply banjo on the pump the diesel comes out a a good rate when cranking the engine. But no diesel comes out on the other side of the pump.
    See here:
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  2. #22
    Friemersheim, Southern Cape
    Thanked: 3381
    Ek loop vroer vandag by CAELEX in vir parte vir die starter. Die swart man agter die toonabnk se vir my (sonder om my te groet - ek het ook nog niks gese nie): Luister nou Ntate, daai ding kom van Fiat af. Kom ek en jy mors mekaar se tyd nie. Jy gaan nie nuwe contactors kry nie. Die spring is pap en ons het nie n nuwe een nie. En die coil is ook amper klaar.
    Hy draai om en loop weg, ek het nog nie n woord gese nie. Hy kom terug met n boks - wys na die toonbank toe en se: "Betaal daar"
    Lekker lag ek nou
    En hy jou sommer baie sukkel vorentoe gespaar!
    Robert van den Berg
  3. The Following User Says Thank You to Prof For This Useful Post:
  4. #23
    Thanked: 1369
    So here is what I envisage for removing the pump:
    1. Remove the injectors.
    2. Remove the tappit cover.
    3. Turn the engine to TDC on no1 piston.
    4. Remove the front inspection cover:
    1. Turn the engine to line up the timing marks.
    2. Remove the pump......
    Sounds simple enough.
  5. #24
    Thanked: 15017
    First check the sieve under the banjo?
    Jakes Louw
  6. The Following User Says Thank You to jelo For This Useful Post:
  7. #25
    Thanked: 1369
    Which Banjo? At the inlet to the pump?
  8. #26
    Thanked: 444
    You must get Reenen's number and sommer put him on speed dial.
  9. #27
    Thanked: 1369
    But then how will the rest of you learn?
    Yes, he has obviously done a couple of these in the past.
  10. #28
    Langs die rivier, op n berg
    Thanked: 3181
    Met n skerp bytel, merk die pomp en timingcover om spoeltiming te merk.
  11. #29
    Thanked: 1369
    Injectors are out:
ID:	583125 Click image for larger version.
ID:	583127 Click image for larger version.
  12. #30
    Thanked: 1369
    I removed the tappit cover and all looks good in there. I've not measured the clearances on the valves yet, but it feels good.
ID:	583194Click image for larger version.
  13. #31
    Jan 2011
    Mtwalume, South Coast
    Thanked: 132
    Uys, I see that you are in the Centurion area. Can I please send a tractor to you that needs injector/pump repairs, I see that you have plenty experience now ?
  14. #32
    Thanked: 1369
    Quote Originally Posted by Errol View Post
    Let me get this one running first.
  15. #33
    Jan 2011
    Thanked: 132
    Sterkte
  16. #34
    Thanked: 1369
    Timing marks. See the small punch mark below the top 4. This is with no1 on TDC (no 4 rocking)
  17. #35
    Thanked: 15017
    Never mind, reenen covered the sieve already in his first post.
    Is it the Bosch VA or the VE?
    Jakes Louw
  18. #36
    Thanked: 1369
    It is the VA.
  19. #37
    Thanked: 15017
    It is the VA.
    eish, manuals are scarce for those, can only find the VE stuff
    Jakes Louw
  20. #38
    Thanked: 1369
    Maybe true, but I have no intention to open this pump myself. I can already hear the springs and small parts fly around the workshop.
  21. #39
    Thanked: 1369
    After discussions with about 8 diesel experts(which all gave me the same advise) I came to the conclusion that this is the end of the road for the diesel pump.
    Like I've said before, most (90%) of FIAT's ran on the CAV pump. This is actually the first one I saw with the Bosch pump on.
    A new CAV pump with the the drive gear for it and 4 new injectors is R10 900.00.
    Now my only concern is that all my timing marks was made for the pump I took off. I don't know what marks the new system will have and apparently a timing light only works with spark plugs........ On top of that the injection timing for the Bosch is 10 degrees BTDC and for the CAV it is 17 degrees BTDC. SO I'll have to figure that part out. Youtube I guess.
  22. #40
    Thanked: 3181
    Ek wou nie negatief wees oor daai pomp nie. Maar hulle het nie meer parte nie. Cuv, of iets soos n nissan td27 pomp, maar dan moet jy van 3 gate na 2 gaan. N mitsibusi 3 ton lorrie pomp behoort net so te pas...
    Maar ek sal net bybscrapyaed n nuwe model 640 pomp net so in drop.
