Rivet Counters
Results 1 to 20 of 20
Thread: Rivet Counters
    Thanked: 546
    Default Rivet Counters
    Anyone know what the correct size solid Aluminum rivets are for Series body parts.
    3/16 by 1/2 length
    3/16 by 7/16 length
    3/16 by 3/8 length
    What are correct sizes.
    How many roughly required for entire series.
    And do we have a supplier in SA.
    Defender Kalahari
    Series 3 SWB
    Series 1 De Luxe Cab Pickup
    Series 1 Station Wagon 88''
  2. The Following User Says Thank You to imgreg For This Useful Post:
    Apr 2018
    RSA
    Thanked: 1098
    Default Re: Rivet Counters
    This is going to be interesting to me Imgreg. My series has pop rivets but you are obviously busy with a restoration. Maybe you need to check the material too to prevent galvanic corrosion?
    Jan 2017
    Thanked: 312
    Try Fascor?
    Nov 2011
    Langebaanweg
    Thanked: 1220
    Not too familiar with the technicalities of the series.
    But rivet lengths will vary according to amount of metal being fastened.
    So you can buy the longest and trim them to the correct lengths before bucktailing them.
    If you need to calculate the required length that protrudes, I can ask a colleague.
    Are you going pneumatic with bucking bar?
    Nov 2011
    Langebaanweg
    Thanked: 1220
    Oh... and talk to a aircraft structural worker(sheety)
    They can help you with a lot of the questions you have.
    That's a 4.8mm rivet, so it's max.
    If you can use smaller, please do as you can always go bigger.
    Use a 4.9mm drill bit for best results.
    Thanked: 451
    https://youtu.be/FJxQby4SRCc
    You’re welcome
  8. The Following 2 Users Say Thank You to GaryFrank For This Useful Post:
    Thanked: 451
    Speak to David Kinghorn (JLR Spares) about those rivets. As far as I know, you have to buy the correct size...., cutting them to size is a pain.
    Nov 2011
    Langebaanweg
    Thanked: 1220
    Ja, sorry I'm used borrowing the Sheeties tools.
    They have a nice rivet cutter
    Thanked: 546
    That is the same thing i was looking at.
    I just have to have the chisels cut off and made into the dome / cup.
    Defender Kalahari
    Series 3 SWB
    Dec 2014
    Thanked: 1980
    There is a place at Rand Airport (or was, I'm not sure) called USATCO, they sell aircraft structural tooling, so you will find rivet guns, snaps and bucking bars, rivet cutters and all sorts of drool inducing toys there at frightening prices.
    They may well have rivets, too.
    Buy the longest rivets you will need, add 1/8'' and cut them to size as required is my advice.
    The Adendorff guns and similar may cause trouble, they have a very harsh stroke delivery, I'd suggest an inline flow reducing adjuster like this...
    You will need the correct snaps, though, those will not be easy to make unless you have some fancy tooling and materials. The rivet head recesses are polished and hardened, and so are the shanks where the piston seats. Normal rivet guns are a .410" shank size for the snaps.
    Here is a 3X size gun with snaps and some bucking bars... Don't get anything smaller than 3X as you will struggle to drive the rivets with a lighter gun.
    Yours for Euro +- 340.00
    As for the actual riveting... there are basic rules, but as your Landy already has the holes drilled, you just need to follow that pattern.
    Here is a chart for shank lengths and finished dimensions if you want to get really technical.
    There are also options to put washers over the shanks if you need to, then obviously the rivet length increases by the corresponding thickness.
    The top diagram should apply to your needs.
    Have a read here, for an idea of how the aviation guys do it.
    https://www.aircraftsystemstech.com/...tructural.html
    Buy the best drills you can, drilling the heads off if you don't set correctly can be a pain with a marginal drill bit as it will wander on the round head and then end up off centre to the stem position.
    If you mess a hole up, there are rivet versions of these bolts available, but they are eye wateringly expensive...
    Rivets work harden, so find out about how to treat them prior to fitting them and the time between treatment and fitting as they can also start to harden while they wait for you to get set up and start, depending on the alloy used and the hardness level.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  13. The Following 3 Users Say Thank You to JohnnoK For This Useful Post:
  14. #11
    Apr 2018
    RSA
    Thanked: 1098
    For the life of me I just can't see why those special bolts are so expensive Johnno. Most holes are shaped like that.
  15. #12
    Dec 2016
    Thanked: 144
    Have used rivets designed to be waterproof before. You have to get the correct length but if you "gasket" the head side and insert, the moisture can't leak inside. Roofing people use them in certain cases. Especially when you cannot get to the back.
    Would be interested to hear comments.
  16. #13
    Dec 2014
    Thanked: 1980
    Ja, you'd think so with the numbers out there...:
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  17. The Following User Says Thank You to JohnnoK For This Useful Post:
  18. #14
    Thanked: 979
    I've got this bag of rivets that I got for a project many years ago. The project didn't get off the ground so if anyone can use them make me an offer. Click image for larger version.
ID:	582859Click image for larger version.
ID:	582860Click image for larger version.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  19. #15
    Thanked: 546
    I will be keen.
    Let me get a price per 100 in the morning and make you a fair offer.
    They are very long but can be cut shorter.
    I need 3/16 x 3/8 around 10mm long.
    Edit, might be too small for me as 3/16 is around 4.7mm
    Those are near 4mm. Will Have to make sure.
    Defender Kalahari
    Series 3 SWB
  20. #16
    Sep 2008
    Thanked: 145
    Greg, have you tried Rivco Products - I have used their rivets on my Series 1. They have a branch in PE. https://www.rivets.co.za/contact.php
    1951 Land Rover Series I 80" 2-litre ioe tilt (project)
    1975 Land Rover Series III 88" 2.25 p soft top (workhorse)
    1998 Land Rover Defender 90 2.8i CSW (expedition vehicle)
    1977 Land Rover Series III 109" 2.25 p station wagon (sold)
  21. The Following User Says Thank You to lrswb For This Useful Post:
  22. #17
    Thanked: 979
    Quote Originally Posted by imgreg View Post
    I will be keen.
    Yes they are one size smaller than what you need.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
  23. #18
    Nov 2011
    Langebaanweg
    Thanked: 1220
    Also did some rivet work today, not on a series thou.
    Part of my gullwing project.
  24. #19
    Thanked: 546
    Nice, did you use a hammer or a pneumatic chisel ?
    Did you get rivets in Cape Town ?
    Defender Kalahari
    Series 3 SWB
  25. #20
    Nov 2011
    Langebaanweg
    Thanked: 1220
    I'm blessed with a aircraft structural worker as a friend.
    He has everything.
    These were done with a pneumatic rivet gun and bucking bar.
    The other, on other parts, were done with a pneumatic rivet squeezer.
